Starting yesterday when ever I do laundry my washer finishes the normal cycle and than starts the permanent press and then the delicate so my laundry is going through 3 complete cycles if I don't catch it after the spin cycle. What would need to be replaced to stop this. Otherwise it has been a great washer.
Most likely the problem is a bad timer. If you need the correct part number then post the "MFG" number of the washer and number of cycles from the control panel.
Originally Posted by: amanaEmily Starting yesterday when ever I do laundry my washer finishes the normal cycle and than starts the permanent press and then the delicate so my laundry is going through 3 complete cycles if I don't catch it after the spin cycle. What would need to be replaced to stop this. Otherwise it has been a great washer. You need to try and catch it when it gets to the off cycle, it sounds like it isn't empty when it does. If it doesn't empty the machine of the water it will move on to the next cycle. If you can try and spend a little time when it gets near the end of the cycle and tell us what you see and hear it would help us with a better diagnosis.
