Discuss
Estate by Whirlpool Won't Spin, Just Buzzes
 in
Washer Repair
Hello, I've browsed through a lot of forums on this site and others, and I can't find an exact replica
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Estate by Whirlpool Won't Spin, Just Buzzes
  #1 (permalink)
Old 10-26-2013, 11:17 AM
Junior Member
Thundersloth is on a distinguished road
Question Estate by Whirlpool Won't Spin, Just Buzzes
Model Number: ETW4400WQ1   Brand: Estate   Age: 1 - 5 years
Hello,
I've browsed through a lot of forums on this site and others, and I can't find an exact replica and solution to the problem I'm having.
I was washing a load of clothes, and when the washer got to the spin cycle, there was a loud buzzing sound (kind of like what electric hair clippers sound like when turned on), and the spin cycle stopped. I was left with wet clothes and a washer half full of water.
I drained the water and got the clothes out, and went to work on the washer. I read somewhere that it might just need a reset, so I unplugged it, let it sit, plugged it back in and then opened and closed the lid 12 times within a minute. From there I was able to get it to spin again. But when I close the lid and try to spin again, it just sits there and buzzes. It will eventually stop buzzing after a while and then I can't get it to do anything without unplugging it, waiting, and plugging it back in, but then I just get a buzz.
I took the case off the washer and checked all the parts I could access. I was able to turn the coupler and make the shaft move, but I really don't know what else I can look for down there. Everything is relatively new and clean, and I just don't have the expertise to know what to look for.
TL;DR - Washer won't spin, just buzzes. Would spin one time, but wouldn't after I closed the lid again.
Related Models
 ETW4400WQ1 AUTOMATIC WASHER
 ETW4400XQ0 AUTOMATIC WASHER
 ETW4450TQ0 AUTOMATIC WASHER
Bosch EU010-000
Amana EU12F FREEZER- VERTICAL
Amana EU13K FREEZER- VERTICAL
Amana EU13K-A FREEZER- VERTICAL
Amana EU13K-AG FREEZER- VERTICAL
Amana EU13K-C FREEZER- VERTICAL
Amana EU13K-L FREEZER- VERTICAL
Amana EU15F FREEZER- VERTICAL
Amana EU16K FREEZER- VERTICAL
Amana EU16K-A FREEZER- VERTICAL
Amana EU16K-AG FREEZER- VERTICAL
Amana EU16K-C FREEZER- VERTICAL
Amana EU16K-L FREEZER- VERTICAL
Amana EU18F FREEZER- VERTICAL
Amana EU18K FREEZER- VERTICAL
Amana EU18K-A FREEZER- VERTICAL
Amana EU18K-AG FREEZER- VERTICAL
Amana EU18K-C FREEZER- VERTICAL
Amana EU18K-L FREEZER- VERTICAL
Amana EU80/46.B00 COMMERCIAL MICROWAVES
Amana EU80/55.302 COMMERCIAL MICROWAVES
Amana EU80/55.B00 COMMERCIAL MICROWAVES
Amana EU80/55.B01 COMMERCIAL MICROWAVES
Amana EU80/56.300 COMMERCIAL MICROWAVES
Amana EU80/56.301 COMMERCIAL MICROWAVES
Amana EU80/56.302 COMMERCIAL MICROWAVES
Whirlpool EUC050A1
Amana EUT1B1 COMMERCIAL MICROWAVES
Whirlpool EV040FXAW0 Freezers*
Whirlpool EV040FXAW00 FREEZER
Whirlpool EV040FXDW00 FREEZERS
Whirlpool EV040FXHW FREEZER
Whirlpool EV040FXHW00 VERTICAL FREEZER
Whirlpool EV060FXTN00 Freezers*
Whirlpool EV070FXRQ00 VERTICAL FREEZER
Whirlpool EV070FXRQ01 VERTICAL FREEZER
Whirlpool EV090FXKN2 Freezers*
Whirlpool EV090FXKN3 Freezers*
Whirlpool EV090FXKN5 Freezers*
Whirlpool EV090FXPN5 Freezers*
Whirlpool EV090FXSN00 Freezers*
Whirlpool EV110CXRW0 Freezers*
Whirlpool EV110CXRW1 Freezers*
Whirlpool EV110CXSW00 Freezers*
Whirlpool EV110CXWW00 Freezers*
Whirlpool EV110FXVN00
Whirlpool EV110FXVW00 Freezers*
Whirlpool EV120FXAN00 Freezers*
Whirlpool EV120FXDN00 UPRIGHT FREEZER
Whirlpool EV120FXDN01 UPRIGHT FREEZER
Whirlpool EV120FXEN00 UPRIGHT FREEZER
Whirlpool EV120FXEN01 UPRIGHT FREEZER
Whirlpool EV120FXEN02 VERTICAL FREEZER
Whirlpool EV120FXG06 VERTICAL FREEZER
Whirlpool EV120FXGW00 VERTICAL FREEZER
Whirlpool EV120FXGW01 VERTICAL FREEZER
Whirlpool EV120FXGW02 VERTICAL FREEZER
Whirlpool EV120FXGW03 VERTICAL FREEZER
Whirlpool EV120FXGW04 VERTICAL FREEZER
Whirlpool EV120FXGW05 VERTICAL FREEZER
Whirlpool EV120FXGW06 VERTICAL FREEZER
Whirlpool EV120FXGW07 VERTICAL FREEZER
Whirlpool EV120FXKQ00 UPRIGHT FREEZER
Whirlpool EV120FXKQ01 UPRIGHT FREEZER
Whirlpool EV120FXKQ02 UPRIGHT FREEZER
