Discuss
How to replace Main Bearing?
 in
Washer Repair
My washer was making a loud noise when spinning cycle. Then the belt burnt/broke. I replaced the belt. The washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » How to replace Main Bearing?
  #1 (permalink)
Old 11-06-2013, 09:33 AM
Junior Member
ranchero79 is on a distinguished road
Default How to replace Main Bearing?
Model Number: ALW540RAW   Brand: Amana   Age: More than 10 years
My washer was making a loud noise when spinning cycle. Then the belt burnt/broke. I replaced the belt. The washer would not spin unless I helped it by mannually spinning the inner tub to get spin started.
I have removed the outter tub top. I have removed the agitator. I have removed the plug, bolt and drive bell. I have removed a conical rubber seal. This exposed two splines. The taller smaller spline 5/8"OD I think drives the drive bell which drives the agitator. The lower spline 1"OD had a 1 1/2" on flats HEX nut threaded on it. I could not remove nut with a socket and had to cut off with dremel tool and chisel.
Now there is 4 1/2" on flats Hex head bolts on the raised center porton of inner tub. The center assembly has the two concentric splines sticking up.
What parts do I remove and "how" to get to the main bearing?
Related Models
Amana ALW540RAW WASHER-TOP LOADING
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMC WASHER-TOP LOADING
Amana ALW540RMW Washer - Top Loading
Amana ALW540RMW WASHER-TOP LOADING
Amana ALW680RAC WASHER-TOP LOADING
Amana ALW680RAW WASHER-TOP LOADING
Amana ALW780QAC WASHER-TOP LOADING
Amana ALW780QAW WASHER-TOP LOADING
Amana ALW780QMC Washer - Top Loading
Amana ALW780QMC WASHER-TOP LOADING
Amana ALW780QMW Washer - Top Loading
Amana ALW780QMW WASHER-TOP LOADING
Amana ALW880QAC WASHER-TOP LOADING
Amana ALW880QAC1 WASHER-TOP LOADING
Amana ALW880QAW WASHER-TOP LOADING
Amana ALW880QAW1 WASHER-TOP LOADING
Amana ALW891SAW WASHER-TOP LOADING
Amana ALW895SAC WASHER-TOP LOADING
Amana ALW895SAW WASHER-TOP LOADING
Amana ALW990EAC WASHER-TOP LOADING
Amana ALW990EAW WASHER-TOP LOADING
General Electric ALX12AAM1 Room air conditioner
General Electric ALX12DAM1 Room air conditioner
General Electric ALX14AAM1 Room air conditioner
General Electric ALX15DAM1 Room air conditioner
Amana ALY1680ADB RV RANGE- GAS
Amana ALY1680ADQ RV RANGE- GAS
Amana ALY1680ADS RV RANGE- GAS
Amana ALY1680ADW RV RANGE- GAS
Amana ALY1680BDB RV RANGE- GAS
Amana ALY1680BDS RV RANGE- GAS
Amana ALY2280ADB RV RANGE- GAS
Amana ALY2280ADQ RV RANGE- GAS
Amana ALY2280ADS RV RANGE- GAS
Amana ALY2280ADW RV RANGE- GAS
Amana ALY2280BDB RV RANGE- GAS
Maytag ALY2280BDB12 22" GAS RV RANGE SEALED BURNERS
Amana ALY2280BDS RV RANGE- GAS
Maytag ALY2280BDS12 22" GAS RV RANGE SEALED BURNERS
Amana ALY2289ADB RV RANGE- GAS
Amana ALY2289BDB RV RANGE- GAS
Amana ALZ8580ADB RV SURFACE UNIT- GAS
Maytag ALZ8580ADB14 22" GAS RV COOKTOP SEALED BURNERS
Amana ALZ8580ADQ RV SURFACE UNIT- GAS
Amana ALZ8580ADS RV SURFACE UNIT- GAS
Maytag ALZ8580ADS14 22" GAS RV COOKTOP SEALED BURNERS
Amana ALZ8580ADW RV SURFACE UNIT- GAS
Amana ALZ8589ADB RV SURFACE UNIT- GAS
