Discuss
Kenmore 70 series washer won't drain or spin
 in
Washer Repair
I am at my wits end. Washer won't go into drain & spin cycle. It only hums. Here's what I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 70 series washer won't drain or spin
  #1 (permalink)
Old 10-12-2013, 09:49 AM
Junior Member
ImSR is on a distinguished road
Unhappy Kenmore 70 series washer won't drain or spin
Model Number: 11026892690   Brand: Kenmore   Age: 5 - 10 years
I am at my wits end. Washer won't go into drain & spin cycle. It only hums. Here's what I have done:
Jumped the lid switch
Confirmed pump is rotating and not clogged
Confirmed coupling isn't broken
Confirmed motor and transmission to be in working order
Confirmed motor electrical plug shows no damage
Looked over time switch and confirmed no apparent damage or burned area
Is there something I'm missing here? I've scoured help videos and don't know where to go from here.
Would appreciate any help. Thanks
Related Models
Kenmore 11026892690 TB26-10- WARM RINSE
Kenmore 11026892691 AUTOMATIC WASHER
Kenmore 11026894691 AUTOMATIC WASHER
Kenmore 11026901690 SUPER CAPACITY PLUS AUTOMATIC WASHER
Kenmore 11026901691 AUTOMATIC WASHER
Kenmore 11026901692 AUTOMATIC WASHER
Kenmore 11026902690 AUTOMATIC WASHER
Kenmore 11026902691 WASHER
Kenmore 11026902692 AUTOMATIC WASHER
Kenmore 11026904691 AUTOMATIC WASHER
Kenmore 11026904692 AUTOMATIC WASHER
Kenmore 11026912690 AUTOMATIC WASHER
Kenmore 11026912691 AUTOMATIC WASHER
Kenmore 11026914690 WASHER
Kenmore 11026914691 AUTOMATIC WASHER
Kenmore 11026922500 WASHER
Kenmore 11026922501 WASHER
Kenmore 11026922502 WASHER
Kenmore 11026922503 RESIDENTIAL WASHERS
Kenmore 11026924500 WASHER
Kenmore 11026924501 WASHER
Kenmore 11026924502 WASHER
Kenmore 11026924503 RESIDENTIAL WASHERS
Kenmore 11026932690 Residential Washers
Kenmore 11026932691 Residential Washers
Kenmore 11026934690 Residential Washers
Kenmore 11026934691 Residential Washers
Kenmore 11026942500 WASHER
Kenmore 11026942501 WASHER
Kenmore 11026942502 WASHER
Kenmore 11026942503 RESIDENTIAL WASHERS
Kenmore 11026944500 WASHER
Kenmore 11026944501 WASHER
Kenmore 11026944502 WASHER
Kenmore 11026944503 RESIDENTIAL WASHERS
Kenmore 11026952690 AUTOMATIC WASHER
Kenmore 11026952691 AUTOMATIC WASHER
Kenmore 11026954690 AUTOMATIC WASHER
Kenmore 11026954691 AUTOMATIC WASHER
Kenmore 11026955690 AUTOMATIC WASHER
Kenmore 11026955691 AUTOMATIC WASHER
Kenmore 11026962500 WASHER
Kenmore 11026962501 WASHER
Kenmore 11026962502 WASHER
Kenmore 11026962503 RESIDENTIAL WASHERS
Kenmore 11026964500 WASHER
Kenmore 11026964501 RESIDENTIAL WASHER
Kenmore 11026964502 WASHER
Kenmore 11026964503 RESIDENTIAL WASHERS
Kenmore 11026966500 RESIDENTIAL WASHER
Kenmore 11027032600 WASHER
Kenmore 11027032601 AUTOMATIC WASHER
Kenmore 11027032602 RESIDENTIAL WASHER
Kenmore 11027032603 RESIDENTIAL WASHER
Kenmore 11027042600 WASHER
Kenmore 11027042601 RESIDENTIAL WASHERS
Kenmore 11027042602 RESIDENTIAL WASHER
Kenmore 11027042603 RESIDENTIAL WASHER
Kenmore 11027052600 RESIDENTIAL WASHERS
Kenmore 11027052601 RESIDENTIAL WASHER
Kenmore 11027052602 RESIDENTIAL WASHER
Kenmore 11027062600 WASHER
Kenmore 11027062601 RESIDENTIAL WASHER
Kenmore 11027062602 RESIDENTIAL WASHER
Kenmore 11027062603 RESIDENTIAL WASHER
Kenmore 11027062604 RESIDENTIAL WASHER
Kenmore 11027072600 WASHER
Kenmore 11027072601 RESIDENTIAL WASHER
Kenmore 11027072602 RESIDENTIAL WASHER
Kenmore 11027072603 RESIDENTIAL WASHER
Kenmore 11027072604 RESIDENTIAL WASHER
Kenmore 11027082600 RESIDENTIAL WASHER
Kenmore 11027082601 RESIDENTIAL WASHER
Kenmore 11027082602 RESIDENTIAL WASHER
Kenmore 11027082603 WASHER
Kenmore 11027082604 RESIDENTIAL WASHER
Kenmore 11027082605 RESIDENTIAL WASHER
Kenmore 11027086601 RESIDENTIAL WASHER
Kenmore 11027086602 RESIDENTIAL WASHER
Kenmore 11027086603 RESIDENTIAL WASHER
Kenmore 11027086604 RESIDENTIAL WASHER
Kenmore 11027086605 RESIDENTIAL WASHER
Kenmore 11027087600 RESIDENTIAL WASHER
