Discuss
Frustration
 in
Washer Repair
Our washer is not working at all right now, after a few weeks of sometimes working and other times not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frustration
  #1 (permalink)
Old 11-06-2013, 11:06 AM
Junior Member
jeslabich is on a distinguished road
Default Frustration
Model Number: WTW5600XW0   Brand: Whirlpool   Age: 1 - 5 years
Our washer is not working at all right now, after a few weeks of sometimes working and other times not working. Since my husband is an electrician we know it is not an electrical problem, although sometimes when you press power it does nothing. At other times when you press power the start button and minutes button flash but machine does not start. We never see an error code - the machine is just over 3 years old. The lid does lock but then unlocks, and then sometimes locks again. I wonder if we should start by replacing the lid lock but he thinks it might be a control panel. Please help.
Related Models
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
Whirlpool WTW8240YW0 AUTOMATIC WASHER
Whirlpool WTW8600YW0 AUTOMATIC WASHER
Whirlpool WTW8800YC0 WASHER
  #2 (permalink)
Old 11-06-2013, 11:43 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Tilt machine back to retrieve the tech manual from inside the front panel. It will tell you how to get into service mode to check for fault codes and run various tests to try and figure out what's wrong. Sounds like it may be a control board problem. Try reseating all control board wiring connectors as well as connectors at bottom of washer for motor, pump, shift actuator and capacitor. Loose connections and broken wires are very common in these washers. Broken wires are common at wire tie-down points.
Eric
  #3 (permalink)
Old 11-06-2013, 01:26 PM
Junior Member
Default
Quote:
Eric
Why can't I find a control board listed in the parts listing for this model Whirlpool Washer?
  #4 (permalink)
Old 11-06-2013, 03:25 PM
Expert
APP Volunteer
Default
There are two circuit boards, the main control and the user interface. Numbers 3 and 6 on the parts page.
02-Console and Dispenser Parts parts for Whirlpool WTW5600XW0 - AppliancePartsPros.com
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frustration big time mranch Washer Repair 4 07-30-2011 04:11 AM
Tappan frustration Jbud Oven Repair (including Ranges and Cooktops) 0 05-24-2008 07:55 PM
Spin cycle frustration. Council2 Washer Repair 6 12-29-2007 07:59 PM
Dishwasher Frustration! Gerry Dishwasher Repair 1 08-13-2007 01:06 PM
