Discuss
Tub Fills But Water Leaks
 in
Washer Repair
I started my washer this morning, stepped out to grab some cloths to put in it, came back and water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Tub Fills But Water Leaks
  #1 (permalink)
Old 10-07-2013, 08:51 AM
Junior Member
jcrance is on a distinguished road
Default Tub Fills But Water Leaks
Model Number: LA5668XSNO   Brand: Whirlpool   Age: 5 - 10 years
I started my washer this morning, stepped out to grab some cloths to put in it, came back and water was coming from the bottom of the washer. I turned it off, of course, then pulled it out to check the hoses. There was no moisture on any of the outer hoses. I check the tub, there was enough water in it to account for the time that it was running. I started it to see were the water was coming from, in the back, in the middle, there are two slits, the one on the left (when facing the back) was were the water was coming from. I have no idea what would be causing this since the tub is still filling and the hoses for the hot and cold are dry. The water inlet valve is to the left of it and it is dry also. Any ideas on what the problem could be would be appreciated. Thank you.
Related Models
Whirlpool LA5668XSW0
Whirlpool LA5668XSW1
Whirlpool LA5668XSW2
Whirlpool LA5668XTF1
Whirlpool LA5668XTG1
Whirlpool LA5668XTM1
Whirlpool LA5668XTN1
Whirlpool LA5668XTW0
Whirlpool LA5668XTW1
Whirlpool LA5700XKW0 AUTOMATIC WASHER
Whirlpool LA5700XMW0 AUTOMATIC WASHER
Whirlpool LA5700XMW1 AUTOMATIC WASHER
Whirlpool LA5700XPW0 AUTOMATIC WASHER
Whirlpool LA5700XPW1 AUTOMATIC WASHER
Whirlpool LA5700XPW3 AUTOMATIC WASHER
Whirlpool LA5700XPW4 AUTOMATIC WASHER
Whirlpool LA5700XPW5 AUTOMATIC WASHER
Whirlpool LA5700XPW6 AUTOMATIC WASHER
Whirlpool LA5700XSW0 AUTOMATIC WASHER
Whirlpool LA5700XSW1 AUTOMATIC WASHER
Whirlpool LA5700XSW2 AUTOMATIC WASHER
Whirlpool LA5700XTF0
Whirlpool LA5700XTF1
Whirlpool LA5700XTG0
Whirlpool LA5700XTG1
Whirlpool LA5700XTM0
Whirlpool LA5700XTM1
Whirlpool LA5700XTN0
Whirlpool LA5700XTN1
Whirlpool LA5700XTW0 AUTOMATIC WASHER
Whirlpool LA5700XTW1 AUTOMATIC WASHER
Whirlpool LA5705XKW0 AUTOMATIC WASHER
Whirlpool LA5705XMW0 AUTOMATIC WASHER
Whirlpool LA5705XMW1 AUTOMATIC WASHER
Whirlpool LA5705XTF2
Whirlpool LA5705XTG2
Whirlpool LA5705XTM2
Whirlpool LA5705XTN2
Whirlpool LA5705XTW0 AUTOMATIC WASHER
Whirlpool LA5705XTW1 AUTOMATIC WASHER
Whirlpool LA5705XTW2 AUTOMATIC WASHER
Whirlpool LA5705XWF0
Whirlpool LA5705XWG0
Whirlpool LA5705XWM0
Whirlpool LA5705XWN0
Whirlpool LA5705XWW0 AUTOMATIC WASHER
Whirlpool LA5710XPW0 AUTOMATIC WASHER
Whirlpool LA5710XPW1 AUTOMATIC WASHER
Whirlpool LA5710XPW3 AUTOMATIC WASHER
Whirlpool LA5715XPW0 AUTOMATIC WASHER
Whirlpool LA5715XPW1 AUTOMATIC WASHER
Whirlpool LA5715XPW3 AUTOMATIC WASHER
Whirlpool LA5720XTF0
Whirlpool LA5720XTG0
Whirlpool LA5720XTM0
Whirlpool LA5720XTN0
Whirlpool LA5720XTW0 AUTOMATIC WASHER
Whirlpool LA5800XKW0
Whirlpool LA5800XMW0
Whirlpool LA5800XPW0
Whirlpool LA5800XPW1
Whirlpool LA5800XSW0
Whirlpool LA5800XSW1
Whirlpool LA5800XTF0
Whirlpool LA5800XTF1
Whirlpool LA5800XTG0
Whirlpool LA5800XTG1
Whirlpool LA5800XTM0
Whirlpool LA5800XTM1
Whirlpool LA5800XTN0
Whirlpool LA5800XTN1
Whirlpool LA5800XTW0
Whirlpool LA5800XTW1
