Discuss
draining residual water from washing machine in order to move it
 in
Washer Repair
I have a 2003 maytag neptune (front loading) washing machine. The bearing/s have gone bad and I need to move
Appliance Repair Forum > Appliance Repair Help > Washer Repair » draining residual water from washing machine in order to move it
  #1 (permalink)
Old 10-13-2009, 09:14 AM
Junior Member
grannybananny99 is on a distinguished road
Smile draining residual water from washing machine in order to move it
Brand: Maytag   Age: 5 - 10 years
I have a 2003 maytag neptune (front loading) washing machine. The bearing/s have gone bad and I need to move it to make way for a new LG. There is still water left in (for balance?) and I'd like to know how to get it out of there so it won't be so heavy to move.
  #2 (permalink)
Old 10-13-2009, 09:27 AM
Junior Member
cooltech is on a distinguished road
Default
If you have a Shop-Vac, you can use it to drain the water. Pull out the drain hose to the washing machine, stick your shop-vac suction hose into the drain hose, seal your hand around the drain hose and turn on the shop-vac. It will suck most of the water out of the washer. You may have to empty the shop-vac several times depending on how much water is in the washer.
  #3 (permalink)
Old 10-13-2009, 09:31 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Even better: Remove the drain hose from the stand pipe and let it go below the level of the machine tub. The water inside will siphon out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine wont move to next cycle RVONSTEIN Washer Repair 3 02-10-2010 03:58 PM
washing machine not draining properly htuttle Washer Repair 1 05-31-2009 12:01 PM
Washing Machine--No spinning while draining david moes Washer Repair 0 07-05-2008 09:06 AM
Residual Water Brandon Washer Repair 1 03-07-2008 12:43 PM
GE washing machine not draining balbir Washer Repair 0 10-30-2007 03:02 PM
