Discuss
Whirlpool Top load Washer clicks loudly in agitate mode and spin
 in
Washer Repair
Washer is just a normal top-load washer. Direct Drive. First, it didn't move at all. It would just make the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Top load Washer clicks loudly in agitate mode and spin
  #1 (permalink)
Old 10-14-2013, 04:21 PM
Junior Member
ggutshall87 is on a distinguished road
Question Whirlpool Top load Washer clicks loudly in agitate mode and spin
Model Number: SM 8525079   Brand: Whirlpool   Age: 5 - 10 years
Washer is just a normal top-load washer. Direct Drive. First, it didn't move at all. It would just make the noise of running. Turned out that the coupling was split, and I replaced it. I put it all back together and ran it. Once it went into agitate mode, it started making this loud clicking noise every agitation. At a steady pace like 2 per second. Then when going into spin cycle it started to spin at a slow pace and slowly ramped up to desired speed, like it needed to use the momentum to reach speed. With the increase in speed, there was an increase in clicks, proportionately. I've had this thing apart several times, trying to find the problem. I checked the motor by turning it by itself. Coupling is still good. Brakes and clutch appear to be in decent enough shape. Nothing appears out of order. I even put coupling on gearcase and took my drill to it and heard nothing and looked fine. But i do not believe it was an appropriate test. Two more notes: Does not happen 100% of the time. More like 95%. One of the times i took it apart and put it back together again, I started it empty in spin and it went for about 15-20 seconds perfectly. Then back to clicks. Ran a medium load and it did clicks 100% during agitate and about 75% during spin mode. The other note: during agitate and spin, it there is definitely a loss in strength. Agitate doesn't even make bubbles anymore and also what I said about the spin mode.
Related Models
Magic Chef SM10P-14-C MWAVE- CNTRTP / STAND ALONE
Magic Chef SM10P14B MWAVE- CNTRTP / STAND ALONE
Magic Chef SM10P14C MWAVE- CNTRTP / STAND ALONE
Frigidaire SM115JXD1 Wwh(v2) / Laundry Center
Frigidaire SM115JXD2 Wwh(v4) / Laundry Center
Frigidaire SM115JXD3 Wwh(v6) / Laundry Center
Frigidaire SM115JXD4 Wwh(v2) / Laundry Center
Frigidaire SM115JXW1 Wwh(v1) / Laundry Center
Frigidaire SM115JXW2 Wwh(v3) / Laundry Center
Frigidaire SM115JXW3 Wwh(v5) / Laundry Center
Frigidaire SM115JXW4 Wwh(v1) / Laundry Center
Frigidaire SM115LXD1 Wwh(v2) / Laundry Center
Frigidaire SM115LXD2 Wwh(v2) / Laundry Center
Frigidaire SM115LXW1 Wwh(v1) / Laundry Center
Frigidaire SM115LXW2 Wwh(v1) / Laundry Center
Frigidaire SM115MXD1 Wwh(v2) / 24 " Laundry Center
Frigidaire SM115MXD2 Wwh(v2) / 24 " Laundry Center
Frigidaire SM115MXW1 Wwh(v1) / 24 " Laundry Center
Frigidaire SM115MXW2 Wwh(v1) / 24 " Laundry Center
Frigidaire SM115PXD1 Wwh(v2) / 24 " Laundry Center
Frigidaire SM115PXD2 Wwh(v2) / 24 " Laundry Center
Frigidaire SM115PXD3 Wwh(v2) / 24 " Laundry Center
Frigidaire SM115PXW1 Wwh(v1) / 24 " Laundry Center
Frigidaire SM115PXW2 Wwh(v1) / 24 " Laundry Center
Frigidaire SM115PXW3 Wwh(v1) / 24 " Laundry Center
Amana SM22TBL REF - SXS/I&W
Amana SM22TBW REF - SXS/I&W
Frigidaire SM230JXD1 Wwh(v1) / Laundry Center
Frigidaire SM230JXD2 Wwh(v3) / Laundry Center
Frigidaire SM230JXD3 Wwh(v5) / Laundry Center
Frigidaire SM230JXD4 Wwh(v1) / Laundry Center
Frigidaire SM230JXW1 Wwh(v2) / Laundry Center
Frigidaire SM230JXW2 Wwh(v4) / Laundry Center
Frigidaire SM230JXW3 Wwh(v6) / Laundry Center
Frigidaire SM230JXW4 Wwh(v2) / Laundry Center
Frigidaire SM230LXD1 Wwh(v2) / Laundry Center
Frigidaire SM230LXD2 Wwh(v2) / Laundry Center
Frigidaire SM230LXW1 Wwh(v1) / Laundry Center
Frigidaire SM230LXW2 Wwh(v1) / Laundry Center
Frigidaire SM230MXD1 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230MXD2 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230MXW1 Wwh(v1) / 24 " Laundry Center
Frigidaire SM230MXW2 Wwh(v1) / 24 " Laundry Center
Frigidaire SM230PXD1 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230PXD2 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230PXD3 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230PXW1 Wwh(v1) / 24 " Laundry Center
Frigidaire SM230PXW2 Wwh(v1) / 24 " Laundry Center
Frigidaire SM230PXW3 Wwh(v1) / 24 " Laundry Center
Thermador SM272B
Thermador SM272S
Thermador SM272W
Thermador SM272YB AFTER S/N 8204
Thermador SM272YS AFTER S/N 8204
Thermador SM272YW AFTER S/N 8204
Thermador SM272ZS AFTER S/N 8204
Whirlpool SM958PEKW0 Range (gas)*
Whirlpool SM958PEKW1 Range (gas)*
Whirlpool SM958PEKW2 Range (gas)*
Whirlpool SM958PEPW0 Range (gas)*
Whirlpool SM958PEPW1 Range (gas)*
Whirlpool SM958PESW0 Range (gas)*
Whirlpool SM958PESW1 Range (gas)*
Whirlpool SM958PESW2 Range (gas)*
Whirlpool SM958PESW3 Range (gas)*
