Discuss
90 series kenmore washer won't spin, drain
 in
Washer Repair
We have a kenmore 90 series washer that, during the spin cycle, stopped spinning and won't drain. At first, it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 90 series kenmore washer won't spin, drain
  #1 (permalink)
Old 10-25-2013, 04:14 PM
Junior Member
Beckmd is on a distinguished road
Default 90 series kenmore washer won't spin, drain
Model Number: 110.20912990   Brand: Kenmore   Age: More than 10 years
We have a kenmore 90 series washer that, during the spin cycle, stopped spinning and won't drain. At first, it sounded like the machine was trying to spin, but now it doesn't do anything. We've looked at the coupler, and it doesn't appear broken, but we can't spin it. Also, there is a gasket that is hanging/loose above the gearcase, and we can't see where it belongs. Any help would be appreciated!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-25-2013, 05:41 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Does it still agitate? Did you remove the motor to check the coupling? With motor removed, did you try to rotate the gearcase input shaft, CCW for agitation, CW for spin? Can you provide photo of the "gasket". It's probably the sound dampening ring that goes around the brake hub to prevent a ringing noise when the brakes are in contact with the hub.
If it agitates ok but won't drain or spin, does the motor make any sound at all in drain/spin or is it totally quiet? If all quiet, you may have a bad lid switch which you can bypass as a test.
Eric
  #3 (permalink)
Old 10-25-2013, 06:36 PM
Junior Member
Default
It did still agitate, before the spin cycle stopped working. We haven't removed the motor to check the coupling - just tried spinning it, and it doesn't move... Is there a "how to" on removing the motor?
The motor does makes a slight humming sound when on the spin cycle, but only for a few seconds.
Picture shows gasket on the right of gearcase.
  #4 (permalink)
Old 10-25-2013, 06:55 PM
Expert
APP Volunteer
Default
Yes, that is the sound dampening ring that has come off the outside of the brake hub. You need to remove the washer cabinet for better access.
How to Disassemble Whirlpool/Kenmore Direct Drive Washer - YouTube
You should be able to rotate the coupler from underneath as you have tried. If it won't budge, there may be something jammed in the drain pump which is on the back of the motor. When you get the cabinet off, release the clips that hold the pump on and pull it off from the motor shaft. Leave drain hoses connected, just push pump out of the way. Check to see if the sound dampening ring has gotten caught up inside the clutch and brake area. If it has, get it out of there. If you can't get it out, you will have to remove the gearcase to gain better access to get it out. If you get it out, try running spin mode with that drain pump still moved out of the way. You will have to bypass the lid switch with cabinet off in order to do this.
Lid switch bypassing Whirlpool direct drive washer - YouTube
Eric
  #5 (permalink)
Old 11-02-2013, 02:42 PM
Junior Member
Default
Thanks for the help... There was a child's sock jammed in the drain pump. The gasket was not caught up anywhere either. The washer is running as I type
  #6 (permalink)
Old 11-02-2013, 03:21 PM
Expert
APP Volunteer
Default
Ok, you should put that sound deadening ring back up around the brake hub. If it seems real loose like it would fall off again, just cut it and remove it. If you don't get any ringing noises during spin or when spin stops that annoy you, then don't worry about replacing it.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 series washer won't drain or spin ImSR Washer Repair 4 10-12-2013 11:14 AM
Kenmore Series 80 Washer won't spin but will drain ko220 Washer Repair 1 07-19-2011 06:55 PM
Kenmore 70 series washer wont agitate, spin, or drain xiuzhiwu Washer Repair 1 07-18-2010 12:59 PM
Kenmore 90 series washer will agitate but not spin or drain kmyres76 Washer Repair 4 06-21-2010 12:49 PM
kenmore washer 70 series wont spin and drain water foster13019 Washer Repair 1 12-20-2008 01:05 PM
