Discuss
kenmore he5t SHOW F35 ERROR
 in
Washer Repair
I just replaced the pressure sensory on this machine and now it is showing an F35 code and sud code
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore he5t SHOW F35 ERROR
  #1 (permalink)
Old 11-12-2013, 11:03 AM
Junior Member
char993 is on a distinguished road
Default kenmore he5t SHOW F35 ERROR
Model Number: 11047781701   Brand: Kenmore   Age: 1 - 5 years
I just replaced the pressure sensory on this machine and now it is showing an F35 code and sud code still. Any ideas what this could be or where i might find the answer?
Related Models
Kenmore 11047781701 RESIDENTIAL WASHER
Kenmore 11047781702 WASHER
Kenmore 11047787800 WASHER
Kenmore 11047787801 WASHER
Kenmore 11047788800 WASHER
Kenmore 11047788801 WASHER
Kenmore 11047789700 RESIDENTIAL WASHER
Kenmore 11047789701 RESIDENTIAL WASHER
Kenmore 11047789702 WASHER
Kenmore 11047791700 RESIDENTIAL WASHER
Kenmore 11047791701 RESIDENTIAL WASHER
Kenmore 11047791702 WASHER
Kenmore 11047797800 RESIDENTIAL WASHER
Kenmore 11047797801 WASHER
Kenmore 11047798800 RESIDENTIAL WASHER
Kenmore 11047798801 WASHER
Kenmore 11047799701 RESIDENTIAL WASHER
Kenmore 11047799702 WASHER
Kenmore 11047852700 WASHER
Kenmore 11047852701 RESIDENTIAL WASHER
Kenmore 11047852702 RESIDENTIAL WASHER
Kenmore 11047852703 RESIDENTIAL WASHER
Kenmore 11047882700 WASHER
Kenmore 11047882701 RESIDENTIAL WASHER
Kenmore 11047882702 RESIDENTIAL WASHER
Kenmore 11047882703 RESIDENTIAL WASHER
Kenmore 11048182790 AUTOMATIC WASHER
Kenmore 11048182791 AUTOMATIC WASHER
Kenmore 11048184790 AUTOMATIC WASHER
Kenmore 11048184791 AUTOMATIC WASHER
Kenmore 11048722790 COMPACT AUTOMATIC WASHER
Kenmore 11048722791 COMPACT AUTOMATIC WASHER
Kenmore 11048724790 COMPACT AUTOMATIC WASHER
Kenmore 11048724791 COMPACT AUTOMATIC WASHER
Kenmore 11049182990 AUTOMATIC WASHER
Kenmore 11049182991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11049962600 WASHER
Kenmore 11049962601 RESIDENTIAL WASHER
Kenmore 11049962602 RESIDENTIAL WASHER
Kenmore 11049962603 RESIDENTIAL WASHER
Kenmore 11049972600 RESIDENTIAL WASHER
Kenmore 11049972601 RESIDENTIAL WASHER
Kenmore 11049972602 RESIDENTIAL WASHER
Kenmore 11049972603 RESIDENTIAL WASHER
Kenmore 1105062110 WASHER
Kenmore 110508802 KENMORE ELECTRIC DRYER
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 1105801100 KENMORE WRINGER WASHER
Kenmore 1105801200 KENMORE WRINGER WASHER
Kenmore 1105802301 KENMORE WRINGER WASHER
Kenmore 1105802330 KENMORE WRINGER WASHER
Kenmore 1105802331 KENMORE WRINGER WASHER
Kenmore 1105802400 KENMORE WRINGER WASHER
Kenmore 1105802600 KENMORE WRINGER WASHER
Kenmore 1105802601 KENMORE WRINGER WASHER
Kenmore 1105802700 KENMORE WRINGER WASHER
Kenmore 1105802701 KENMORE WRINGER WASHER
Kenmore 1105802800 KENMORE WRINGER WASHER
Kenmore 1105802801 KENMORE WRINGER WASHER
Kenmore 1105802901 KENMORE WRINGER WASHER
Kenmore 1105802910 KENMORE WRINGER WASHER
Kenmore 1105803000 KENMORE SEMI-AUTOMATIC WASHER
Kenmore 1105804100 KENMORE AUTOMATIC WASHER
Kenmore 1105804200 KENMORE AUTOMATIC WASHER
