GE Front load washer, Model Number W B V H 6 2 4 0 F W W
I tried to clean the BIG rubber gasket that keeps water from leaking out of the door and removed this spring-like retaining clamp,
NOw I am trying to reassemble and I cannot remember where the spring clamp is to be located ...so the rubber gasket is held in place.
ANY info is better than me guessing again.