Amana ALZ8590ADB RV SURFACE UNIT- GAS
Amana ALZ8590ADS RV SURFACE UNIT- GAS
Bosch AM040-00
Frigidaire AM08B4ERBA Gib(v2) / Room Air Conditioner
Frigidaire AM08B4ESBA Gib(v1) / Room Air Conditioner
Frigidaire AM08B5EVA Gib(v1) / Room Air Conditioner
Frigidaire AM08B6ESBA Gib(v2) / Room Air Conditioner
Frigidaire AM08B6ESBB Gib(v1) / Room Air Conditioner
Frigidaire AM09C4EYA Gib(v1) / Room Air Conditioner
Frigidaire AM09C4EZA Gib(v1) / Room Air Conditioner
Frigidaire AM09C5EWA Gib(v1) / Room Air Conditioner
Frigidaire AM09C5EWB Gib(v1) / Room Air Conditioner
Frigidaire AM09C6EVA Gib(v1) / Room Air Conditioner
Frigidaire AM09C6EVA1 Gib(v1) / Room Air Conditioner
Frigidaire AM10C4ERBA Gib(v1) / Room Air Conditioner
Frigidaire AM10C4ESBA Gib(v3) / Room Air Conditioner
Frigidaire AM10C4ESBB Gib(v4) / Room Air Conditioner
Frigidaire AM10C4ETBA Gib(v1) / Room Air Conditioner
Frigidaire AM10C5EYA Gib(v1) / Room Air Conditioner
Frigidaire AM10C5EYB Gib(v2) / Room Air Conditioner
Frigidaire AM10C6ERBA Gib(v3) / Room Air Conditioner
Frigidaire AM10C6ESBA Gib(v5) / Room Air Conditioner
Frigidaire AM10C6ETBA Gib(v1) / Room Air Conditioner
Frigidaire AM10C6EYA Gib(v1) / Room Air Conditioner
Frigidaire AM10C6EYB Gib(v2) / Room Air Conditioner
Frigidaire AM11C4EVA Gib(v1) / Room Air Conditioner
Frigidaire AM11C4EWA Gib(v1) / Room Air Conditioner
Frigidaire AM11C4EWB Gib(v1) / Room Air Conditioner
Frigidaire AM11C6EVA Gib(v1) / Air Conditioner
Frigidaire AM11E7EYA Gib(v1) / Room Air Conditioner
Frigidaire AM12C4EYA Gib(v1) / Room Air Conditioner
Frigidaire AM12C5EVA Gib(v1) / Room Air Conditioner
Frigidaire AM12C5EWA Gib(v1) / Room Air Conditioner
Frigidaire AM12C5EYA Gib(v1) / Room Air Conditioner
Frigidaire AM12C6ESBA Gib(v6) / Room Air Conditioner
Frigidaire AM12C6ESBB Gib(v7) / Room Air Conditioner
Frigidaire AM12C6ESBC Gib(v2) / Room Air Conditioner
Frigidaire AM12C6ESBD Gib(v3) / Room Air Conditioner
Frigidaire AM12E4EVA Gib(v1) / Room Air Conditioner
Frigidaire AM12E7EVA Gib(v1) / Air Conditioner
Frigidaire AM16E4RTBA Gib(v1) / Room Air Conditioner
Whirlpool AMB750WP01 Compactors
Whirlpool AMB7552 TRASH MASHER COMPACTOR
Whirlpool AMB7554 TRASH MASHER COMPACTOR
Amana AMC2206BAB MWAVE- CNTRTP / STAND ALONE
Maytag AMC2206BAB15 COUNTERTOP MICROWAVE 2.0 CU. FT.
Amana AMC2206BAS MWAVE- CNTRTP / STAND ALONE
Maytag AMC2206BAS15 COUNTERTOP MICROWAVE 2.0 CU. FT.
Amana AMC2206BAW MWAVE- CNTRTP / STAND ALONE
Maytag AMC2206BAW15 COUNTERTOP MICROWAVE 2.0 CU. FT.
Amana AMC4080AAB MWAVE- CNTRTP / STAND ALONE
Maytag AMC4080AAB14 COUNTERTOP MICROWAVE 0.8 CU. FT.
Amana AMC4080AAS MWAVE- CNTRTP / STAND ALONE
Maytag AMC4080AAS14 COUNTERTOP MICROWAVE 0.8 CU. FT.
Amana AMC4080AAW MWAVE- CNTRTP / STAND ALONE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing main bearing in drive Chrisrad Washer Repair 0 01-05-2012 08:26 PM
spin main bearing change DONGINS Washer Repair 0 08-07-2011 08:38 PM
Blown Main Bearing Schnieder Washer Repair 6 07-23-2010 12:14 PM
Leaking tib at the main bearing jkl Washer Repair 2 02-08-2008 05:56 PM
installing the Assy, main bearing jdouglas14 Washer Repair 4 12-03-2007 05:33 PM
