I have a Kenmore front load washer, model# 417.44092500, I believe manufactured by Fridgidare. I have had all three baffles crack and need to replace them. The baffles appear to be held in by a screw that I cannot seem to access. I have tried to find a way to access the screw but haven't found a way. How do you get to the screw? I have tried removing the vent hose at the top of the drum housing, as well as the drain at the bottom. I would like to get the old baffles out and know I can replace them, before I order replacements. No luck so far. Any help would be great. Thanks!
Never mind. No screw. The bracket in the middle is held by 4 small metal tabs. Used a chip bar, like a crowbar and popped them out. Not sure how to secure them once they are replaced without bending those tabs.
