Discuss
Jenn-Air washer not rinsing/spinning on normal cycle
 in
Washer Repair
I have a Jenn-Air washer (model JW1000W--serial number starts with 14) that is not going through the cycles correctly anymore.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Jenn-Air washer not rinsing/spinning on normal cycle
  #1 (permalink)
Old 10-28-2013, 03:18 AM
Junior Member
kmom is on a distinguished road
Default Jenn-Air washer not rinsing/spinning on normal cycle
Model Number: JW1000W   Brand: Jenn-Air   Age: More than 10 years
I have a Jenn-Air washer (model JW1000W--serial number starts with 14) that is not going through the cycles correctly anymore. The timer will advance and there is the normal timer ticking noise, but the washer will not drain/spin on its own when I use the Normal cycle. The cycle will be "done" and the tub will be full of water.
I have been doing my laundry by setting the timer to the normal cycle. When the cycle should be agitating, I tug on the timer a bit to get it to agitate. Then I manually change to the Permanent Press cycle spin setting to get it to drain. Then I set the timer to the Permanent Press rinse cycle to rinse/drain. I cannot do this with the normal cycle, because it does not rinse or spin when I select the rinse or spin settings there. The Permanent Press cycle might work because nothing can be worn out on that cycle, since I have never used it prior to this problem occurring.
I don't think it is the lid switch, because every time I lift the lid, the washer will immediately stop spinning. I have done this numerous times, always with the same result. I also hear a click when the lid switch is depressed.
I could not figure out how to remove the old timer. I removed the timer handle (the part that you push in/pull out when doing laundry). I couldn't figure out how to remove the circular piece that is on the outside of the washer behind that part, however. Is there a clip of some sort holding this piece in? I didn't want to force it off, because I was afraid of breaking it, and I need my washer to work while I am figuring this problem out.
There were a lot of wires in the back going into the timer. I am assuming you just push in on the connector tabs in order to release them. Am I correct?
Also, should there be styrofoam behind the timer? Service was done on our washer less than two months after we bought it new, and I was told the "motor guard burned out." I'm not sure if that is part of the timer or not. I just noticed the styrofoam when I was looking for the timer part number. The styrofoam is behind the circular piece (behind the handle) that I cannot figure out how to remove.
Do you think I need to replace the timer (part number 35-5027 is written on the timer), or could it be something else? I don't want to spend over $100 on a timer if the problem could be something else.
Related Models
Jenn-Air JW1000W WASHER-TOP LOADING
Amana JW1008.000 COMMERCIAL MICROWAVES
Amana JW1008.100 COMMERCIAL MICROWAVES
Amana JW1008.200 COMMERCIAL MICROWAVES
Amana JW1008.A COMMERCIAL MICROWAVES
Amana JW1008.B COMMERCIAL MICROWAVES
Amana JW1040.000 COMMERCIAL MICROWAVES
Amana JW1040.100 COMMERCIAL MICROWAVES
Amana JW1040.200 COMMERCIAL MICROWAVES
Amana JW1040.A COMMERCIAL MICROWAVES
Amana JW1040.B COMMERCIAL MICROWAVES
Jenn-Air JW2000A WASHER-TOP LOADING
Jenn-Air JW2000W WASHER-TOP LOADING
Jenn-Air JW3000A WASHER-TOP LOADING
Jenn-Air JW3000W WASHER-TOP LOADING
Whirlpool JWARG469WP00 REFRIGERATOR
Whirlpool JWARG475D00 TOP MOUNT REFRIGERATOR
Whirlpool JWARG475WP00 REFRIGERATOR
Whirlpool JWARG475WP01 TOP MOUNT REFRIGERATOR
Whirlpool JWARG480PW01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool JWARG481PW01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool JWARG482WP01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool JWARG483WP01 SIDE-BY-SIDE REFRIGERATOR
Jenn-Air JWC2450ACX WINE CELLAR / UNDER COUNTER REF
Jenn-Air JWC2450ARB WINE CELLAR / UNDER COUNTER REF
Jenn-Air JWC2450ARS WINE CELLAR / UNDER COUNTER REF
Jenn-Air JWC2450ARW WINE CELLAR / UNDER COUNTER REF
Jenn-Air JWCG5 WINE CELLAR / UNDER COUNTER REF
Maytag JWD2030WS00 30" ELECTRIC BUILT-IN WARMING DRAWER
