Discuss
Roper Washer RAS7133KQ1
 in
Washer Repair
Replaced lid switch. Now will not rinse. Washes- drains- spins. cold/cold doesn't work, hot-warm/cold are only cold. Related Models Frigidaire
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper Washer RAS7133KQ1
  #1 (permalink)
Old 10-30-2013, 02:21 AM
Junior Member
dexter43 is on a distinguished road
Default Roper Washer RAS7133KQ1
Model Number: Roper Washer RAS7133KQ1   Brand: Roper   Age: 5 - 10 years
Related Models
Frigidaire RP13M2WS2B Gib(v4) / Top Mount Refrigerator
Frigidaire RP13M2WS2C Gib(v5) / Top Mount Refrigerator
Frigidaire RP13M2WS2D Gib(v6) / Top Mount Refrigerator
Amana RR MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1 RANGE- S/C S/I DDRAFT GAS
Amana RR-10 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1000 RANGE- S/C S/I DDRAFT GAS
Amana RR-1000 MWAVE- CNTRTP / STAND ALONE
Amana RR-1010 RANGE- S/C S/I DDRAFT GAS
Amana RR-1010 MWAVE- CNTRTP / STAND ALONE
Amana RR-10A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-10A MWAVE- CNTRTP / STAND ALONE
Amana RR-1110 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1225 MWAVE- CNTRTP / STAND ALONE
Amana RR-3H RANGE- S/C S/I DDRAFT GAS
Amana RR-4 RANGE- S/C S/I DDRAFT GAS
Amana RR-4D RANGE- S/C S/I DDRAFT GAS
Amana RR-4DW RANGE- S/C S/I DDRAFT GAS
Amana RR-5B MWAVE- CNTRTP / STAND ALONE
Amana RR-7 RANGE- S/C S/I DDRAFT GAS
Amana RR-700 RANGE- S/C S/I DDRAFT GAS
Amana RR-700 MWAVE- CNTRTP / STAND ALONE
Amana RR-7A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-7B MWAVE - FAMILY SIZE (60 HZ)
Amana RR-7B MWAVE- CNTRTP / STAND ALONE
Amana RR-7D RANGE- S/C S/I DDRAFT GAS
Amana RR-7DA MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-800 MWAVE- CNTRTP / STAND ALONE
Amana RR-810 MWAVE- CNTRTP / STAND ALONE
Amana RR-810 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-820 MWAVE- CNTRTP / STAND ALONE
Amana RR-8A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8B MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8T MWAVE- CNTRTP / STAND ALONE
Amana RR-8TC MWAVE- CNTRTP / STAND ALONE
Amana RR-9 RANGE- S/C S/I DDRAFT GAS
Amana RR-900 MWAVE- CNTRTP / STAND ALONE
Amana RR-910 RANGE- S/C S/I DDRAFT GAS
Amana RR-910 MWAVE- CNTRTP / STAND ALONE
Amana RR-9T MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TA MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TA MWAVE- CNTRTP / STAND ALONE
Amana RR-9TB MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TB MWAVE- CNTRTP / STAND ALONE
Amana RR-II RANGE- S/C S/I DDRAFT GAS
Amana RR1020 MWAVE- CNTRTP / STAND ALONE
Amana RR1220 MWAVE- CNTRTP / STAND ALONE
Amana RR2 MWAVE- CNTRTP / STAND ALONE
Amana RR510 MWAVE- CNTRTP / STAND ALONE
Amana RR510A MWAVE- CNTRTP / STAND ALONE
Amana RR52 MWAVE - FAMILY SIZE (60 HZ)
Amana RR54 MWAVE - FAMILY SIZE (60 HZ)
Amana RR54D MWAVE- CNTRTP / STAND ALONE
Amana RR56 MWAVE- CNTRTP / STAND ALONE
Amana RR57D MWAVE- CNTRTP / STAND ALONE
Amana RR59T MWAVE- CNTRTP / STAND ALONE
Amana RR6W MWAVE- CNTRTP / STAND ALONE
Amana RR7 MWAVE- CNTRTP / STAND ALONE
Amana RR720 MWAVE- CNTRTP / STAND ALONE
Amana RR9 MWAVE- CNTRTP / STAND ALONE
Amana RR920 MWAVE- CNTRTP / STAND ALONE
Amana RRC57D MWAVE- CNTRTP / STAND ALONE
Amana RRH-10 MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10A MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10A MWAVE- CNTRTP / STAND ALONE
Amana RRL-10C MWAVE- CNTRTP / STAND ALONE
Amana RRL-10TD MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10TD MWAVE- CNTRTP / STAND ALONE
