Discuss
Frigidaire F/L Washer Clunking & Smoking
 in
Washer Repair
For a while the high-speed spin of this front-loader was sounding like a jet aircraft taking off, suddenly it started
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire F/L Washer Clunking & Smoking
  #1 (permalink)
Old 11-17-2013, 09:51 AM
Junior Member
BobT55 is on a distinguished road
Unhappy Frigidaire F/L Washer Clunking & Smoking
Model Number: 417.39022891   Brand: Frigidaire   Age: More than 10 years
For a while the high-speed spin of this front-loader was sounding like a jet aircraft taking off, suddenly it started clunking like a pair of shoes was inside.
When my wife went to take the load out there was smoke which smelled like burnt rubber.
Any thoughts on the possible cause & fix? Anyone know if there is a repair manual available online?
Thanks in advance.
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
  #2 (permalink)
Old 11-17-2013, 11:34 AM
Senior Member
Appliance Ninja is on a distinguished road
Default
Sorry to hear of your washer trouble. I suspect the main tub bearing was initially bad, followed by a broken tub support now. If you open the door and lift up and down on the inner tub, is it loose and does it knock when you lift it up and down?
  #3 (permalink)
Old 11-17-2013, 12:04 PM
Junior Member
Default
Yup, seems to move pretty freely and knocks pretty loudly. I saw there's posted info on replacing the bearing - is the tub support readily replaced?
Thanks for your help.
  #4 (permalink)
Old 11-17-2013, 02:37 PM
Junior Member
rileedee is on a distinguished road
Default
I think my daughter's Samsung F/L washer (model # WF218ANB/XAA) may have similar problems. The drum gasket is visibly VERY torn. The drum is VERY loose...and when you turn the drum you can hear bearings, and they continue to roll after you stop the drum.
I would appreciate any help we could get also.
  #5 (permalink)
Old 11-17-2013, 04:11 PM
Senior Member
Default
Given the cost of the inner tub assembly and the outer tub assembly (the bearing comes as part of the tub assembly) it will likely be more economical to replace the machines. However, I can help with repair, if you decide to repair them.
  #6 (permalink)
Old 11-17-2013, 06:53 PM
Junior Member
Default
I agree that with the cost of the parts (~ $300-$600 if I understand the assemblies) and adding to the age of the machine it makes sense to replace it.
I do appreciate your help. Live well, happy and healthy.
  #7 (permalink)
Old 11-17-2013, 06:54 PM
Senior Member
Default
Thank you, Bob! Have a great week, even if you have to go washer shopping!
  #8 (permalink)
Old 11-18-2013, 09:14 AM
Junior Member
Default
I don't remember exactly how long ago my daughter got her washer, but I don't think its 5 years old (though it is out of warranty).
Can you direct me to videos or instructions to determining exactly what does need to be replaced?
  #9 (permalink)
Old 11-18-2013, 09:17 AM
Senior Member
Default
Sure, those parts are available below!
Samsung DC97-15328F Assy S.tub Back;frontier - AppliancePartsPros.com
Samsung DC97-15013D Assy Drum;prime-Pjt,w - AppliancePartsPros.com
  #10 (permalink)
Old 11-18-2013, 10:35 AM
Senior Member
Default
I found a service manual but it is not for your exact model. However, it will get you in the right direction for those parts! It is available for download below.
Samsung Washer Manual
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Washer-clunking noise tracib01 Washer Repair 2 06-16-2011 07:18 AM
Washer is clunking...really badly AlanS Washer Repair 0 09-08-2010 08:35 PM
GE washer aggitator clunking Vrons Washer Repair 1 10-15-2009 07:10 PM
ge washer clunking noise dbnbob Dishwasher Repair 1 07-15-2009 03:45 AM
Frigidaire Washer Smoking, not Spinning cesar960 Washer Repair 1 10-17-2008 12:19 AM
