Here's another frontloader not completing its washing cycle. START CYCLE Shows 1:09 est time. Goes thru 1st wash cycle, using soap. Drains water, refills. Drum spins from time to time.
- HUM, no action or water
- start button blinks
- turned power off, then on, then "start"
Started at 54 min.
- adds water, drains, refills
- HUM, no action at 39 min.
Same routine at 39 min., (maybe another time), 9 min., and 1 min. Then finished. END CYCLEChecked error code = E22, fill timeout
- checked for clogged screens - fine
- removed water valve, checked all 3 valves with ohm meter - fine
- reinstalled
Ran t06, water level control test mode
- first step ran the pump, screen showed "E" (Empty)
- stepped through final 4 steps, each filling water and showing codes as expected
Wow, that's a long explanation! Sorry. Thanks. Any ideas are appreciated. Bryan
