Discuss
Washer wont fill with water
 in
Washer Repair
My Maytag Neptune front load washer will not fill with water. I see an error code "nd" on the display.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer wont fill with water
  #1 (permalink)
Old 10-17-2013, 06:20 AM
Junior Member
john1955 is on a distinguished road
Default Washer wont fill with water
Model Number: MAH5500BWW   Brand: Maytag   Age: More than 10 years
My Maytag Neptune front load washer will not fill with water. I see an error code "nd" on the display. The instruction service sheet, that is inside the console, says that this means no drain. Everything I look-up asks me to check the pump for blockage. I did this and cannot find any blockage. I checked the continuity of the water valve solenoids and they all test OK. If I manually fill the washer with water the pump empties the tub at the appropriate time. So as best as I can tell the pump is functioning fine. At this point I have no clue how to proceed. Are there any sensors that could be bad that might need to be replaced. Please help.
Related Models
Maytag MAH5500BWW WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWQ WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWW WASHER- HORIZONTAL AXIS
Maytag MAH6500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH6500AWW WASHER- HORIZONTAL AXIS
Maytag MAH6700AWM WASHER- HORIZONTAL AXIS
Maytag MAH6700AWW WASHER- HORIZONTAL AXIS
Maytag MAH7500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH7500AWW WASHER- HORIZONTAL AXIS
Admiral MAH7550AAW WASHER- HORIZONTAL AXIS
Admiral MAH7550AGW WASHER- HORIZONTAL AXIS
Maytag MAH8700AWM WASHER- HORIZONTAL AXIS
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
Maytag MAT10PSAGL MANUAL, PARTS (WASHER)
Maytag MAT10PSAGW MANUAL, PARTS (WASHER)
Maytag MAT11CSBKL MANUAL, PARTS (WASHER)
Maytag MAT11MNAAW MANUAL, PARTS (WASHER)
Maytag MAT11MNAGW MANUAL, PARTS (WASHER)
Maytag MAT11MNEGW MANUAL, PARTS (WASHER)
Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER)
Maytag MAT12CSAAL MANUAL, PARTS (WASHER)
Maytag MAT12CSAAQ MANUAL, PARTS (WASHER)
Maytag MAT12CSAAW MANUAL, PARTS (WASHER)
Maytag MAT12CSAGW MANUAL, PARTS (WASHER)
Maytag MAT12CSAKL MANUAL, PARTS (WASHER)
Maytag MAT12CSAKQ MANUAL, PARTS (WASHER)
Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSEGW MANUAL, PARTS (WASHER)
Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER)
Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDAAL MANUAL, PARTS (WASHER)
Maytag MAT12PDAAW MANUAL, PARTS (WASHER)
Maytag MAT12PDABL MANUAL, PARTS (WASHER)
Maytag MAT12PDABW MANUAL, PARTS (WASHER)
Maytag MAT12PDAGW MANUAL, PARTS (WASHER)
Maytag MAT12PDBAL MANUAL, PARTS (WASHER)
Maytag MAT12PDBAQ MANUAL, PARTS (WASHER)
Maytag MAT12PDBAW MANUAL, PARTS (WASHER)
Maytag MAT12PDBBL MANUAL, PARTS (WASHER)
Maytag MAT12PDBBQ WASHER-TOP LOADING
Maytag MAT12PDBBW MANUAL, PARTS (WASHER)
Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDEGW MANUAL, PARTS (WASHER)
Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDSAW MANUAL,PARTS (WASHER)
Maytag MAT12PRAAW MANUAL, PARTS (WASHER)
Maytag MAT12PRAEW MANUAL, PARTS (WASHER)
Maytag MAT12PRBAW MANUAL, PARTS (WASHER)
Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PRSAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAGW MANUAL, PARTS (WASHER)
Maytag MAT12PSBAW MANUAL, PARTS (WASHER)
Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT13MNAAW MANUAL, PARTS (WASHER)
Maytag MAT13MNAGW MANUAL, PARTS (WASHER)
Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNEGW MANUAL, PARTS (WASHER)
Maytag MAT13PDAAW MANUAL, PARTS (WASHER)
Maytag MAT13PDBAW MANUAL, PARTS (WASHER)
Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER)
Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER)
Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PDAWW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool MAT14PDAXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PRAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT23PCAAG MANUAL, PARTS (WASHER)
Maytag MAT23PCAAL MANUAL, PARTS (WASHER)
  #2 (permalink)
Old 10-17-2013, 04:20 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
The problem could be in the control board or in the pressure switch , and you may want to start by replacing the pressure switch on spec. If you order from this site and that is not the part that fixes it you can replace it.
You should also download the service manual for the Neptune 3000. You should be able to find a free download on the net, look for the one with the lonesome repairman on the front. Your model is covered in the back, even though that is not noted in the table of contents.
The manual will take you through a whole bunch of diagnostic testing you can do with this model.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer wont fill with water amtracker Washer Repair 3 06-19-2012 05:06 AM
washer wont fill with water ron2011 Washer Repair 1 10-17-2011 10:30 AM
washer wont fill with water christi Washer Repair 0 05-05-2010 02:36 PM
Maytag washer wont fill with water volguy Washer Repair 1 06-15-2009 12:12 AM
Whirlpool washer wont fill with water. dfwhip Washer Repair 1 12-10-2007 05:16 PM
