Discuss
Kenmore Series 70 Washer Repair
 in
Washer Repair
Sears Kenmore Series 70 Washer Model Number: 110.26712693 Manufacturer: Whirlpool (I believe) I am working on repairing a friend's washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Series 70 Washer Repair
  #1 (permalink)
Old 10-11-2013, 10:08 AM
Junior Member
Shadowraven is on a distinguished road
Exclamation Kenmore Series 70 Washer Repair
Model Number: 110.26712693   Brand: Kenmore   Age: 5 - 10 years
I am working on repairing a friend's washer that will not fill with water. When started it does not even attempt to fill, but goes straight into agitation. The unit empties without problem, but won't fill. Currently my friend is using a garden hose from outside to fill his washer. He contacted me because I am usually able to fix anything that breaks, but I am always still learning.
This washer may be older than 10 years but still works very well and I see no other problems with it. He is committed to keeping it for now.
I believe that I have already located the problem but would like some confirmation before I order a $53 part for him. I think that the problem is being caused by a faulty Water Level Switch and that this: Water Level Switch, is the part I need to fix it.
I have already disassembled the washer and checked the line, it is clear and unobstructed. I've checked the water lines and they have pressure. He also reported that he had to jiggle the water level dial to get it to work just before it stopped filling. I don't think that the problem lies with the fill valves as the washer doesn't even attempt to fill itself. It just goes straight into agitation. I would be very grateful if one of you experts could chime in here and confirm my suspicions.
Thanks guys!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-11-2013, 10:50 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Pressure switch could be the problem. Check with multimeter with empty tub. Disconnect wires from switch and check for continuity between where the violet wire and pink wire were connected. Should be 0 ohms (short) and open between violet and tan connections. If there is continuity between violet and tan terminals on switch, disconnect pressure hose and check again. If you still have continuity, switch is faulty. Jump violet and pink wires together to see if washer will fill.
Whirlpool W10337780 Water Level Switch Kit - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 10-12-2013, 01:54 AM
Junior Member
carpinteyrorli is on a distinguished road
Default Muscle Pain The Day After A Workout
cheap belstaff In many respects, your chosen waterway will assist identify the basic related equipment listing. Many kayaks developed for stumbling and / or traveling provide you with discussed storeroom each of those fore not to mention aft belonging to the cabin. Such opportunities will be rather small-scale.
Mulberry Sacs babysitterofnalts is actually the compassionate taker. please be sure to to help you meet the regards. your lady in no way damages me personally and he or she request to cooking that will distinct. Overcom Only two massive egg on yet another carrier toilet bowl; period through pepper and salt. Incorporate tuckered out matzo; combine unless joined along with humid hitter types. Temperature Two tablespoons vegetable oil and gas within the significant frying pan throughout mediumhigh temperatures.
North Face uscita Privacy may also be a major problem for many individuals. The vast majority of international locations ordinarily part of overseas opportunities need laws and regulations causing it to be unlawful with the expenditure firms to secrete any specific specifics about their own buyers. You will find there's without any governments canceling.
belstaff jackets The latest modernization of data technology has drastically infected the actual lifestyles of consumers internationally. On top of the current online assistance, it offers effectively designed the planet seem to be reduced considering that it represents an essential part in almost every people's life, as a result of home shopping to help amassing information and facts. The traditional ways of looking for a personal ended up being a hardcore and also time consuming task.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 90 series washer momof4 Washer Repair 6 11-13-2012 06:59 PM
Kenmore 90 series washer lego126 Washer Repair 2 05-13-2012 07:56 PM
Kenmore 400 series wash machine repair needed bekholt Washer Repair 5 11-04-2011 03:12 PM
kenmore series 70 dryer repair cdrted Dryer Repair 1 10-26-2010 01:06 PM
Kenmore 70 series dryer repair help qkhan525 Dryer Repair 3 09-09-2009 11:19 AM
