Hello guy's this machine will not go into spin in any cycle, yet does beautyfull high speed spin in diagnostic mode, all harness conections are good. Tried a ccu board off a good machine no difference (building has many machines of same model) no fault code on display, door locks properly. The only thing abnormal was a black dust in motor winding. also removed some coins and some odd items from pump now machine pumps fine also checked hose to pressure switch and other end plastic container and all is clear. If someone has any knowledge as to where do I go from here I would greatly appreciated.Thanks George
