Discuss
Maytag Neptune 2000 won't spin
 in
Washer Repair
Gentlemen I actually have 2 Maytag stacked combo units with the same problem. They were bought together in 2002 when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune 2000 won't spin
  #1 (permalink)
Old 10-11-2013, 12:06 AM
Junior Member
JimEbert is on a distinguished road
Default Maytag Neptune 2000 won't spin
Model Number: MLG2000AWW   Brand: Maytag   Age: More than 10 years
Gentlemen
I actually have 2 Maytag stacked combo units with the same problem. They were bought together in 2002 when we remodeled our home and happen to have different motors and motor control boards (one could have been replaced under warrenty).
Unit 1
SN 46866024ZY
Upper Control Board 62718050 - R11 AND Q6 look perfect, the whole board looks good.
Motor Conrol 62722460 this has the motor wires soldered to the board. The fuse tests good.
Wax Motor is the black tipped version, I found the spin enable microswitch would not close electrically and have replaced it. I also checked the three out of balance switches individually and all tested good.
The washer starts normally and runs fine, the red on light and door locked lights come on. When the timer advances to the rinse cycle the machine adds water the drum rotates 5 turns each way a number of times, the pump expels water but the machine never enters a spin. When the cycle is over the interior dry (water is pumped out) but no high speed spin has occured. I have tested continuity from P4 at the motor control to the P4 on the upper circut and all three wire show 0 ohms. Where do i go from here?
Unit 2
SN 46865923ZY
Motor Board 62724610
Upper Control Board 62718050 - R11 and Q6 look perfect, the whole board looks good.
Wax motor has the black tip, the red on light and door locked lights come on.
This machine quit entering the spin mode 4 or 5 years ago, it was never a issue until the other machine broke. This machine is doing the same thing as the other machine, everything seems to run fine until it is time for the machine to enter the spin cycle and it never speeds up, as a matter of fact both machines have the rotating wheel not moving at all for portions of the rinse/spin cycle. The P4 continunity test from the motor board to the upper board is also at 0 ohms. What's next?
Related Models
Maytag MLG2000AWW STACKED LAUNDRY- GAS
Maytag MLG2000AXW STACKED LAUNDRY- GAS
Maytag MLG23MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG23MNFWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLG23PDAWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAYQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDFGW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDFWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDFXW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHXW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PRAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PRFWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PRFXW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG24PDAGW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAWW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAWW1 COMMERCIAL GAS DRYER
Maytag MLG24PDAXW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAXW1 COMMERCIAL GAS DRYER
Maytag MLG24PNAGW0 COMMERCIAL GAS DRYER
Maytag MLG24PRAWW0 COMMERCIAL GAS DRYER
Maytag MLG24PRAWW1 COMMERCIAL GAS DRYER
Maytag MLG31PCAWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCAWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG32PDAWA MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWA MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWQ MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG32PDBWW MANUAL, PARTS (DRYER GAS)
Maytag MLG33PDAWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDAWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDSWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDSWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLI7000AAW SMALL APPLIANCES
Maytag MLI7500AAW SMALL APPLIANCES
Admiral MLR1100AJQ RANGE- F/S STD GAS
Admiral MLR1100AJW RANGE- F/S STD GAS
Admiral MLR1110AJQ RANGE- F/S STD GAS
Admiral MLR1110AJW RANGE- F/S STD GAS
Admiral MLR1415AJQ RANGE- F/S STD GAS
Admiral MLR1415AJS RANGE- F/S STD GAS
Admiral MLR1415AJW RANGE- F/S STD GAS
Admiral MLR4410BXH RANGE- F/S STD GAS
Admiral MLR4410BXL RANGE- F/S STD GAS
Admiral MLR4410BXT RANGE- F/S STD GAS
Admiral MLR4410CXH RANGE- F/S STD GAS
Admiral MLR4410CXT RANGE- F/S STD GAS