Maytag JWD2030WX00 30" ELECTRIC BUILT-IN WARMING DRAWER
Maytag JWD2130WB00 30" ELECTRIC BUILT-IN WARMING DRAWER
Maytag JWD2130WP00 30" ELECTRIC BUILT-IN WARMING DRAWER
Maytag JWD2130WR00 30" ELECTRIC BUILT-IN WARMING DRAWER
Maytag JWD2130WW00 30" ELECTRIC BUILT-IN WARMING DRAWER
Jenn-Air JWD6030CDX MISC / ACCESSORY
Jenn-Air JWD6130DDB MISC / ACCESSORY
Jenn-Air JWD6130DDS MISC / ACCESSORY
Jenn-Air JWD6130DDW MISC / ACCESSORY
Jenn-Air JWD7030CDX MISC / ACCESSORY
Jenn-Air JWD7130CDB MISC / ACCESSORY
Jenn-Air JWD7130CDP MISC / ACCESSORY
Jenn-Air JWD7130CDS MISC / ACCESSORY
Jenn-Air JWD7130CDW MISC / ACCESSORY
Jenn-Air JWD7130DDB MISC / ACCESSORY
Jenn-Air JWD7130DDP MISC / ACCESSORY
Jenn-Air JWD7130DDS MISC / ACCESSORY
Jenn-Air JWD7130DDW MISC / ACCESSORY
Jenn-Air JWD7530CDX MISC / ACCESSORY
Whirlpool JWKGN700001 SIDE-BY-SIDE REFRIGERATOR
Whirlpool JWP21000 Laundry Centers
Whirlpool JWP21080 Laundry Centers
Whirlpool JWRZ2727FI00 SIDE-BY-SIDE REFRIGERATOR
General Electric JX27*01 Electric range
General Electric JX27002 Electric range
General Electric JX27R01 Electric range
General Electric JX65001 Electric range
General Electric JX65002 Electric range
General Electric JX81 Counter top microwave
General Electric JX81A GE OVER-THE-RANGE MICROW
General Electric JX90001 Electric range
General Electric JX97001 Electric range
General Electric JX97002 Electric range
General Electric JXA040 Gas range
General Electric JXA041 Gas range
General Electric JXA070 Gas range
Jenn-Air JXA1027ADB MISC / ACCESSORY
Jenn-Air JXA1027ADQ MISC / ACCESSORY
Jenn-Air JXA1027ADS MISC / ACCESSORY
Jenn-Air JXA1027ADW MISC / ACCESSORY
Jenn-Air JXA1030ADB MISC / ACCESSORY
Jenn-Air JXA1030ADQ MISC / ACCESSORY
Jenn-Air JXA1030ADS MISC / ACCESSORY
Jenn-Air JXA1030ADW MISC / ACCESSORY
Jenn-Air JXA9001CDP HOOD
Jenn-Air JXA9002CDP HOOD
Jenn-Air JXA9003CDP HOOD
Jenn-Air JXA9030CDP HOOD
Jenn-Air JXA9036CDP HOOD
Jenn-Air JXA9048CDP HOOD
Jenn-Air JXA9130AAP MISC / ACCESSORY
General Electric JXDC41001
General Electric JXDC41001BC Electric range
General Electric JXDC410K1 Electric range
General Electric JXDC410N1 Electric range
General Electric JXDC410N3BC Electric range
General Electric JXDC430R2BL Electric range
General Electric JXDC440R2WH Electric range
General Electric JXDD43001 Electric range
General Electric JXDD430N1 Electric range
General Electric JXDD44 Electric range
General Electric JXDD46101 Electric range
General Electric JXDD461N1 Electric range
General Electric JXDL44001 Electric range
General Electric JXDL440K1 Electric range
General Electric JXDL440N1 Electric range
General Electric JXDL45101 Electric range
General Electric JXDL451N1 Electric range
General Electric JXDL47001 Electric range
General Electric JXDL470N1 Electric range
General Electric JXDL491N1 Electric range
General Electric JXDM2 Electric range
General Electric JXDR47 Electric range
General Electric JXDR48 Electric range
General Electric JXDR49 Electric range
General Electric JXDR50 Electric range
General Electric JXDR50V1B RADIANT MODULE
General Electric JXDR50V1C RADIANT MODULE
General Electric JXDR50V1W RADIANT MODULE
Maytag JXDR7301VS0 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM
Maytag JXDR7301VS1 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM
Maytag JXDR7361VS0 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM
Maytag JXDR7361VS1 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM
General Electric JXDS42001
General Electric JXDS42001BC Electric range
General Electric JXDS420K1 Electric range
General Electric JXDS420N1 Electric range
General Electric JXDS430R1BL Electric range
General Electric JXDS440R1WH Electric range
General Electric JXDS48 ELECTRIC RANGE
General Electric JXDS48101 Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 800 washer rinsing during final spin cycle?? Sirfixalot Washer Repair 1 03-22-2013 11:12 AM
Jenn Air Pro not rinsing, missing part? Guillemot Dishwasher Repair 1 05-09-2011 08:08 AM
Washing Machine is not rinsing and spinning meliss Washer Repair 0 07-05-2010 03:11 PM
GE washer WDSR2080D8WW not spinning or rinsing. 1FAST12R Washer Repair 5 05-13-2009 01:06 PM
Dish washer flashing on normal cycle mike112 Dishwasher Repair 1 05-10-2008 05:41 PM
