Hello there. Where can I get a wiring diagram to see if the motor I just got on ******** can be wired up to my 1se3160agwwge. the motor I got was from a wcsr2080b2ww. Thanks for the help
Groups: Expert
Is that a WWSE3160 you have? That washer uses a 2-speed motor, the one from the 2080 is a single speed. Here's the wiring diagram from the 2080. It can be used but you would have to wire your washer for single speed operation only. Very simple if you want to do it. Eric
