Discuss
Makes loud bearing noise in spin cycle
 in
Washer Repair
Washer makes loud bearing noise in spin cycle. Everything else works fine without any noise. It does not leak. Ads
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Makes loud bearing noise in spin cycle
  #1 (permalink)
Old 10-12-2009, 11:56 AM
Junior Member
dwoutersz is on a distinguished road
Default Makes loud bearing noise in spin cycle
Model Number: sav5300aww   Brand: Maytag   Age: 5 - 10 years
Ads By Google
Related Models
Maytag SAV5300AWW Washer - Top Loading
Maytag SAV5401AWQ Washer - Top Loading
Maytag SAV5401AWW Washer - Top Loading
Maytag SAV5600AWW Washer - Top Loading
Maytag SAV5701AWQ Washer - Top Loading
Maytag SAV5701AWW Washer - Top Loading
Maytag SAV5710AWW Washer - Top Loading
Maytag SAV571EEWW Washer - Top Loading
Maytag SAV5910AWW Washer - Top Loading
Maytag SAV5910EWW Washer - Top Loading
Maytag SAW25K3S Washer - Top Loading
Whirlpool SAWB600HQ0
Whirlpool SAWB600JQ0
Whirlpool SAWB600JQ1
Whirlpool SAWS800HQ0
Whirlpool SAWS800JQ0
Whirlpool SAWS800JQ1
Whirlpool SAWS800JQ2
Whirlpool SAWS800MQ0 Automatic Washer
Whirlpool SAWS900HQ0
Whirlpool SAWS900JQ0
Whirlpool SAWS900MQ0 Automatic Washer
Whirlpool SAWX650JQ0
Whirlpool SAWX650MQ0 Automatic Washer
Whirlpool SAWX650MQ2 Automatic Washer
Whirlpool SB1000SKN0
Whirlpool SB100PEDB0
Whirlpool SB100PEDB1
Whirlpool SB100PEDB2
Whirlpool SB100PEDB4
Whirlpool SB100PEDB5
Whirlpool SB100PEK0
Whirlpool SB100PEK1
Whirlpool SB100PER0
Whirlpool SB100PES0
Whirlpool SB100PES1
Whirlpool SB100PES2
Whirlpool SB100PES3
Whirlpool SB100PES4
Whirlpool SB100PSK0
Whirlpool SB100PSK1
Whirlpool SB100PSR0
Whirlpool SB100PSR1
Whirlpool SB130PEDB0
Whirlpool SB130PEDB1
Whirlpool SB130PEDB2
Whirlpool SB130PEK0
Whirlpool SB130PER1
Whirlpool SB130PER2
Whirlpool SB130PER3
Whirlpool SB130PER4
Whirlpool SB130PER5
Whirlpool SB130PERW0
Whirlpool SB130PSK0
Whirlpool SB160PEDB0
Whirlpool SB160PEDB1
Whirlpool SB160PEDB2
Whirlpool SB160PEDB4
Whirlpool SB160PEDQ0
Whirlpool SB160PEDQ1
Whirlpool SB160PEDQ2
Whirlpool SB160PEDQ4
Whirlpool SB160PEEB1
Whirlpool SB160PEEB2
Whirlpool SB160PEEB5 24" Built - in - Oven Gas
Whirlpool SB160PEEB6
Whirlpool SB160PEEB7
Whirlpool SB160PEEB8
Whirlpool SB160PEEB9
Whirlpool SB160PEEQ1
Whirlpool SB160PEEQ2
Whirlpool SB160PEEQ5 24" Built - in - Oven Gas
Whirlpool SB160PEEQ6
Whirlpool SB160PEEQ7
Whirlpool SB160PEEQ8
Whirlpool SB160PEEQ9
Whirlpool SB160PEXB0
Whirlpool SB160PEXB1
Whirlpool SB160PEXQ0
Whirlpool SB160PEXQ1
Amana SB21VE Ref - SXS/I&W
Amana SB21VPSE Ref - SXS/I&W
Amana SB21VW Ref - SXS/I&W
Thermador SB2B
Amana SB520K Ref - SXS/I&W
Amana SB520SW Ref - SXS/I&W
Amana SB520TW Ref - SXS/I&W
Amana SBC24FX0 Range - Electric Std Delaware
Amana SBC24FX5 Range - Electric Std Delaware
Amana SBC24FXOW Range - Electric Std Delaware
Amana SBC26CK Range - Electric Std Delaware
Amana SBD20H Ref - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K Ref - SXS/I&W
Amana SBD20M Ref - SXS/I&W
Amana SBD20MW Ref - SXS/I&W
Amana SBD20NE Ref - SXS/I&W
Amana SBD20NW Ref - SXS/I&W
Amana SBD20Q2E Ref - SXS/I&W
Amana SBD20Q2W Ref - SXS/I&W
Amana SBD20S4E Ref - SXS/I&W
Amana SBD20S4L Ref - SXS/I&W
Amana SBD20S4W Ref - SXS/I&W
Amana SBD20TPE Ref - SXS/I&W
Amana SBD20TPL Ref - SXS/I&W
Amana SBD20TPSW Ref - SXS/I&W
  #2 (permalink)
Old 10-14-2009, 06:16 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
See if this technical bulletin from Maytag on your model addresses your problem.
http://www.servicematters.com/maytag...TDL-0060-B.pdf
It is a somewhat time consuming repair and you need special tools.
__________________
  #3 (permalink)
Old 07-15-2011, 07:15 PM
Junior Member
LI Mark is on a distinguished road
Default Screeching In Spin Cycle
I have the same problem, Tech Bulletin page has moved do you know where it is?
1st problem is the drive belt burnt at the small pully side and broke from a freeze up or something.
Put a ribbed type auto belt on that we matched to see if the tranny blew or if it still spins. It spins and agatates. Does full wash cycle - wash, rinse, spin.
Now getting Very Loud screeching when it starts to spin and continues until it reaches full speed - then gone.
Also If I put some pressure pushing the motor back is is not as loud, still screeches but reaches full speed quicker
Brakes fine and quiet.
Machine has a metal drive pully and it Sounds like metal on metal at the bottom of machine.
No metal filings under the machine.
Occosional burst of the same screech during wash / agatate/ rinse cycle.
Completes full wash cycle and runs pretty good but the screeching sounds like it's gonna blow up!
Helpl I want to fix it, 20 years new and counting.
Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer makes loud noise at end of spin cycle HVAC pirate Washer Repair 1 02-24-2010 05:28 PM
GE Prodigy makes loud bearing noise on spin cycle TimN Washer Repair 0 02-02-2010 03:02 PM
Maytag Washer Makes Loud Moaning Noise During Spin Cycle DTOFT Washer Repair 1 06-11-2009 05:33 PM
Washer makes a loud clicking noise on spin cycle pattihanni Washer Repair 0 05-02-2009 09:40 AM
Loud Noise (bearing) On Spin Cycle CJASTUTO Washer Repair 1 03-08-2009 03:53 PM
