Discuss
Pin Missing from Perfectemp water select switch
 in
Washer Repair
Hi, No Hot water, turns out that a pin in the circuit board for that switch is missing, there is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Pin Missing from Perfectemp water select switch
  #1 (permalink)
Old 10-31-2013, 01:34 PM
Junior Member
SteveMack is on a distinguished road
Default Pin Missing from Perfectemp water select switch
Model Number: wjre5550k2www   Brand: GE   Age: 1 - 5 years
No Hot water, turns out that a pin in the circuit board for that switch is missing, there is an empty hole there with some solder there.
I put in service mode and the water valve works hot and cold.
Can someone check to see if yours is missing that pin, it is on R154 of the board I believe, it is very noticeable.
The new board is 125.00, this machine is only about 3 years old.
Also have any of you repaired a missing pin??? in one of these switches,
I didn't get a real good look at the switch but if I can re-solder in a pin or if it is just a Drop solder with no pin then I can probably re-solder it
Related Models
General Electric WJRE5550K3WW WASHER
General Electric WJRR4170E0CC Washer
General Electric WJRR4170E0WW Washer
General Electric WJRR4170E1CC Washer
General Electric WJRR4170E1WW Washer
General Electric WJRR4170E3CC Washer
General Electric WJRR4170E3WW Washer
General Electric WJRR4170E4CC Washer
General Electric WJRR4170E4WW Washer
General Electric WJRR4170E5CC Washer
General Electric WJRR4170E5WW Washer
General Electric WJRR4170E6CC Washer
General Electric WJRR4170E6WW Washer
General Electric WJRR4170G0WW Washer
General Electric WJRR4170G1WW WASHER
General Electric WJRR4170G2WW WASHER
General Electric WJRR4170G3WW WASHER
General Electric WJRR4170G4WW WASHER
General Electric WJRR4170G5WW WASHER
General Electric WJRR4170G6WW WASHER
General Electric WJSE3110A0AA Washer
General Electric WJSE3110A0CC Washer
General Electric WJSE3110A0WW Washer
General Electric WJSE3110A2CC Washer
General Electric WJSE3110A2WW Washer
General Electric WJSE4150B0CC Washer
General Electric WJSE4150B0WW Washer
General Electric WJSE4150B1CC Washer
General Electric WJSE4150B1WW Washer
General Electric WJSE4150B2CC Washer
General Electric WJSE4150B2WW Washer
General Electric WJSE4150B3CC Washer
General Electric WJSE4150B3WW Washer
General Electric WJSR1070A1AA Washer
General Electric WJSR1070A1CC Washer
General Electric WJSR1070A1WW Washer
General Electric WJSR1070A2AA Washer
General Electric WJSR1070A2WW Washer
General Electric WJSR2070B0CC Washer
General Electric WJSR2070B0WW Washer
General Electric WJSR2070B2CC Washer
General Electric WJSR2070B2WW Washer
General Electric WJSR2070B3CC Washer
General Electric WJSR2070B3WW Washer
General Electric WJSR2070B4CC Washer
General Electric WJSR2070B4WW Washer
General Electric WJSR2070B9WW WASHER
General Electric WJSR2070D0WW Washer
General Electric WJSR2070D1WW Washer
General Electric WJSR2070D2WW Washer
General Electric WJSR2070D3WW Washer
General Electric WJSR2070D5WW Washer
General Electric WJSR2070D6WW Washer
General Electric WJSR2080T2AA Washer
General Electric WJSR2080T2WB Washer
General Electric WJSR2080T2WW Washer
General Electric WJSR2080T3AA Washer
General Electric WJSR2080T3WB Washer
General Electric WJSR2080T3WW Washer
General Electric WJSR2080T5AA Washer
General Electric WJSR2080T5WB Washer
General Electric WJSR2080T5WW Washer
General Electric WJSR2080T6AA Washer
General Electric WJSR2080T6WB Washer
General Electric WJSR2080T6WW Washer
General Electric WJSR2080T8AA Washer
General Electric WJSR2080T8WB Washer
General Electric WJSR2080T8WW Washer
General Electric WJSR2080TAAA Washer
General Electric WJSR2080TAWB Washer
General Electric WJSR2080TAWW Washer
General Electric WJSR2080V1AA Washer
General Electric WJSR2080V1WW Washer
General Electric WJSR2080V2AA Washer
General Electric WJSR2080V2WW Washer
General Electric WJSR2080V3AA Washer
General Electric WJSR2080V3WW Washer
General Electric WJSR4160D0CC Washer
General Electric WJSR4160D0WW Washer
General Electric WJSR4160D2CC Washer
General Electric WJSR4160D2WW Washer
General Electric WJSR4160D5CC Washer
General Electric WJSR4160D5WW Washer
General Electric WJSR4160D6CC Washer
General Electric WJSR4160D6WW Washer
General Electric WJSR4160DACC Washer
General Electric WJSR4160DAWW Washer
General Electric WJSR4160DCCC Washer
General Electric WJSR4160DCWW Washer
General Electric WJSR4160G0WW Washer
General Electric WJSR4160G1WW WASHER
General Electric WJSR4160G2WW WASHER
General Electric WJSR4160G3WW WASHER
General Electric WJSR4160G4WW WASHER
General Electric WJSR4160G5WW WASHER
General Electric WJSR4160G6WW WASHER
General Electric WJXR2080T2AA Washer
General Electric WJXR2080T2WW Washer
General Electric WJXR2080T3AA Washer
General Electric WJXR2080T3WW Washer
General Electric WJXR2080T5AA Washer
General Electric WJXR2080T5WW Washer
General Electric WJXR2080T6AA Washer
General Electric WJXR2080T6WW Washer
General Electric WJXR2080T8AA Washer
General Electric WJXR2080T8WW Washer
General Electric WJXR2080TAAA Washer
General Electric WJXR2080TAWW Washer
General Electric WJXR2080V0AA Washer
General Electric WJXR2080V0WW Washer
Whirlpool WKP85800 30" ELECTRIC RANGE CERAN COOKTOP
General Electric WKRE5500K0WW WASHER
General Electric WKRE5550K0WW WASHER
General Electric WKRE6280D0WW Washer
General Electric WKRE6280D1WW Washer
General Electric WKRE6280DCWW Washer
General Electric WKSE5260E0WW Washer
General Electric WKSE5260E1WW Washer
General Electric WKSE5260E6WW Washer
General Electric WKSE6280B1WW Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
program select/time select - clock does not work DEAN DAGGETT Oven Repair (including Ranges and Cooktops) 1 04-29-2013 03:08 PM
Simmer Select Switch BenN Oven Repair (including Ranges and Cooktops) 0 03-22-2011 12:15 PM
Water tube to ice maker missing? Poenella Refrigerator & Freezer Repair 3 02-21-2011 10:14 AM
GE Cooktop - Heat Switch + Select Switch dtshenoy Oven Repair (including Ranges and Cooktops) 3 06-06-2009 03:14 PM
simmer select switch won't work jollyboat Oven Repair (including Ranges and Cooktops) 1 03-17-2009 05:36 PM
