Discuss
Roper Top Load Washer
 in
Washer Repair
My washer never drained, I drained it manually and the only thing it does on any setting is hum, I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper Top Load Washer
  #1 (permalink)
Old 10-14-2013, 07:37 PM
Junior Member
Nikkilee is on a distinguished road
Default Roper Top Load Washer
Model Number: RAS8445KQO   Brand: Roper   Age: 5 - 10 years
My washer never drained, I drained it manually and the only thing it does on any setting is hum, I have already checked the lid switch and that is not the problem, not sure what to start checking or how to check it.
Thanks,
Nikki
Related Models
Maytag RAX1000AXW MISC / ACCESSORY
Maytag RAX1000CXB MISC / ACCESSORY
Maytag RAX2000AXW MISC / ACCESSORY
Maytag RAX2000CXB MISC / ACCESSORY
Maytag RAX3000DXX MISC / ACCESSORY
Maytag RAX33 MISC / ACCESSORY
Maytag RAX3300CXX MISC / ACCESSORY
Maytag RAX34 MISC / ACCESSORY
Maytag RAX36 MISC / ACCESSORY
Maytag RAX3600CXX MISC / ACCESSORY
Roper RAX4232JQ0 WASHER
Roper RAX4232KQ0 WASHER
Roper RAX4232KQ1 AUTOMATIC WASHER
Roper RAX4232PQ0 AUTOMATIC WASHER
Roper RAX4232PQ1 AUTOMATIC WASHER
Roper RAX4232RQ0 AUTOMATIC WASHER
Roper RAX4232RQ1 AUTOMATIC WASHER
Roper RAX4232RQ3 AUTOMATIC WASHER
Roper RAX4232RQ4 AUTOMATIC WASHER
Roper RAX4233PQ0 AUTOMATIC WASHER
Maytag RAX5000AXB MISC / ACCESSORY
Maytag RAX5000CXB MISC / ACCESSORY
Maytag RAX5100AXB MISC / ACCESSORY
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Roper RAX5133AL1 AUTOMATIC WASHER
Roper RAX5133AW0 Washers*
Maytag RAX5200AXB MISC / ACCESSORY
Maytag RAX5200CXB MISC / ACCESSORY
Maytag RAX5300AXB MISC / ACCESSORY
Maytag RAX5400AXB MISC / ACCESSORY
Maytag RAX5500AXB MISC / ACCESSORY
Maytag RAX5500CXB MISC / ACCESSORY
Maytag RAX5600AXB MISC / ACCESSORY
Maytag RAX5700AXB MISC / ACCESSORY
Maytag RAX5700CXB MISC / ACCESSORY
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Roper RAX7244EN0 WASHER
Roper RAX7244EN1 WASHER
Roper RAX7244EQ0 WASHER
Roper RAX7244EQ1 WASHER
Roper RAX7244EW0 WASHER
Roper RAX7244EW1 WASHER
Roper RAX7244JQ0 WASHER
Roper RAX7244KQ0 WASHER
Roper RAX7244KQ1 AUTOMATIC WASHER
Roper RAX7244KQ2 AUTOMATIC WASHER
Roper RAX7244PQ0 AUTOMATIC WASHER
Roper RAX7244PQ1 AUTOMATIC WASHER
Whirlpool RAX7245AG0
Whirlpool RAX7245AL0
Roper RAX7245AW0 Washers*
Roper RAX7245BL1 AUTOMATIC WASHER
Roper RAX7245BQ1 AUTOMATIC WASHER
Roper RAX7245BW0 DIRECT-DRIVE AUTOMATIC WASHER
Roper RAX7245BW1 AUTOMATIC WASHER
Roper RAX7245JQ0 WASHER
Roper RAX7245KQ0 WASHER
Roper RAX7245KQ1 AUTOMATIC WASHER
Whirlpool RB1000XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYN3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN5 24" ELECTRIC OVEN
Whirlpool RB1005XYW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW5 24" ELECTRIC OVEN
Whirlpool RB100PXK-0 24" ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK0
Whirlpool RB100PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB100PXYB3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB5 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1200XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB120PXYB3 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB120PXYB5 24" ELECTRIC OVEN
Whirlpool RB1300XKW1 COOKTOP
Frigidaire RB130FA0 Frg(v5) / Electric Range
Frigidaire RB130FF0 Frg(v4) / Electric Range
Frigidaire RB130FH0 Frg(v6) / Electric Range
Frigidaire RB130FL0 Frg(v3) / Electric Range
Frigidaire RB130FM0 Frg(v2) / Electric Range
Frigidaire RB130FW0 Frg(v1) / Electric Range
Whirlpool RB130PXK0 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK1 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK2 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK3 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV0 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV1 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV3 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV4 BUILT IN DOUBLE OVEN
Frigidaire RB131CA0 Frg(v1) / Electric Cooktop
Frigidaire RB131CA1 Frg(v1) / Built - in Electric Cooktop
  #2 (permalink)
Old 10-14-2013, 08:13 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Remove the cabinet, bypass lid switch and pull pump from motor to see if it will run without pump. (pump may be jammed). If it still won't run, pull motor and see if it will run just sitting on the floor. Place your foot on the motor as it will jump if it starts. Rotate gearcase input shaft by hand. CW for spin, CCW for agitation.
Eric
  #3 (permalink)
Old 10-15-2013, 05:07 PM
Junior Member
Default
Thanks, I watched a youtube video to figure out how to take apart the washer and I pulled the pump off and I don't know how it got in there but the 7 year olds sock was jammed in the pump.. managed to get it out and put washer back together and works great.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper top-load washer basket/tub won't spin curth Washer Repair 3 08-01-2012 05:18 PM
Roper top load washer shakes violently...HELP. Hexster Washer Repair 5 08-30-2011 02:05 AM
Roper Top Load Washer fills slowly dougdawn707 Washer Repair 1 03-09-2010 05:35 AM
Roper washer will not spin with a full load DRobison Washer Repair 0 03-13-2009 11:48 AM
Roper Top Load Washer Stops Mid Cycle wisfamily Washer Repair 7 11-01-2008 06:52 PM
