Discuss
LG front load just fills will not stop
 in
Washer Repair
Originally Posted by Appliance Ninja That is correct. You should be able to start just a spin cycle to pump
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG front load just fills will not stop
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #11 (permalink)
Old 11-20-2013, 01:59 PM
Junior Member
mojuave is on a distinguished road
Default
Quote:
Originally Posted by Appliance Ninja View Post
That is correct. You should be able to start just a spin cycle to pump the water out. Then replace that hose back to the switch and see what happens.
wm1812cw is the model #. so what i did was drag it out to back porch and dump it because i dont have just a spin cycle had to be a rinse and spin and again just fills with water. After i dump it drag it in and hook back up ran a rinse and spin and shut it off when water got to door, I know from past the water turns on and off alternating spin direction so steady on water does not operate correctly. I did however notice that the suuport leg to drum is off on that side(probably me when i replaced drum shaft) which may have caused hose to disconnect. I think at this point maybe order new air valve thing?
  #12 (permalink)
Old 11-20-2013, 02:26 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
If it finally did shut off bur still overfilled, I do believe the pressure switch may need to be replaced. The correct one for your model is available at the link below.
LG 6601ER1006A Switch Assm.,sensor S - AppliancePartsPros.com
  #13 (permalink)
Old 11-21-2013, 07:38 AM
Junior Member
Default
I am about to order that is there anything else I may need? my water fill valves seem to leak a little now and then i see water coming out from underneath but only during cycle and I cant seem to find that valve on parts list
  #14 (permalink)
Old 11-21-2013, 07:43 AM
Senior Member
Default
Both valves for your model are available below. I can think of no other parts you may need.
LG 5221ER1003A Water Inlet Valve Assembly - AppliancePartsPros.com
LG 5220FR2006H Water Inlet Valve Assembly - AppliancePartsPros.com
  #15 (permalink)
Old 11-21-2013, 07:57 AM
Junior Member
Default
ok on order i will update as repairs are made. Thank you so much for your help now if i can only remember my info when bought parts for door seal and my dishwasher to sign in lol
  #16 (permalink)
Old 11-21-2013, 08:07 AM
Senior Member
Default
You are very welcome, keep me posted!
  #17 (permalink)
Old 11-25-2013, 06:57 AM
Junior Member
Default
ok part came very fast just like it always does from here and had it installed 2 days after order. The sensor was the problem and now washer working great.
*** there was water in the tub so I had to trick the sensor on first cycle by blowing air through line pinching line then hook back to sensor creating initial pressure (only because I didn't want to drain it again)
  #18 (permalink)
Old 11-25-2013, 07:35 AM
Senior Member
Default
Glad you got it up and running, nice work!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Load Washer Fills With Water When Not In Use Brewman Washer Repair 1 09-07-2013 05:19 AM
Front load washer not spinning, drains and fills only. dcortes Washer Repair 0 05-19-2013 12:13 PM
Front load washer fills with door open DBG Washer Repair 1 07-07-2011 05:10 AM
Front load washer fills with water when off volunteer2 Washer Repair 1 03-05-2010 03:44 PM
Front Load Washer fills with water between loads bobfarrel@aim.com Washer Repair 2 09-29-2009 12:03 PM
