My 5 year old Roper fills up with water, agitates/washes, drains and then when it hits the rinse cycle it stops and al it does is hum. The machine will not start a rinse cycle in any cycle permanent press ect. I can the turn the mashine to spin and that works. Can it be fixed inexpensively, or buy new?
Groups: Expert
So, after it drains, it won't go into spin unless you advance it there manually? What is the model number of the washer?
Eric
I'm having the same problem with my Rope. It well wash but then stop at rinse. I can turn the knob to spin an it well work. I only came up with this model number 13at609g76637747
