The washer is a Montgomery ward, although searching the models the internals look like a Norge LWJ202A. It is 20+ years old. The only thing it does not do is sometimes it does not spin. I have the front off, and I can see the spindle and shaft from bottom pulley spinning. I can give the housing a little push and it will then start spinning fine. I searched and thought perhaps the clutch assy that looks to be internal to the transmission, however it says that part is not available. So what now?