Whirlpool EV120FXKQ03 VERTICAL FREEZER
Whirlpool EV120FXKQ04 VERTICAL FREEZER
Whirlpool EV120FXKQ05 VERTICAL FREEZER
Whirlpool EV120FXKQ06 VERTICAL FREEZER
Whirlpool EV120FXKQ07 VERTICAL FREEZER
Whirlpool EV120FXMQ00 VERTICAL FREEZER
Whirlpool EV120FXMQ01 VERTICAL FREEZER
Whirlpool EV120FXMQ02 VERTICAL FREEZER
Whirlpool EV120FXMQ03 VERTICAL FREEZER
Whirlpool EV120FXMQ04 VERTICAL FREEZER
Whirlpool EV120FXMQ05 VERTICAL FREEZER
Whirlpool EV120FXMQ06 VERTICAL FREEZER
Whirlpool EV120FXXN00 Freezers*
Whirlpool EV120NXRQ00 VERTICAL FREEZER
Whirlpool EV120NXRQ03 VERTICAL FREEZER
Whirlpool EV130CXRW0 Freezers*
Whirlpool EV130CXSW00 Freezers*
Whirlpool EV130EXPW0 Freezers*
  #2 (permalink)
Old 10-26-2013, 11:36 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Your washer does not have any kind of electronic control so there is no reset procedure for it. Most likely, something has got into the pump and is jamming it. With cabinet removed and lid switch bypassed, release the two clips that hold the pump onto the back of the motor and pull the pump off and push it out of the way. (leave hoses connected). If washer spins ok with pump removed, you will need to unhook the drain hoses from the pump and check for obstructions. If this is not the problem, we can check some other things.
Here's a video on how to bypass the lid switch:
Lid switch bypassing Whirlpool direct drive washer - YouTube
Eric
  #3 (permalink)
Old 10-26-2013, 11:46 AM
Junior Member
Default
I actually took the pump off when I had the cabinet removed, and checked it for blockages. I didn't find anything in there.
  #4 (permalink)
Old 10-26-2013, 12:13 PM
Expert
APP Volunteer
Default
Try it with the pump off anyway to make sure it isn't seized. You must bypass lid switch for these tests. If it still won't work, try rotating the motor shaft by hand. CCW should cause the agitator to work and CW should cause the basket to spin. If you are able to do both, remove motor and set it on the floor still hooked up. Try spin mode to see if it runs. Place your foot on the motor before starting as it will tend to jump if it starts. If it just hums, spin the motor shaft by hand to see if it will start running. Check the motor connector for burned/corroded connections (unplug connector). Also check same on motor thermal overload switch.
Eric
  #5 (permalink)
Old 10-26-2013, 05:02 PM
Junior Member
Default
Okay, so I don't have the means to make a jumper cable for the lid switch bypass right now, so I watched a video on how to remove and check the clutch. The clutch is fine. Once I put everything back together, the spin cycle worked until I opened and closed the lid, then it would just buzz again with no movement.
  #6 (permalink)
Old 10-26-2013, 07:18 PM
Expert
APP Volunteer
Default
I think you may have a bad motor. Your model is one of the last Whirlpool made direct drive non-commercial units made and in the last production models, they used motors made in China and there have been problems with them. Check the label on the motor. If it's a model W10210608 and says "Made in China", it is suspect. This is a single speed motor. The replacement is a two speed model 661600. If you get this motor, you must also replace the tub support rear counterbalance spring as the new motor is heavier than your original. The spring is easy to replace. The only way to be sure the motor is the problem is to do some electrical troubleshooting which would be beyond your capability. If you get the motor from APP, you can return it if it doesn't solve the problem.
Whirlpool 661600 Direct Drive Washer Motor - AppliancePartsPros.com
Whirlpool W10250667 Suspension Spring - AppliancePartsPros.com
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Estate Washer won't Spin AnaBanana413 Washer Repair 9 02-20-2013 06:19 PM
Estate washer agitates, won't drain, timer buzzes knuckles Washer Repair 1 08-20-2012 01:40 PM
Whirlpool Estate - Spin Cycle Not Working RMBurke Washer Repair 1 12-11-2009 10:33 AM
Estate washer won't start... it only buzzes joepinion Washer Repair 1 11-04-2009 06:20 PM
Estate Whirlpool washer noise during spin tom gottler Washer Repair 1 12-20-2008 10:46 AM