Kenmore 11027087601 RESIDENTIAL WASHER
Kenmore 11027087602 RESIDENTIAL WASHER
Kenmore 11027087603 RESIDENTIAL WASHER
Kenmore 11027087604 RESIDENTIAL WASHER
Kenmore 11027087605 RESIDENTIAL WASHER
Kenmore 11027092600 WASHER
Kenmore 11027092601 RESIDENTIAL WASHER
Kenmore 11027092602 RESIDENTIAL WASHER
Kenmore 11027092603 RESIDENTIAL WASHER
Kenmore 11027112600 WASHER
Kenmore 11027152600 AUTOMATIC WASHER
Kenmore 11027152601 RESIDENTIAL WASHER
Kenmore 11027152602 RESIDENTIAL WASHER
Kenmore 11027172600 WASHER
Kenmore 11027222600 RESIDENTIAL WASHERS
Kenmore 11027224600 RESIDENTIAL WASHERS
Kenmore 11027272600 WASHER
Kenmore 11027322600 RESIDENTIAL WASHERS
Kenmore 11027332600 RESIDENTIAL WASHERS
Kenmore 11027342600 RESIDENTIAL WASHERS
Kenmore 11027422600 RESIDENTIAL WASHERS
Kenmore 11027432600 RESIDENTIAL WASHERS
Kenmore 11027442600 RESIDENTIAL WASHER
Kenmore 11027522600 RESIDENTIAL WASHERS
Kenmore 11027532600 RESIDENTIAL WASHERS
Kenmore 11027542600 RESIDENTIAL WASHER
Kenmore 11027612600 RESIDENTIAL WASHERS
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Kenmore 11027632600 RESIDENTIAL WASHERS
Kenmore 11027642600 RESIDENTIAL WASHERS
Kenmore 11027721600 RESIDENTIAL WASHER
Kenmore 11027731600 RESIDENTIAL WASHERS
Kenmore 11027741600 RESIDENTIAL WASHERS
Kenmore 11027751700 RESIDENTIAL WASHER
Kenmore 11027761700 RESIDENTIAL WASHER
Kenmore 11027782700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-12-2013, 10:56 AM
Member
ppipowerclass is on a distinguished road
Default
I have worked on TONS of these over the last few months. The motor spins in 2 different directions. One way, is for agitate. The other direction, is for drain / spin. The transmissions in these style of Kenmore are a little tricky too. Luckily, they're VERY common. I would check the motor with a volt tester to make sure that it reading properly. If it is, take the transmission out and visually inspect it to make sure that it has no leaks / cracks or any oil on it. If it does, than it's more than likely shot.
  #3 (permalink)
Old 10-12-2013, 11:07 AM
Junior Member
Default
Thank you for your reply. While I was waiting for a reply, I took the motor and transmission unit out again and have discovered that the shaft gear from the gearcase isn't catching in both motor directions. Actually the gears work fine with the top of the case off but when I replace the top, the pronged gear that fits around the shaft isn't spinning in both directions. So apparently the motor would "freeze up" when it tried to go in the opposite direction and only hum. I'm sure a gearcase for this model is pretty pricey. Do you suggest replacing it or getting a new washer?
  #4 (permalink)
Old 10-12-2013, 11:11 AM
Member
Default
They're VERY easy to replace! If that is the issue, I would call a local appliance place and see if they have a good used one for a reasonable price. If you lived closer, Id give you one of the 20 I have. haha.
I would replace the transmission.. you would for sure be able to get a few more years out of the washer!
  #5 (permalink)
Old 10-12-2013, 11:14 AM
Junior Member
Default
Thanks so much! I'll definitely look into a used transmission. Especially since my husband broke one of the bolt heads off while tightening them yesterday and it was leaking drops of oil anyway. Didn't think I'd be able to get a used one!
I'm on a mission now....!
Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 90 plus series washer won't spin, barely agitates, will drain & makes noise Maryland Mom Washer Repair 3 08-24-2012 04:32 PM
Kenmore Series 80 Washer won't spin but will drain ko220 Washer Repair 1 07-19-2011 06:55 PM
Kenmore 70 series washer wont agitate, spin, or drain xiuzhiwu Washer Repair 1 07-18-2010 12:59 PM
Kenmore 90 series washer will agitate but not spin or drain kmyres76 Washer Repair 4 06-21-2010 12:49 PM
kenmore washer 70 series wont spin and drain water foster13019 Washer Repair 1 12-20-2008 01:05 PM
