Discuss
Kenmore Washer Lid Lock/Won't fill
 in
Washer Repair
Hello guys, this is my first post on your site. Hello to all. Hopefully someone may be able to help
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer Lid Lock/Won't fill
  #1 (permalink)
Old 11-22-2013, 02:42 AM
Junior Member
dlarvin is on a distinguished road
Default Kenmore Washer Lid Lock/Won't fill
Model Number: 110.21102012   Brand: Kenmore   Age: 1 - 5 years
Hello guys, this is my first post on your site. Hello to all. Hopefully someone may be able to help me figure this out. I recently acquired a Kenmore Washer Model 110.21102012. the lid lock was disassembled and in the tub. Upon further inspection I noticed there were a few pieces of the switch missing, including the solenoid. I have a copy of the Tech sheet, describing how to run diagnostic tests, etc. Problem being, the washer has to be in standby mode, which of course it can't due to the lid lock situation. So, after a little more searching, I managed to find the wiring diagram for the lid lock (I've attached the image below). Basically I'm wanting to run the diagnostics or at least get it to run through a full cycle, to make sure nothing else is wrong. In an effort to bypass the lid lock, and after looking at the diagram, I connected all 4 wires, which should be comparable to the lid being shut, and the lid locked. When I turn it on, the red indicator lights up solid for the lid lock, then after a few seconds, a click, then the green Fill indicator comes on, but no water is flowing. then after a minute or so, the motor turns on briefly and spins the tub just a bit, then spins briefly again after another minute or two. Then...nothing. the green Fill light stays on....and the red lid lock light stays on solid. I left it like that while I ate dinner, came back and everything still the same. I'm thinking that the machine may be assuming the water is in the process of filling the tub and its waiting for the signal from the load size sensor to signal that it has enough water, before it starts to agitate. Only other possibility I can think of is that the board may be screwed from some unknown event prior to it coming into my hands. I don't think the lid lock circuit would have anything to do with it, but I may be wrong, only thing I can think of from that end is the diagram showing that the solenoid has 68-100 ohm resistance that is not present without having the actual solenoid. Any info, thoughts, or ideas would be much appreciated. Just figured I'd ask someone more knowledgeable about such things before I go any further. Thanks.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 11-22-2013, 06:43 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Your going to need a working lid lock. The normal sequence when starting is that the control board first locks the lid, then unlocks and locks again to test the function of the switch.
Eric
  #3 (permalink)
Old 11-22-2013, 01:06 PM
Junior Member
Default RE Lid switch
Quote:
Eric
Hey Eric is there anyway to manually perform the sequence of operation by jumping the wires out. The reason I'm asking is I want to find out if everything else is working before I purchase the switch. Thanks for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore 800 washer won't fill glor41 Washer Repair 0 08-19-2012 08:55 AM
Kenmore washer won't fill johnzo Washer Repair 2 04-02-2012 07:33 AM
Kenmore washer won't fill rooner Washer Repair 1 12-25-2011 06:53 PM
Kenmore washer will not fill tconley Washer Repair 5 01-06-2011 03:20 PM
Kenmore top load washer lid lock error schoolfishguy Dishwasher Repair 0 12-04-2008 04:12 AM