Amana RRL-10XA MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5C MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5D MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5D MWAVE- CNTRTP / STAND ALONE
Amana RRL-7C MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-7C MWAVE- CNTRTP / STAND ALONE
Amana RRL-8T MWAVE- CNTRTP / STAND ALONE
Amana RRL-8TC MWAVE- CNTRTP / STAND ALONE
Amana RRL-8TD MWAVE - FAMILY SIZE (60 HZ)
  #2 (permalink)
Old 10-30-2013, 07:21 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
So, rinse was fine before replacing lid switch? By no rinse, you mean it won't fill on rinse? Your symptoms don't make sense. Rinse is cold water only so if cold water isn't working, you wouldn't get cold water in wash cycle when set for hot or warm. Make sure water supply hoses are connected correctly and that you have hot and cold water (run each hose directly into tub to check).
Eric
  #3 (permalink)
Old 10-30-2013, 12:00 PM
Junior Member
Default Yes very strange
Yes very strange. What prompted the switch was that I ran a load and it stopped on the first cycle, it filled-agitated then would not drain or spin, moving the timer pasted rinse to spin didn't work, so new switch. Now it fills and agitates will drain and spin but it stops on the first cycle. Moving the timer to last spin it will spin no rinse. Also the hoses are correct and the water is hot at spout, cold/cold doesn't work but all other setting do, warn-hot but water is cold.
  #4 (permalink)
Old 10-30-2013, 04:07 PM
Expert
APP Volunteer
Default
Well, it makes no sense. I'd say you have a bad cold water valve solenoid since rinse is cold only and you say cold/cold doesn't work but if that is the case, where are you getting cold water when you've selected warm or hot??? This washer does not have an electronic auto temp control, it's a simple manual mechanical switch. Swap the water valve solenoid valve connectors and try rinse cycle again. If you get water, your inlet valve is bad.
http://www.appliancepartspros.com/wh...ap3094541.html
Eric
  #5 (permalink)
Old 10-30-2013, 11:40 PM
Junior Member
Default Out fox the machine? not.
Yes, interesting to out fox the machine. I turned the hot water spigot off as it wasn't doing anything { has a small intermittent drip changed the washer but still drips, it is old, I'm going to replace with braided ones}and the situation is the same, the water selector works every where but on the cold/cold. Nothing got disconnected and had hot/warn water before when I replaced the lid switch so I 'm thinking it is the solenoid.
Thanks so much for the input, I founded and ran a shop for 30 years that I sold in 07 to a former employee, I was always welling to participate with my customers and detail the job and supply first quality A-1 materials also that they needed to do the work, 98 percent after a clear explanation of what was required told me to do the work, of the other 2 percent more than half return to do the same.
Most people ignore Newton's third law of motion, for every action there is an equal and opposite reaction, what you put out comes back to you, in the scriptures seven fold.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Washer tomanypups1 Washer Repair 4 05-03-2013 12:34 PM
Roper washer Needs Help shane k Washer Repair 2 11-02-2012 06:24 PM
roper Washer Fly away Washer Repair 0 09-06-2012 05:31 AM
need help with roper washer mrbreezio Washer Repair 1 01-23-2012 06:30 PM
roper washer michelle whelan Washer Repair 2 02-24-2009 04:41 PM
