Discuss
Maytag Performa drain pump leaking
 in
Washer Repair
I have a Maytag Performa washer that leaks during the filling of the tub. The leak is from the overflow
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Performa drain pump leaking
  #1 (permalink)
Old 10-18-2013, 04:56 PM
Junior Member
TonyU is on a distinguished road
Default Maytag Performa drain pump leaking
Brand: Maytag   Age: 5 - 10 years
I have a Maytag Performa washer that leaks during the filling of the tub. The leak is from the overflow holes along the top of the drain pump. I replaced the drain pump, but this did not fix the problem. When the tub fills water runs immediatly into the drain pump and starts leaking out shortly after when the pump fills up. Do I have two bad pumps or is there another cause to this leaking?
Thank you for your feedback.
TonyU
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I think the pump quite on my maytag performa washer ChevyCowboy Washer Repair 1 12-10-2011 08:15 AM
Trouble with redesigned water pump Maytag Performa pav2300aww Danacat Washer Repair 1 08-19-2011 06:57 PM
Maytag Washer Drain Pump Leaking Divelucaya Washer Repair 3 02-12-2011 08:03 PM
Maytag Performa Washer Leaking From Bottom While Filling mjones61 Washer Repair 3 11-12-2010 02:41 AM
Washer Leaking -- Maytag Performa -- Help before I am buried in laundry! 4kids Washer Repair 3 10-11-2009 09:04 PM