Whirlpool SM958PESW4 Range (gas)*
Whirlpool SM958PESW5 Range (gas)*
Whirlpool SM958PSKW0 Range (gas)*
Whirlpool SM958PSKW1 Range (gas)*
Whirlpool SM958PSKW2 Range (gas)*
Hardwick SM9642A580R RANGE- F/S STD GAS
Hardwick SM9642W580R RANGE- F/S STD GAS
Whirlpool SM980PEYW0 Range (gas)*
Whirlpool SM980PEYW2 Range (gas)*
Whirlpool SM988PEPW0 Range (gas)*
Whirlpool SM988PEPW1 Range (gas)*
Whirlpool SM988PEPW2 Range (gas)*
Whirlpool SM988PESW0 Range (gas)*
Whirlpool SM988PESW1 Range (gas)*
Whirlpool SM988PESW2 Range (gas)*
Whirlpool SM988PESW3 Range (gas)*
Whirlpool SM988PESW7 Range (gas)*
Whirlpool SM988PESW8 Range (gas)*
Amana SMC-1 COMPACTOR
Amana SMC-1-A COMPACTOR
Amana SMC-1-AG COMPACTOR
Amana SMC-1-C COMPACTOR
Amana SMCD-2 COMPACTOR
Amana SMCD-2-A COMPACTOR
Amana SMCD-2-AG COMPACTOR
Amana SMCD-2-C COMPACTOR
Amana SMCD-2B-A COMPACTOR
Amana SMCD-2B-AG COMPACTOR
Amana SMCD-2B-C COMPACTOR
Amana SMCD-2B-L COMPACTOR
Amana SMCD-2W COMPACTOR
Amana SMCD-2W-A COMPACTOR
Amana SMCD-2W-AG COMPACTOR
Amana SMCD-2W-C COMPACTOR
Amana SMCD-2W/-AG COMPACTOR
Amana SMCD2B COMPACTOR
Amana SMD21TBW REF - SXS/I&W
  #2 (permalink)
Old 10-14-2013, 05:08 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Post a video to youtube so we can hear it. Provide the correct model number, that isn't it.
Eric
  #3 (permalink)
Old 10-14-2013, 05:36 PM
Junior Member
Default
https://www.youtube.com/watch?v=YSON...e_gdata_player
This is the video of the sound it makes. Will post correct model number momentarily.
  #4 (permalink)
Old 10-14-2013, 05:39 PM
Junior Member
Default
Model: GSW9800PW2
  #5 (permalink)
Old 10-14-2013, 07:44 PM
Expert
APP Volunteer
Default
Video is listed as private, can't watch it.
  #6 (permalink)
Old 10-15-2013, 12:21 PM
Junior Member
Default
Sorry about that. It should be public now.
  #7 (permalink)
Old 10-15-2013, 12:43 PM
Expert
APP Volunteer
Default
Sounds like a faulty motor switch. Place it in the very last minute of permanent press cycle final spin. This should be high speed spin that bypasses the fabric selector switch setting. If it does the clicking there, I'm pretty sure it's the motor switch. Remove the cabinet, disconnect the motor connector, remove screw from motor switch and pull switch away from motor. Check for continuity between where the orange wire connected and the blue/orange wire connected. Should be zero ohms. If it's open or reading high resistance, that's' the problem.
Eric
  #8 (permalink)
Old 10-24-2013, 03:14 PM
Junior Member
Default
Sorry it took so long to update. I work long hours many days.
So I checked the things that you had me check. I ohmed out the switch and all appears well. Also took it apart since it was just the red plastic cover. saw how it worked and it checks out.
Also, probably the largest clue to this mystery:
When you said if it does click during the cycle final spin...
Well, the washer does not click in the final (super fast) spin. What does that mean? I look forward to your answer, and do apologize for the untimely response.
  #9 (permalink)
Old 10-24-2013, 06:28 PM
Expert
APP Volunteer
Default
Does it do the clicking in normal cycle during the last 5 minutes of wash agitation just before first drain? If not, looks like a bad fabric selector switch or faulty wiring/connection associated with switch. If it does do the clicking there, looks like a bad timer. Have you tried different speed settings with the fabric selector switch?
Eric
  #10 (permalink)
Old 10-28-2013, 12:53 PM
Junior Member
Default
Problem Solved:
I really looked into the motor switch. When I took it off, I noticed that the second terminal was bent over and touching the first terminal (the one with the black wire coming out of the motor to.) There was a little bit of black where they were touching. I straightened it out and carefully plugged everything in and reconnected everything. Then, tried it out again. There is no loud clicking noise and the strength of the washer is back to 100%. Thanks Eric. You just saved me a couple hundred dollars.
To sum things up: Original problem: broken coupling (probably caused by too much stress on the motor like a large load or tangle within washer.)
Second problem: Me plugging connector to motor wrong after investigating and fixing original problem.
Eric, you were right from the very beginning about something with motor switch. Thank you again kind stranger.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer won't spin or agitate. Motor? Mode shifter? kzinti83 Washer Repair 2 09-01-2013 02:14 PM
Kenmore washer diresct drive won't spin or agitate, makes loud clicks Killjoy Washer Repair 11 06-14-2010 10:00 AM
kitchenaid (whirlpool) top load washer will not agitate or spin bounette77 Washer Repair 20 01-26-2010 01:30 AM
ge top load washer clicks and wont spin fast jwood Washer Repair 1 04-18-2008 03:57 AM
