The issue I am having is, all the front display panel lights flicker on, and off. When it does this, I cant select any options, or start the washer. Sometimes it starts working for a moment, when it does this, I can select my water temp, that's it. And also I cant leave it plugged in, if I do it beeps continuously, and its not a service code beep. I have traced it to two possible probs.1. I figure it is likely the actual display control board part#W10215447, because there is power to the board but functions wont work, and lights flicker. If it is not maybe it could be the control board that the selector/display unit plugs into, part #AP5736910 on your site. So what do you think, am I on the right track? opinion from a expert would be helpful Thanks.
