Discuss
Install Door Lock Assembly For Frigidaire Front Loader Washer Model#gltf2940es3
 in
Washer Repair
I need help for installing a door lock assembly for Frigidaire washer model #GLTF2940ES. I bought the part from the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Install Door Lock Assembly For Frigidaire Front Loader Washer Model#gltf2940es3
  #1 (permalink)
Old 10-12-2009, 10:26 AM
Junior Member
sassouline is on a distinguished road
Default Install Door Lock Assembly For Frigidaire Front Loader Washer Model#gltf2940es3
Brand: Frigidaire   Age: 1 - 5 years
I need help for installing a door lock assembly for Frigidaire washer model #GLTF2940ES. I bought the part from the website but don't know how to install. Please respond. Thank you.
  #2 (permalink)
Old 10-12-2009, 09:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The instructions are attached to the reply. Good luck.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-14-2009, 02:01 PM
Junior Member
Default
Thank you for the instructions. My husband and I will use them this weekend. Bye
  #4 (permalink)
Old 03-31-2010, 06:38 PM
Junior Member
plineman is on a distinguished road
Default Wife's happy in GA
Quote:
Thanks,Gene--Searched for this thread for a week--and 3 days for switch to arrive--10 min. labor no problems. Your obvious expertise has been greatly appreciated.
  #5 (permalink)
Old 04-01-2010, 06:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
You are welcome. We are glad you were able to fix it. Good luck with your washer.
__________________
  #6 (permalink)
Old 05-27-2011, 08:00 AM
Junior Member
JMU2004 is on a distinguished road
Default Thanks
I Had the EXACT same issue....apparently Very common with this model.
Part is on the way!
On a side note, a repair tech came out and told me it was the drain pump....$350 for the part and labor. The pump is $50, and the labor looks simple. This guy gives repairmen a bad name.....
  #7 (permalink)
Old 01-10-2012, 06:50 PM
Junior Member
bodie is on a distinguished road
Default gltf2940es front loader -
hi, my washer machine wont spin at end of cycle. Ive read its either door latch or motor board. Is there a way to find out which one without multi-meter test? If its the door latch can you send instructions? Bodie
  #8 (permalink)
Old 01-10-2012, 07:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Perform the Diagnostic test as described in the Tech sheet and post the results.
Post the end of the model number (one more digit).
__________________
  #9 (permalink)
Old 01-05-2013, 01:38 PM
Junior Member
stousdk is on a distinguished road
Default
I seem to having this same issue with our Frigidaire GLFT2940ES3.
BUT
I'm not getting any error codes of any kind.
The machine will run through an entire cycle...time runs perfectly normal...then when time for the spin comes up, suddenly the time display goes from whatever amount of time is displayed to zero, the machine signals that the cycle is finished, and the door unlocks, as if the spin actually happened.
Is it likely the same problem, the secondary door latch?
The Machine is 8 years old, and to be honest, I can't afford to nickel and dime parts.
  #10 (permalink)
Old 01-05-2013, 05:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Try to recall an error code from the machine memory as described in the tech sheet, posted earlier.
Run the diagnostic test as described in the same tech sheet.
Post the results.
Here are the breakdown diagrams and Parts for Frigidaire GLTF2940ES3 Washer - AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire door lock assembly frustratedmomma Washer Repair 4 09-17-2011 09:35 PM
GE Front Loader Washer door will not lock TGMUMMA Washer Repair 1 08-14-2009 11:32 AM
Whifrpool lock/door front loader washer repair kchapell Washer Repair 1 05-30-2009 02:55 PM
front loader door won't lock & start kimmitchell Washer Repair 8 07-27-2008 11:58 AM
Maytag Front loader door latch assembly bpcolll Washer Repair 4 08-29-2007 10:55 AM
