Discuss
Help with Whirlpool Duet leak betw inlet nozzle & dispenser
 in
Washer Repair
I'm hoping for some help from a Whirlpool pro... Duet washer is two months shy of 2 years old. Did
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help with Whirlpool Duet leak betw inlet nozzle & dispenser
  #1 (permalink)
Old 10-13-2013, 03:31 PM
Junior Member
Whirlpooled is on a distinguished road
Default Help with Whirlpool Duet leak betw inlet nozzle & dispenser
Model Number: WFW9550W   Brand: Whirlpool   Age: 1 - 5 years
Duet washer is two months shy of 2 years old. Did many successive loads yesterday and noticed water leak on floor. Today I removed front and rear panels and saw evidence of a leak that probably existed from day one (some rust and corrosion on bottom panel, shock, etc on left side, by the shock.) Removed top panel and ran machine on quick cycle to definitively isolate the leak. So far, I've got it nailed...
Shortly after machine cycle advances the water distribution lever on top of dispenser to position IV, water starts leaking at the joint between the water distribution plate (#11 in diagram) and the dispenser body, by the retaining clip just above the inlet nozzle (red arrows in diagram).
Examined and disconnected hoses, removed dispenser, and carefully opened dispenser lid. Everything looks perfectly fine! At this point, I suspected that the inlet nozzle (#5 in diagram) which was seated in the feed hose (#23) may not have been fully engaged into the dispenser, causing backspray inside the dispenser when the lever advances to position 4, forcing water to leak out between the dispenser and its lid, right near the inlet nozzle. Close examination while things were disassembled has shown that the nozzle just barely protrudes into the cavity when fully seated in the dispenser's inlet, so this made sense to me.
Carefully reassembled all, and yep, the leak persists, although not nearly as bad as before.
Any thoughts or suggestions from your experience? I'm feeling as thought this nozzle is really a bit shorter than it should be, but maybe I'm fixating on the wrong thing. If it were slightly longer, it would protrude a bit further into the cavity and would be less likely to backspray against the seam between lid and dispenser.
Thanks in advance for your insight.
Related Models
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Whirlpool WFW9550WW10 AUTOMATIC WASHER
Whirlpool WFW95HEXL0 WASHER
Whirlpool WFW95HEXL1 AUTOMATIC WASHER
Whirlpool WFW95HEXL2 AUTOMATIC WASHER
Whirlpool WFW95HEXR0 WASHER
Whirlpool WFW95HEXR1 AUTOMATIC WASHER
Whirlpool WFW95HEXR2 AUTOMATIC WASHER
Whirlpool WFW95HEXW0 WASHER
Whirlpool WFW95HEXW1 AUTOMATIC WASHER
Whirlpool WFW95HEXW2 AUTOMATIC WASHER
Whirlpool WFW9600TA00 AUTOMATIC WASHER
Whirlpool WFW9600TA01 AUTOMATIC WASHER
Whirlpool WFW9600TA02 AUTOMATIC WASHER
Whirlpool WFW9600TB00 AUTOMATIC WASHER
Whirlpool WFW9600TC00 AUTOMATIC WASHER
Whirlpool WFW9600TU00 AUTOMATIC WASHER
Whirlpool WFW9600TW00 AUTOMATIC WASHER
Whirlpool WFW9600TW01 AUTOMATIC WASHER
Whirlpool WFW9600TW02 AUTOMATIC WASHER
Whirlpool WFW9600TZ00 AUTOMATIC WASHER
Whirlpool WFW9640XW00 AUTOMATIC WASHER
Whirlpool WFW9700VA00 AUTOMATIC WASHER
Whirlpool WFW9700VA01 AUTOMATIC WASHER
Whirlpool WFW9700VW00 AUTOMATIC WASHER
Whirlpool WFW9700VW01 AUTOMATIC WASHER
Whirlpool WFW9750WL00 AUTOMATIC WASHER
Whirlpool WFW9750WL01 AUTOMATIC WASHER
Whirlpool WFW9750WL02 AUTOMATIC WASHER
Whirlpool WFW9750WR00 AUTOMATIC WASHER
Whirlpool WFW9750WR01 AUTOMATIC WASHER
Whirlpool WFW9750WR02 AUTOMATIC WASHER
Whirlpool WFW9750WW00 AUTOMATIC WASHER
Whirlpool WFW9750WW01 AUTOMATIC WASHER
Whirlpool WFW9750WW02 AUTOMATIC WASHER
Whirlpool WFW97HEXL0 WASHER
Whirlpool WFW97HEXL1 WASHER
Whirlpool WFW97HEXL2 AUTOMATIC WASHER
Whirlpool WFW97HEXR0 WASHER
Whirlpool WFW97HEXR1 WASHER
