Discuss
Water leaking from transmission?
 in
Washer Repair
Kenmore 80 Series top loader. Water was leaking, so the old owners replaced it, and gave it to me. They
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water leaking from transmission?
  #1 (permalink)
Old 10-19-2013, 11:59 AM
Junior Member
almost enough is on a distinguished road
Default Water leaking from transmission?
Model Number: 110.28882790   Brand: Kenmore   Age: 5 - 10 years
Water was leaking, so the old owners replaced it, and gave it to me. They couldn't find the leak. I took the thing apart, and ran the cycle, and saw water coming from the transmission arm, so I naturally thought it was the tub seal. I just got done replacing it, and the thing still leaks from the exact same area.
The weird part is the water doesn't come from the outer tub, but it actually looks like it's coming out of the inside of the drive arm. It's not coming out and around the unit on the bottom, as if it's coming out of the tub seal and down onto it. It's actually coming out of the little holes on the bottom of the drive arm.
I'm at a loss. Am I going to have to replace the transmission, or is there a seal that I overlooked when I took the thing apart?
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-19-2013, 02:16 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Probably have a leaking centerpost seal or drive tube seal. This would cause water to come out from within the brake hub/clutch hub area.
Eric
  #3 (permalink)
Old 10-19-2013, 02:32 PM
Junior Member
Default
Quote:
Eric
Are those serviceable? When disassembling the tub unit I didn't notice any accessible seals. I'm guessing they are the black seals on the drive arm at 4:44 on the repair video on this parts site?
Looks like I'll have to start disassembly again.
  #4 (permalink)
Old 10-19-2013, 03:05 PM
Expert
APP Volunteer
Default
Yes, those are the seals. It is very rare for them to fail, I've never replaced one and I believe specialized tools are required to replace them. If water is coming out from within the brake hub/clutch hub area, it has to be one of those seals. If the tub seal was leaking, it would be coming down the outside of the tub support.
Eric
  #5 (permalink)
Old 11-05-2013, 10:38 AM
Junior Member
Default
So I finally got the washer pulled back apart (it's midterm time...so sue me).
Sure enough, I have about a 1cm gap in the seal that goes between (what I believe is) the brake shaft and the drive shaft. Definitely the source of the leaking.
Does it really take a specialty tool to repair this? My wife and I have been out a washer for too long, and we started shopping for a used replacement...but I'd hate to chuck a whole unit out because of one stupid seal. I'd especially hate to chuck it out after the hours I've put into cleaning it and repairing it.
Any information would be great. I can't find much on repairing seals for drive shafts.
  #6 (permalink)
Old 11-05-2013, 12:09 PM
Expert
APP Volunteer
Default
Top seal in this photo? You may be able to get the seals out and new ones in without special tools. Your on your own. I believe there will be two seals between agitator shaft and basket drive, one on top of the other (drive tube seal and oil seal).
Whirlpool 91939 Transmission Shaft Seal - AppliancePartsPros.com
Whirlpool 356427 Shaft Seal - AppliancePartsPros.com
  #7 (permalink)
Old 11-05-2013, 12:12 PM
Junior Member
Default
Its actually the bottom seal on that photo. The top one looks fine. Its the bigger one that sits stationary around the rotating shaft.
  #8 (permalink)
Old 11-05-2013, 12:40 PM
Expert
APP Volunteer
Default
That would be this one. Diagram shows two upper seals. Make sure centerpost is perfectly horizontal when removing basket drive as there is turbine oil in there.
Whirlpool 8577376 Seal - AppliancePartsPros.com
Added: Older direct drive models used two upper seals that were tall. A newer design has the upper bearing closer to the top of the tube and only one smaller seal is used. These seals and bearings are pressed in. You may be able to figure out a way fashioning your own installation tools to get the job done, or just replace the tub support and basket drive. Those seals must be greased.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer leaking water through transmission hessians1 Washer Repair 1 01-17-2012 02:40 PM
water leaking under tub & top of transmission mylolc Washer Repair 1 04-26-2011 12:26 PM
water getting in transmission and leaking back out jtconner Dishwasher Repair 0 01-19-2011 07:21 AM
water leaking between transmission and tub jsteward Washer Repair 1 08-27-2009 01:16 PM
Transmission Leaking Steve L Washer Repair 3 06-17-2009 10:01 AM
