Discuss
Spin problem with Whirlpool washer
 in
Washer Repair
My problem is that the washer will not spin with a full load. If I go down when the washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Spin problem with Whirlpool washer
  #1 (permalink)
Old 10-13-2013, 07:57 AM
Junior Member
trailrider1 is on a distinguished road
Default Spin problem with Whirlpool washer
Model Number: LSQ9549LW0   Brand: Whirlpool   Age: 5 - 10 years
My problem is that the washer will not spin with a full load. If I go down when the washer stops and take out some of the clothing and reset to spin. It will spin but with a full load when I open the lid the clothes are laying on the bottom soaking wet. We replaced the gearcase last year. Glancing thru the parts list I do not see a belt. Could anyone help me and tell me what it could be.
Thank you in advance.
Related Models
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564MQ0 AUTOMATIC WASHER
Whirlpool LSQ9565MQ0 WASHER
Whirlpool LSQ9600JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG1 AUTOMATIC WASHER
Whirlpool LSQ9600LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LW1 AUTOMATIC WASHER
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
  #2 (permalink)
Old 10-13-2013, 09:41 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You need to monitor the washer while it's doing a load first. After agitation stops, the washer should drain for a couple minutes without spinning, then the motor must pause for a few seconds and start again at which point it should start spinning. If there is no pause, the timer is faulty. If there is a pause but it still won't start spinning with a heavy load, the most likely culprit is a worn clutch.
Whirlpool 285785 Clutch Assembly - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 10-13-2013, 02:59 PM
Junior Member
whirlpoolhelena is on a distinguished road
Default
I assume the drain pump is attached to the motor? If so, it sounds as though the motor windings burnt up. Most home washers the drain pump attaches directly to the motor, so the motor has to spin to get the water out. If it just sits there and hums then that would be the most likely problem. The other problem it could be would be the transmission has locked up and is preventing the motor from turning. Both are expensive, the motor at least 200 the transmission more, so it may be time for a new washer.
  #4 (permalink)
Old 10-13-2013, 03:26 PM
Expert
APP Volunteer
Default
Assuming the washer agitates ok and the fact that the washer does spin with a light load, it is highly unlikely that any motor windings are burnt up. This would be extremely rare for a Whirlpool motor. Not likely that the gearcase is the problem either since again, it does spin under light load. An easy way to check the motor and gearcase is to run the machine with the cabinet off and lid switch bypassed. Observe the clutch hub while in spin mode. If the clutch hub is spinning, then the motor and gearcase are fine. If clutch hub is spinning but basket is not, the problem could be a worn clutch, sticking brakes, worn drive block or other problem with basket drive or possibly clothing caught between the tubs. As I said, the motor must pause after draining or the gearcase will remain in neutral and never go into spin.
Eric
Cabinet removal: Cabinet removing Whirlpool direct drive washer - YouTube
Lid switch bypass: Lid switch bypassing Whirlpool direct drive washer - YouTube
Clutch hub location:
  #5 (permalink)
Old 10-15-2013, 11:16 AM
Junior Member
Default Thank You
Thank You very much, My husband said it looks like it may be the clutch so we are going to order the parts this week. I will let you know. Thank You Again
  #6 (permalink)
Old 10-15-2013, 11:48 AM
Expert
APP Volunteer
Default
Ok, make sure you purchase a genuine Whirlpool FSP replacement. Don't buy those $8-$15 clutches found on amazon and e bay. They are cheap pieces of junk and might last a few loads if your lucky.
Eric
  #7 (permalink)
Old 10-15-2013, 01:09 PM
Junior Member
Default
Will be ordering from you.
Thanks Again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Washer Spin Cycle Problem rbyeway Washer Repair 1 11-10-2011 06:34 PM
Spin problem with Whirlpool direct drive washer msvolkert Washer Repair 4 07-31-2010 05:54 AM
whirlpool washer spin problem amtnlvr Washer Repair 1 02-17-2010 05:57 PM
Whirlpool Washer Spin Cycle Problem lk12835 Washer Repair 1 11-24-2009 04:39 PM
Whirlpool Washer Spin Problem JDK0806 Washer Repair 5 09-26-2009 08:28 PM
