Register | FAQ's | New Posts | Today's Posts | Extras |
» duet Washing machine |
![]() Model Number: GHW9400PW4 Brand: Whirlpool Age: 5 - 10 years
![]() Hi, I go directly to the point. My duet washing machine stuck on C05 when at test mode. Check Amp at the heater = 7.9 Amp. 120 Volt at the heater, heater ohm at 15 Ohm, NTC sensor test at 5,6 K Ohm with water in the tub, NTC test 10 K ohm at room temp. Took the NTC Outdoor in cold temp. and show 13 K Ohm. Clean the NTC... But still the machine refused to go on with the test mode. Check the continuity of NTC wires to the CCU Ok. I'm confused now!!! if I try to check the OHM at the NTC with my tester directly to the circuit then the machine set to C06, the heater go to 0 Amp. and machine go to the end of test mode cycle... drain, spin ok I am a bit lost and don t know what could be wrong... Any suggestion Thks Related Models Last edited by Tony45 : 10-30-2013 at 01:00 PM. |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Whirlpool Duet Washing Machine | tgoins77 | Washer Repair | 2 | 12-25-2011 10:57 PM |
Whirlpool Duet Steam Washing Machine | sjmeyers | Washer Repair | 0 | 07-09-2011 01:01 PM |
Washing Machine - Whirlpool HT duet | kjms41 | Washer Repair | 1 | 03-10-2011 06:37 PM |
Control panel duet washing machine | stevez | Washer Repair | 0 | 05-09-2008 11:37 AM |
Duet Washing machine no lights | Derek | Washer Repair | 0 | 07-25-2007 05:49 AM |