Admiral MLR4451AJQ RANGE- F/S STD GAS
Admiral MLR4451AJS RANGE- F/S STD GAS
Admiral MLR4451AJW RANGE- F/S STD GAS
Admiral MLR5755QDS RANGE- S/C F/S GAS
Admiral MLR5755QDW RANGE- S/C F/S GAS
Frigidaire MLSE62RFD0 Frg(v1) / Laundry Center
Frigidaire MLSE62RFD1 Frg(v1) / Laundry Center
Frigidaire MLSE62RFW0 Frg(v2) / Laundry Center
Frigidaire MLSE62RFW1 Frg(v2) / Laundry Center
Frigidaire MLSE62RFW2 Frg(v0) / Laundry Center
Frigidaire MLSG62RFD0 Frg(v1) / Laundry Center
Frigidaire MLSG62RFD1 Frg(v1) / Laundry Center
Frigidaire MLSG62RFW0 Frg(v2) / Laundry Center
Frigidaire MLSG62RFW1 Frg(v2) / Laundry Center
Frigidaire MLXE42RBD0 Frg(v2) / 27 " Laundry Center
Frigidaire MLXE42RBD1 Frg(v1) / 27 " Laundry Center
Frigidaire MLXE42RBD2 Frg(v1) / Laundry Center
Frigidaire MLXE42RBD3 Frg(v1) / Laundry Center
Frigidaire MLXE42RBW0 Tap(v4) / 27 " Laundry Center
Frigidaire MLXE42RBW1 Frg(v2) / 27 " Laundry Center
Frigidaire MLXE42RBW2 Frg(v2) / Laundry Center
Frigidaire MLXE42RBW3 Frg(v2) / Laundry Center
Frigidaire MLXE42RBWD0 Kel(v10) / 27 " Laundry Center
Frigidaire MLXE42RED0 Frg(v1) / Laundry Center
Frigidaire MLXE42RED3 Frg(v1) / Laundry Center
Frigidaire MLXE42RED4 Frg(v1) / Laundry Center
Frigidaire MLXE42RED5 Frg(v1) / Laundry Center
Frigidaire MLXE42REW0 Frg(v2) / Laundry Center
Frigidaire MLXE42REW1 Frg(v0) / Laundry Center
Frigidaire MLXE42REW2 Frg(v0) / Laundry Center
Frigidaire MLXE42REW3 Frg(v2) / Laundry Center
Frigidaire MLXE42REW4 Frg(v2) / Laundry Center
Frigidaire MLXE42REW5 Frg(v2) / Laundry Center
Frigidaire MLXE42REW6 Laundry Center - Universal
Frigidaire MLXE42REW7 Universal/laundry Center
Frigidaire MLXE42REW8 Universal/laundry Center
Frigidaire MLXE42RFW0 Universal/laundry Center
Frigidaire MLXE62RBD0 Frg(v2) / 27 " Electric Laundry Center
Frigidaire MLXE62RBD1 Frg(v1) / 27 " Electric Laundry Center
Frigidaire MLXE62RBD2 Frg(v1) / Laundry Center
Frigidaire MLXE62RBD3 Frg(v1) / Laundry Center
Frigidaire MLXE62RBW0 Tap(v4) / 27 " Electric Laundry Center
Frigidaire MLXE62RBW1 Frg(v2) / 27 " Electric Laundry Center
Frigidaire MLXE62RBW2 Frg(v2) / Laundry Center
Frigidaire MLXE62RBW3 Frg(v2) / Laundry Center
Frigidaire MLXE62RBWD0 Kel(v10) / 27 " Electric Laundry Center
Frigidaire MLXE62RBWW0 Frg(v1) / 27 " Electric Laundry Center
Frigidaire MLXE62RED0 Frg(v1) / Laundry Center
Frigidaire MLXE62RED3 Frg(v1) / Laundry Center
Frigidaire MLXE62REW0 Frg(v2) / Laundry Center
Frigidaire MLXE62REW1 Frg(v0) / Laundry Center
Frigidaire MLXE62REW2 Frg(v0) / Laundry Center
Frigidaire MLXE62REW3 Frg(v2) / Laundry Center
Frigidaire MLXG42RBD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MLXG42RBD1 Gib(v1) / 27 " Gas Laundry Center
Frigidaire MLXG42RBD2 Frg(v1) / Laundry Center
Frigidaire MLXG42RBD3 Frg(v1) / Laundry Center
Frigidaire MLXG42RBW0 Tap(v4) / 27 " Gas Laundry Center
Frigidaire MLXG42RBW1 Gib(v2) / 27 " Gas Laundry Center
Frigidaire MLXG42RBW2 Frg(v2) / Laundry Center
Frigidaire MLXG42RBW3 Frg(v2) / Laundry Center
Frigidaire MLXG42RBWD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MLXG42RBWW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire MLXG42RED0 Frg(v1) / Laundry Center
Frigidaire MLXG42RED2 Frg(v1) / Laundry Center
  #2 (permalink)
Old 10-13-2013, 10:55 PM
Junior Member
Default How I fixed it.
The most important thing is I got a service manual, and it made understanding the repair so much simpler.
Unit 1:
While I replaced the faulty spin enable switch in the door lock mechanism and I tested it by pushing the rubber switch with a screwdriver, I did not test it with the wax motor closing the switch. The nylon plunger was not pushing the rubber button on the switch sufficiently to close it. My low budget fix was to hang a piece of carbon fiber I had between the rubber button on the switch and the plunger on the door lock mechanism. Machine is working perfectly.
Unit 2:
Further testing revealed that the inertial switch attached to the washer drum had failed. I have order the replacement.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune MLG 2000 stackable won't spin kimpalmer11 Washer Repair 1 07-13-2012 07:22 PM
LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack mrdhoffman Washer Repair 1 08-30-2011 07:45 PM
Maytag Performa PYG 2000 no heat dthurd Dryer Repair 14 06-17-2011 09:41 AM
Maytag Neptune Super Stack will not spin while in spin cycle. Vohn Washer Repair 2 11-04-2010 09:30 AM
Maytag Stackable 2000 won't spin! Marcus1260 Washer Repair 0 04-29-2009 10:19 PM