Whirlpool LA5805XKW0
Whirlpool LA5805XMW0
Whirlpool LA5805XPW0
Whirlpool LA5805XPW1
Whirlpool LA5880XKW2
Maytag LA590 WASHER-TOP LOADING
Whirlpool LA5900XSW0
Whirlpool LA5900XSW1
Maytag LA5910 WASHER-TOP LOADING
Whirlpool LA5950XSW0
Whirlpool LA6000XPW0
Whirlpool LA6000XPW1
Whirlpool LA6000XPW2
Whirlpool LA6000XPW3
Whirlpool LA6000XPW4
Whirlpool LA6000XPW5
Whirlpool LA6000XSW0
Frigidaire LA600AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA600AXD2 Wwh(v6) / 27 " Washer
Frigidaire LA600AXD3 Wwh(v1) / 27 " Washer
Frigidaire LA600AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA600AXW2 Wwh(v5) / 27 " Washer
Frigidaire LA600AXW3 Wwh(v2) / 27 " Washer
Frigidaire LA600EXD3 Wwh(v11) / Top Loading Washer
Frigidaire LA600EXF3 Wwh(v12) / Top Loading Washer
Frigidaire LA600EXH3 Wwh(v13) / Top Loading Washer
Frigidaire LA600EXV3 Wwh(v14) / Top Loading Washer
Frigidaire LA600EXW3 Wwh(v15) / Top Loading Washer
Frigidaire LA600JXD3 Wwh(v1) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXD4 Wwh(v6) / Top Load Washer
Frigidaire LA600JXD5 Wwh(v3) / Top Load Washer
Frigidaire LA600JXF3 Wwh(v2) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXF4 Wwh(v7) / Top Load Washer
Frigidaire LA600JXH3 Wwh(v3) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXH4 Wwh(v8) / Top Load Washer
Frigidaire LA600JXV3 Wwh(v4) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXV4 Wwh(v9) / Top Load Washer
Frigidaire LA600JXW3 Wwh(v5) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXW4 Wwh(v10) / Top Load Washer
Frigidaire LA600JXW5 Wwh(v4) / Top Load Washer
Frigidaire LA600MXD1 Wwh(v6) / 27 " Washer
Frigidaire LA600MXD2 Wwh(v6) / 27 " Washer
Frigidaire LA600MXH1 Wwh(v5) / 27 " Washer
Frigidaire LA600MXH2 Wwh(v5) / 27 " Washer
Frigidaire LA600MXW1 Wwh(v4) / 27 " Washer
Frigidaire LA600MXW2 Wwh(v4) / 27 " Washer
Whirlpool LA6010XTF0
  #2 (permalink)
Old 10-07-2013, 04:41 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Here's your schematic to breakdown your unit you'll have to tear it apart and identify the part it's leaking from. Good luck
http://www.appliancepartspros.com/pa...a5668xsw0.html
  #3 (permalink)
Old 10-07-2013, 06:18 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Here's the actual parts manual for your washer. It may be that the hose running from the inlet valve to the vacuum break is leaking. Number 22 on the diagram on page 5.
http://shared.whirlpoolcorp.com/asse...%203348035.pdf
Eric
  #4 (permalink)
Old 10-09-2013, 08:51 AM
Junior Member
Default Thank you
I wanted to thank everyone for their input. I was able to take it apart and it was the vacuum inlet hose, there was a huge hole in it. Thank you again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water dispenser leaks when ice maker fills Steenbockj Refrigerator & Freezer Repair 5 02-22-2013 10:45 AM
rinse cycle over fills and leaks erthsynce Washer Repair 2 05-16-2012 05:12 PM
water dispenser leaks (yes I replaced the water inlet valve, filter, and installed s) david465 Refrigerator & Freezer Repair 4 03-11-2010 04:12 PM
Washer Fills, but leaks out of the bottom QTBaby21 Washer Repair 1 07-09-2009 12:30 PM
water sometimes fills into bottom then leaks tomcundith Dishwasher Repair 0 06-10-2009 03:02 PM
