Discuss
top load washer not spin drying
 in
Washer Repair
no matter how big or small the load size, the clothes are still soaked at the end of the cycle.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » top load washer not spin drying
  #1 (permalink)
Old 11-12-2013, 10:24 PM
Junior Member
Firedan is on a distinguished road
Red face top load washer not spin drying
Model Number: MVWC400XW3   Brand: Maytag   Age: 1 - 5 years
no matter how big or small the load size, the clothes are still soaked at the end of the cycle. have to put in an additional drain spin cycle. only then is the load adequately spun dryed.
Related Models
Maytag MVWC450WW0 AUTOMATIC WASHER
Maytag MVWC500VW0 AUTOMATIC WASHER
Maytag MVWC500VW1 AUTOMATIC WASHER
Maytag MVWC5ESXW0 AUTOMATIC WASHER
Maytag MVWC6ESWW0 AUTOMATIC WASHER
Maytag MVWC6ESWW1 AUTOMATIC WASHER
Maytag MVWC700VJ0 AUTOMATIC WASHER
Maytag MVWC700VJ1 AUTOMATIC WASHER
Maytag MVWC700VW0 AUTOMATIC WASHER
Maytag MVWC700VW1 AUTOMATIC WASHER
Maytag MVWC7ESWW0 AUTOMATIC WASHER
Maytag MVWX500XL0 AUTOMATIC WASHER
Maytag MVWX500XW0 AUTOMATIC WASHER
Maytag MVWX550XW0 AUTOMATIC WASHER
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
  #2 (permalink)
Old 11-13-2013, 08:26 AM
Senior Member
Appliance Ninja is on a distinguished road
Default
Does it spin every time when you manually set it to spin after the cycle end? If you look at the water as it pumps out from the drain hose, does the water stream seem pretty forceful and fill the hose or a partial, weak stream?
  #3 (permalink)
Old 11-19-2013, 01:56 PM
Junior Member
Default
Quote:
yes, it spins every time when I change to "spin" at the end of the cycle. It does seem to be pumping adequately but what do I know. I have not watched it through the initial spin cycle. so I don't know for sure if it is or is not pumping out the water before the timer stops or advances.
  #4 (permalink)
Old 11-19-2013, 02:16 PM
Senior Member
Default
Well, if it spins out every time you set it manually, I suspect the issue may be slow draining, not pumping out fast enough. Can you fill the tub and the drain it out, watching at how fast the water pumps out as it drains?
  #5 (permalink)
Old 11-19-2013, 09:27 PM
Junior Member
Default
yes, i will give it a go. so are you thinking bad pump assy? I will let you know tomorrow what i find. thank you for all your help.
  #6 (permalink)
Old 11-20-2013, 07:27 AM
Senior Member
Default
Yes, or a partially obstructed drain path/pump. That it spins and does okay if set to another spin cycle manually suggests the mechanics of the other components are okay, but we will know more when we see what the pump is doing for certain.
  #7 (permalink)
Old 11-20-2013, 05:50 PM
Junior Member
Default
I watched it go thru a complete wash cycle, from start to finish. when it got to the final cycle (fill,rinse,spin) it filled the tub with rinse water agitated for a bit then it pumped the water out and spun for a bit. After a pause, it started to fill for a minute or so than stopped filling and the cycle ended. I did notice that as it was in it's last fill cycle prior to ending that, the lid lock unlocked it self and the led indicator (lid lock) flashed continuously for about 3 minutes until the cycle ended. now I'm even more confused.
  #8 (permalink)
Old 11-20-2013, 06:07 PM
Senior Member
Default
That sounds like a confused control, especially the adding water after spinning. Try unplugging the machine for about 15 minutes and see if that changes how it acts at the end of the cycle.
  #9 (permalink)
Old 11-21-2013, 01:07 AM
Junior Member
Default
ok, i will give that a try. i will let you know how that turns out
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer works fine with no load, stops in spin with load. Bgraybea Washer Repair 0 06-21-2013 02:57 PM
GE top load is not spin drying quasimodo928 Washer Repair 3 02-16-2013 03:33 PM
Washer not totally spin drying clothes Darnoc Washer Repair 1 09-02-2011 05:10 PM
Washer stopped agitating and spin drying mommasan Washer Repair 4 08-29-2011 05:06 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
