Discuss
LG front load just fills will not stop
 in
Washer Repair
I have an LG THROMM from tag I assume by the tag on side model 50WD7230. I don't know what
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG front load just fills will not stop
  #1 (permalink)
Old 11-20-2013, 11:11 AM
Junior Member
mojuave is on a distinguished road
Default LG front load just fills will not stop
Model Number: 50WD7230   Brand: -other-   Age: 5 - 10 years
I have an LG THROMM from tag I assume by the tag on side model 50WD7230. I don't know what happened was working fine then next cycle just started filling and will stop, it will agitate but will not drain either. Right now I have a washer half full of water and we all know what will happen if I open the door, PLEASE HELP
Related Models
Hoover 51
Frigidaire 5100A AIR CONDITIONER
Frigidaire 5107B AIR CONDITIONER
Frigidaire 5117A ROOM AIR CONDITIONER
Frigidaire 5118A AIR CONDITIONER
Frigidaire 5119A AIR CONDITIONER
Frigidaire 5121A AIR CONDITIONER
Frigidaire 5127A AIR CONDITIONER
Frigidaire 5128A AIR CONDITIONER
Frigidaire 5129A AIR CONDITIONER
Hoover 5130
Frigidaire 5130009B Frg(v0) / Room Air Conditioner
Hoover 5131
Frigidaire 5131A AIR CONDITIONER
Frigidaire 5132001 FRIGIDAIRE ROOM AIR CONDITIONER
Frigidaire 5132001A Frg(v0) / Room Air Conditioner
Hoover 5137
Frigidaire 5137006A AIR CONDITIONING 5200 B.T.U.
Frigidaire 5137007E1 AIR CONDITIONER
Frigidaire 5138007 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5138007E AIR CONDITIONER
Frigidaire 5138007G1 AIR CONDITIONER
Frigidaire 5139008 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5139008A FRIGIDAIRE AIR CONDITIONER
Frigidaire 5139008E1 AIR CONDITIONER
Frigidaire 5139A AIR CONDITIONER
Hoover 5140
Frigidaire 5144000 AIR CONDITIONER
Frigidaire 5144000B AIR CONDITIONER
Frigidaire 5145001 WESTINGHOUSE AIR CONDITIONER
Frigidaire 5145001B AIR CONDITIONER
Hoover 5146
Frigidaire 5146002 AIR CONDITIONER
Frigidaire 5146002A AIR CONDITIONER
Frigidaire 5147003 FRIGIDAIRE AIR CONDITIONER
Hoover 5148
Frigidaire 5148004A AIR CONDITIONER
Frigidaire 5148004E FRIGIDAIRE ROOM AIR CONDITIONER
Frigidaire 5149A AIR CONDITIONER
Amana 515.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 5150
Frigidaire 5154007 AIR CONDITIONER
Hoover 5158
Hoover 5158-01
Frigidaire 5159B AIR CONDITIONER
Hoover 5160
Frigidaire 5164004 AIR CONDITIONER
Frigidaire 5167A AIR CONDITIONER
Frigidaire 5167B AIR CONDITIONER
Hoover 5168
Hoover 5168-01
Frigidaire 5169B AIR CONDITIONER
Frigidaire 5174001 AIR CONDITIONER
Frigidaire 5174001B AIR CONDITIONER
Frigidaire 5176003A ROOM AIR CONDITIONER
Frigidaire 5177004A AIR CONDITIONER
Frigidaire 5177004B AIR CONDITIONER
Frigidaire 5178A AIR CONDITIONER
Frigidaire 5179A AIR CONDITIONER
Frigidaire 5179B AIR CONDITIONER
Frigidaire 5180004 WESTINGHOUSE AIR CONDITIONER
Frigidaire 5180004A AIR CONDITIONER
Frigidaire 5187A AIR CONDITIONER
Frigidaire 5187B AIR CONDITIONER
Frigidaire 5187C AIR CONDITIONER
Frigidaire 5193004 AIR CONDITIONER
Frigidaire 5193004A AIR CONDITIONER
Frigidaire 5193004B AIR CONDITIONER
Frigidaire 5195006 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5195006A AIR CONDITIONER
Frigidaire 5197A AIR CONDITIONER
Frigidaire 5198A AIR CONDITIONER
Frigidaire 5198B AIR CONDITIONER
Frigidaire 5198C AIR CONDITIONER
Frigidaire 5198G AIR CONDITIONER
Magic Chef 51FA-1K RANGE- D/I STD GAS
Magic Chef 51FA-1KXS-ON RANGE- D/I STD GAS
Magic Chef 51FA-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FA-2KW RANGE- D/I STD GAS
Magic Chef 51FA-2KW-BS RANGE- D/I STD GAS
Magic Chef 51FA-2KX-ON RANGE- D/I STD GAS
Magic Chef 51FA-2KXS-ON RANGE- D/I STD GAS
Magic Chef 51FK-2KLX-64 RANGE- D/I CONT CLEAN GAS
Magic Chef 51FK-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FN-1K RANGE- D/I STD GAS
Magic Chef 51FN-1KX RANGE- D/I STD GAS
Magic Chef 51FN-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FN-2KW RANGE- D/I STD GAS
Magic Chef 51FN-2KW-BS RANGE- D/I STD GAS
Magic Chef 51FN-2KX-ON RANGE- D/I STD GAS
Magic Chef 51FY-2KLX-ON RANGE- D/I CONT CLEAN GAS
Whirlpool 51IMWEX1 FREESTANDING ICE MAKER
Amana 520.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 520.001 MWAVE - FAMILY SIZE (60 HZ)
Hoover 5200
Frigidaire 5237A AIR CONDITIONER
Frigidaire 5238A AIR CONDITIONER
Hoover 5240
Frigidaire 5243000 AIR CONDITIONER
