Faye C. Gross
#1 Posted : Friday, October 11, 2013 6:21:26 PM(UTC)
Faye C. Gross
the gentle cycle does not work
fairbank56
#2 Posted : Friday, October 11, 2013 7:16:58 PM(UTC)
fairbank56
Groups: Expert
Do you hear any noise at all from the motor when gentle/slow speed is selected? If not, disconnect wires from terminals 1 and 3 on back of speed switch and jump those two wires together and try it in spin mode. If it works, replace the speed switch. If it doesn't work and there is no noise from motor, check white wire at harness connector at motor. Look for broken wire or burned/corroded connector pins. Check continuity of white wire from speed switch to motor connector. With motor connector disconnected, you should have continuity between motor terminals where white wire and blue wire connect. If not, motor switch is defective and motor needs to be replaced.
Eric
GE WH12X10053 Switch Rotary - AppliancePartsPros.com
my fully automatic washer,(top loader) WONT SPIN (Washer Repair)
by johnsail2000 4/14/2023 8:51:18 PM(UTC)
Whirlpool front loading automatic washer rinse cycle (Washer Repair)
by Ivis 3/17/2013 4:36:02 PM(UTC)
Whirlpool LSQ9200PT0 AUTOMATIC WASHER has completely stopped (Dishwasher Repair)
by greencircle 8/26/2012 10:04:08 AM(UTC)
Whirlpool Cambrio Automatic washer error code F1 (Washer Repair)
by dishwasher6 7/24/2012 4:46:21 PM(UTC)
Whirlpool Automatic washer (Washer Repair)
by looking4help 3/7/2012 1:49:59 PM(UTC)
Whirlpool Automatic Washer (Washer Repair)
by Francuz 8/29/2011 3:25:08 PM(UTC)
Kenmore Automatic Washer (Washer Repair)
by melissa66 2/27/2011 1:28:36 PM(UTC)
Elite three speed automatic washer (Washer Repair)
by ksully 2/7/2011 3:48:52 PM(UTC)
Automatic Washer knob (Washer Repair)
by Melody1 1/12/2011 1:53:00 PM(UTC)
by dojo55 10/30/2010 5:00:46 AM(UTC)
One Speed Automatic Washer (Washer Repair)
by ricksa3 8/5/2009 1:11:42 PM(UTC)
kenmore 2-speed automatic washer (Washer Repair)
by jonandjanc 5/11/2009 3:14:46 PM(UTC)
by garronc1 5/8/2009 7:29:11 AM(UTC)
by Gary 8/30/2007 8:36:59 AM(UTC)
