The cycle goes through the rinse cycle, agitates then everything stops (the motor stops, the timer stops, the tub stays full). This occurs at the same stage regardless of what cycle is used.
I'm trying to decide if it is worth getting someone to come out and look at it or if I should just replace the whole thing (attached washer/dryer, the dryer works fine). Definitely hoping it can be fixed relatively inexpensively... I just had to replace my dishwasher last week!
