Register | FAQ's | New Posts | Today's Posts | Extras |
» Washer not spinning properly |
![]() Model Number: RAX4232kQ0 Brand: Roper Age: More than 10 years
![]() I have a Roper Washer RAX4232KQ0 that isn't spinning clothes completely dry. I replaced the block a week ago thinking that was the problem and it didn't fix the problem. Now I'm guessing the problem might possibly be the coupling or clutch instead. With a full normal load or small load it spins really slowly therefore leaving the clothes overly wet. To further elaborate on the problem with spinning clothes dry it will only spin 1 or 2 articles of clothing at a time dry and not a full load or even a small load. Your advice is greatly appricated. Thanks, Steve Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() You most likely need to replace the clutch but I would check the condition of the motor coupler first.
Whirlpool 285785 Clutch Assembly - AppliancePartsPros.com Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com Eric |
![]() fairbank56 Eric I checked the Direct Drive Washer Motor Coupling and the arms & the hockey puck all look like brand new so I am assuming the Clutch Assembly is bad? Is there anyway to check the Clutch Assembly?
Thanks, Steve |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Washer not spinning - how do I open up washer top or side and replace belt? | bbradenak | Dryer Repair | 1 | 06-18-2012 08:22 PM |
washer not spinning properly | mikeeagle22 | Washer Repair | 3 | 04-26-2012 10:46 AM |
Washer (newly relocated) Not Spinning Properly | pacer25jones@msn.com | Washer Repair | 1 | 11-21-2011 10:07 AM |
Maytag washer not spinning properly | tnglc | Washer Repair | 2 | 11-19-2009 11:56 AM |
GE Washer does not run properly | vivitar16 | Washer Repair | 4 | 08-27-2008 10:23 AM |