Kenmore 1105804201 KENMORE AUTOMATIC WASHER
Kenmore 1105804202 KENMORE AUTOMATIC WASHER
Kenmore 1105804203 KENMORE AUTOMATIC WASHER
Kenmore 1105804300 KENMORE AUTOMATIC WASHER
Kenmore 1105804301 KENMORE AUTOMATIC WASHER
Kenmore 1105804302 KENMORE AUTOMATIC WASHER
Kenmore 1105804303 KENMORE AUTOMATIC WASHER
Kenmore 1105804500 KENMORE AUTOMATIC WASHER
Kenmore 1105804501 KENMORE AUTOMATIC WASHER
Kenmore 1105804550 KENMORE AUTOMATIC WASHER
Kenmore 1105804551 KENMORE AUTOMATIC WASHER
Kenmore 1105804700 KENMORE AUTOMATIC WASHER
Kenmore 1105804702 KENMORE AUTOMATIC WASHER
Kenmore 1105804750 KENMORE AUTOMATIC WASHER
Kenmore 1105804752 KENMORE AUTOMATIC WASHER
Kenmore 1105804800 KENMORE AUTOMATIC WASHERS
Kenmore 1105804801 KENMORE AUTOMATIC WASHER
Kenmore 1105804802 KENMORE AUTOMATIC WASHER
Kenmore 1105804803 KENMORE AUTOMATIC WASHER
Kenmore 1105804804 KENMORE AUTOMATIC WASHER
Kenmore 1105804850 KENMORE AUTOMATIC WASHERS
Kenmore 1105804851 KENMORE AUTOMATIC WASHER
Kenmore 1105804852 KENMORE AUTOMATIC WASHER
Kenmore 1105804853 KENMORE AUTOMATIC WASHER
Kenmore 1105804854 KENMORE AUTOMATIC WASHER
Kenmore 1105804950 KENMORE AUTOMATIC WASHER
Kenmore 1105804951 KENMORE AUTOMATIC WASHER
Kenmore 1105804952 KENMORE AUTOMATIC WASHER
Kenmore 1105804953 KENMORE AUTOMATIC WASHER
Kenmore 1105805100 KENMORE AUTOMATIC WASHER
Kenmore 1105805200 KENMORE AUTOMATIC WASHER
Kenmore 1105805201 KENMORE AUTOMATIC WASHER
Kenmore 1105805202 KENMORE AUTOMATIC WASHER
Kenmore 1105805203 KENMORE AUTOMATIC WASHER
Kenmore 1105805300 KENMORE AUTOMATIC WASHER
Kenmore 1105805301 KENMORE AUTOMATIC WASHER
Kenmore 1105805302 KENMORE AUTOMATIC WASHER
Kenmore 1105805303 KENMORE AUTOMATIC WASHER
Kenmore 1105805500 KENMORE AUTOMATIC WASHER
Kenmore 1105805501 KENMORE AUTOMATIC WASHER
Kenmore 1105805550 KENMORE AUTOMATIC WASHER
Kenmore 1105805551 KENMORE AUTOMATIC WASHER
Kenmore 1105805700 KENMORE AUTOMATIC WASHER
  #2 (permalink)
Old 11-12-2013, 11:05 AM
Senior Member
Appliance Ninja is on a distinguished road
Default
If you have replaced the pressure sensor already, the issue lies with the cables from the sensor to the control or the actual control itself. If the cable looks good, the control is likely faulty. If you post the complete model number, I can get you the correct part number.
  #3 (permalink)
Old 11-12-2013, 01:15 PM
Junior Member
Default model #
Kenmore HE5T Model #11047781701
  #4 (permalink)
Old 11-12-2013, 01:21 PM
Senior Member
Default
Thank you! The board I believe you will need to replace (if all connections are verified okay) is available at the link below.
Whirlpool W10157911 Cntrl-Elec - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore HE5T Not Draining Properly GreatBigTuna Washer Repair 2 05-15-2013 05:49 PM
Kenmore Elite HE5T washer F-35 SUD code! pinoyballa316 Washer Repair 1 11-27-2012 01:13 PM
kenmore HE5T ace_numb Washer Repair 3 12-05-2011 10:15 PM
HE5t F11 Error deuce4lsu Washer Repair 3 06-09-2010 09:17 AM
whirpool duet show error msg( FH) mani Washer Repair 2 07-21-2009 06:31 PM