Whirlpool WFW97HEXR2 AUTOMATIC WASHER
Whirlpool WFW97HEXW0 WASHER
Whirlpool WFW97HEXW1 WASHER
Whirlpool WFW97HEXW2 AUTOMATIC WASHER
Amana WG1010.000 COMMERCIAL MICROWAVES
Amana WG1010.010 COMMERCIAL MICROWAVES
Amana WG1010.200 COMMERCIAL MICROWAVES
Amana WG1021.000 COMMERCIAL MICROWAVES
Amana WG1021.200 COMMERCIAL MICROWAVES
Amana WG1065.000 COMMERCIAL MICROWAVES
Amana WG1120.500 COMMERCIAL MICROWAVES
Amana WG1120.600 COMMERCIAL MICROWAVES
Amana WG1121.000 COMMERCIAL MICROWAVES
Amana WG1165.000 COMMERCIAL MICROWAVES
Amana WG1165.700 COMMERCIAL MICROWAVES
Amana WG1166.500 COMMERCIAL MICROWAVES
 WG1804R Air Conditioner
 WG1805RY6 Air Conditioner
Jenn-Air WG200 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG206 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG24000B WALLOVEN- STD GAS
Jenn-Air WG24000W WALLOVEN- STD GAS
Jenn-Air WG30100B WALLOVEN- S/C GAS
Jenn-Air WG30100W WALLOVEN- S/C GAS
Amana WG445.1 COMMERCIAL MICROWAVES
Amana WG445.2 COMMERCIAL MICROWAVES
 WG5200R Air Conditioner
Whirlpool WGD4750XQ0 29" GAS DRYER
Whirlpool WGD4750XQ1 29" GAS DRYER
Whirlpool WGD4800XQ0 DRYER
Whirlpool WGD4850XQ0 29" GAS DRYER
Whirlpool WGD4890XQ0 29" GAS DRYER
Whirlpool WGD4900XW0 29" GAS DRYER
Whirlpool WGD4910XQ0 29" GAS DRYER
Whirlpool WGD5000VQ1 29" GAS DRYER
Whirlpool WGD5100SQ0 29" GAS DRYER
Whirlpool WGD5100VQ0 29" GAS DRYER
Whirlpool WGD5100VQ1 29" GAS DRYER
Whirlpool WGD5200TQ0 29" GAS DRYER
Whirlpool WGD5200VQ0 29" GAS DRYER
Whirlpool WGD5200VQ1 29" GAS DRYER
Whirlpool WGD5300SQ0 29"GAS DRYER
Whirlpool WGD5300ST0 29"GAS DRYER
Whirlpool WGD5300VW0 29" GAS DRYER
Whirlpool WGD5300VW1 29" GAS DRYER
Whirlpool WGD5310SQ0 29"GAS DRYER
Whirlpool WGD5320SQ0 29"GAS DRYER
Whirlpool WGD5321SQ0 29"GAS DRYER
Whirlpool WGD5500SQ0 29"GAS DRYER
Whirlpool WGD5500ST0 29"GAS DRYER
Whirlpool WGD5500XL0 27" ELECTRIC DRYER
Whirlpool WGD5500XL1 27" ELECTRIC DRYER
Whirlpool WGD5500XW0 27" ELECTRIC DRYER
Whirlpool WGD5500XW1 27" ELECTRIC DRYER
Whirlpool WGD5510VQ0 29"GAS DRYER
Whirlpool WGD5510VQ1 29"GAS DRYER
Whirlpool WGD5520SQ0 29" GAS DRYER
Whirlpool WGD5521SQ0 29"GAS DRYER
Whirlpool WGD5530SQ0 29"GAS DRYER
Whirlpool WGD5540SQ0 29"GAS DRYER
Whirlpool WGD5540ST0 29"GAS DRYER
Whirlpool WGD5550SQ0 29" GAS DRYER
Whirlpool WGD5550ST0 29" GAS DRYER
Whirlpool WGD5550XW0 27" GAS DRYER
Whirlpool WGD5550XW1 27" GAS DRYER
Whirlpool WGD5560SQ0 29" GAS DRYER
Whirlpool WGD5590VQ0 29" GAS DRYER
Whirlpool WGD5590VQ1 29" GAS DRYER
Whirlpool WGD5600SQ0 29" GAS DRYER
Whirlpool WGD5600ST0 29" GAS DRYER
Whirlpool WGD5600VQ0 29" GAS DRYER
Whirlpool WGD5600XW0 27" GAS DRYER
Whirlpool WGD5600XW1 27" GAS DRYER
Whirlpool WGD5610XW0 27" GAS DRYER
Last edited by Whirlpooled : 10-13-2013 at 03:39 PM. Reason: Sorry, pasted image did not stick. Will append as attachment.
  #2 (permalink)
Old 10-15-2013, 06:47 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
You may have a defective part. Go ahead an order the replacement and see if it is different, and even if it is not go ahead and replace it.
If you order from this site and the part does not fix the problem you can return it.
__________________
  #3 (permalink)
Old 09-23-2014, 09:40 AM
Junior Member
bs71@live.com is on a distinguished road
Default
I have this same exact issue.. does anyone have a resolution to this? Did the part fix the problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet inlet valve has different wire connectors COH Washer Repair 1 08-19-2013 05:06 PM
front loading washing machine inlet nozzle leaking manion Washer Repair 1 07-05-2011 01:17 PM
whirlpool duet leak-is it the boot? booninety Washer Repair 0 04-24-2010 10:36 AM
Whirlpool Duet LP gas dryer valve leak fu11m00n Dryer Repair 0 12-09-2009 06:15 PM
Whirlpool Duet - Cleaned Filter, now I have a leak PalmBayChuck Washer Repair 2 09-24-2009 05:26 PM
