I replaced the clutch a couple months ago and the last 2 weeks when it spins on high it has a loud grinding sound. I took it apart the other night to check what was grinding and didn't see anything. Put it all back together and it filled but wouldn't spin. I couldn't move the basket by hand and the agitator wouldn't spin. It smelled like burning wires but no smoke. Pulled it all apart and the shaft out of the gearbox wouldn't move. I took the gear box apart, put back together and it would move then lock up again. I can't get it to spin or agitate. The motor is running because it drains water but nothing else. I didn't see anything broken in the gearbox and made sure it was put back together. Any suggestions?
