| » Washer don't spin |
Model Number: 11047512601 Brand: Kenmore Age: 1 - 5 years
My washer does'nt spin.It washes,drains but does'nt spin.The only time it spins is when it is empty.I replaced the electronic board on top.I got it to spin twice with 2 towles in it in about 10 tries. Ser# is HLT4353286.
See if you can find the tech notes with trouble shooting routines, either under the top or inside the bottom panel.
A probable cause is your motor control board, but it is very expensive and you do not want to replace it unless you are sure that is the problem.
__________________
I got the tech notes and ran A diagnostic test and everything worked it would even spin at high speed. I cant get A erroe code. Plus now I can't make it run the clean washer cycle without A F34 code with nothing in it.
Well, based on this information I would suspect the main board, but you have already replaced it.
It is possible, maybe even likely the main board you received was defective, and I would see if you can get an exchange on it. That way you will either have it fixed or know for sure the main board is not the problem.
__________________
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 10 | 05-24-2011 12:25 PM |
| Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 8 | 01-13-2011 10:13 AM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| whirlpool washer won't spin manually or spin | boniam | Washer Repair | 15 | 06-29-2008 07:19 AM |