Frigidaire 5243000A AIR CONDITIONER
Frigidaire 5243000B AIR CONDITIONER
Frigidaire 5244001A ROOM AIR CONDITIONER
Frigidaire 5249A AIR CONDITIONER
Frigidaire 5249G AIR CONDITIONER
Frigidaire 5257A AIR CONDITIONER
Frigidaire 5257B AIR CONDITIONER
Frigidaire 5257C AIR CONDITIONER
Frigidaire 5257D AIR CONDITIONER
Frigidaire 5257G AIR CONDITIONER
Frigidaire 5263004 AIR CONDITIONER
Frigidaire 5263004A AIR CONDITIONER
Frigidaire 5263004B AIR CONDITIONER
Frigidaire 5277A ROOM AIR CONDITIONER
Frigidaire 5277C AIR CONDITIONER
Frigidaire 5277D AIR CONDITIONER
Frigidaire 5287A AIR CONDITIONER
Frigidaire 5288A AIR CONDITIONER
Frigidaire 5289A AIR CONDITIONER
Frigidaire 5291003 AIR CONDITIONER
Frigidaire 5291A AIR CONDITIONER
  #2 (permalink)
Old 11-20-2013, 11:16 AM
Senior Member
Appliance Ninja is on a distinguished road
Default
Don't open the door if there is that much water in it. It is likely locked, anyway. Can you hear the drain pump running when it should be pumping out, even if it doesn't? Also, with the water filling, are you saying that it just keeps filling up and will not stop unless you shut the machine off?
  #3 (permalink)
Old 11-20-2013, 11:23 AM
Junior Member
Default
Quote:
i can actually open the door if i wanted to but it floods my floor. yes it just keeps filling. I bought this model for water saving so normal cycle it fills a little spins fills spins opposite and so on then drains and repeats but when i turn it on it just keeps filling but without power it wont fill so i assume valve is not stuck but also will not drain im thinking some kind sensor but I don't know where to even start it just seems like 2 different problems
  #4 (permalink)
Old 11-20-2013, 11:28 AM
Senior Member
Default
If you remove the top of the machine, you will see the pressure switch mounted near the top of the machine. It will have a very small hose attached to it (or should have). If you remove that hose and blow through it, does air easily pass through that hose? The model number is behind the door, so once I get that I can get you more specific information.
  #5 (permalink)
Old 11-20-2013, 11:31 AM
Junior Member
Default
ok i will try that but i might need help that i dont have now to remove my dryer from the wasker they are stackable. so the 50WD7230 tag on the side is not the model?
  #6 (permalink)
Old 11-20-2013, 11:33 AM
Senior Member
Default
Yes, you will need to remove the dryer to get the top off. The model is not coming up, I have tried it several ways. The model tag is inside the door, I believe.
  #7 (permalink)
Old 11-20-2013, 12:02 PM
Junior Member
Default
ok i gained access the is one black tube on the right side coming up from bottom i blew in it and it made bubbles inside the water thats in the drum. there is what seems to be a valve on that side machine that has a stub where an air line valve would go though should it be hooked up? i tried it and still washer just keeps getting full
  #8 (permalink)
Old 11-20-2013, 01:08 PM
Senior Member
Default
If that hose came off, the switch will think the tub is empty, so you will need to get the water out, then take the tube back off so the pressure is equal. Then, with all the water out, place that tube back to the pressure switch. What happens then?
  #9 (permalink)
Old 11-20-2013, 01:15 PM
Junior Member
Default
ok so i need to first empty the drum of water? then once its empty put hose back then i should be good? when you say empty drum like as much as possible only way is to open door i guess then right? is there anyway to jump the valve to turn on to dump the water??
  #10 (permalink)
Old 11-20-2013, 01:27 PM
Senior Member
Default
That is correct. You should be able to start just a spin cycle to pump the water out. Then replace that hose back to the switch and see what happens.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Load Washer Fills With Water When Not In Use Brewman Washer Repair 1 09-07-2013 05:19 AM
Front load washer not spinning, drains and fills only. dcortes Washer Repair 0 05-19-2013 12:13 PM
Front load washer fills with door open DBG Washer Repair 1 07-07-2011 05:10 AM
Front load washer fills with water when off volunteer2 Washer Repair 1 03-05-2010 03:44 PM
Front Load Washer fills with water between loads bobfarrel@aim.com Washer Repair 2 09-29-2009 12:03 PM
