sprank
#1 Posted : Thursday, October 3, 2013 10:54:19 AM(UTC)
sprank
My Door Lock Light comes on, but nothing else results from any position of the timer when I pull the knob to on position. I found my wax motor in the door lock mechanism had expanded and therefore seemed to have shorted and burned itself up. I also found black marks on a resistor and a transistor on the motor control board and I've even replaced the timer. These three elements have been replaced. Still no change in behavior.
HumboldtRepairMan
#2 Posted : Thursday, October 3, 2013 3:40:10 PM(UTC)
HumboldtRepairMan
You did the right thing on replacing the parts you did usually it's the timer or motor control but since you replaced all the parts you did it's either the wire harness or the motor then if all the parts you got were from a reputable supplier and tested good.
sprank
#3 Posted : Thursday, October 3, 2013 3:51:09 PM(UTC)
sprank
upon second inspection, I had improperly installed a wiring harness that came with the door lock factory replacement part. Once I spotted that, my troubles were over.
As there are two ways to install the harness and lock due to early and late series numbers of that same model I had misled myself to believe that not all wires were involved. I was wrong.
HumboldtRepairMan
#4 Posted : Thursday, October 3, 2013 3:53:32 PM(UTC)
HumboldtRepairMan
that make sense anytime you work on something make video with your cameraphone or take notes and label things. That may have been the problem with you shorting things out?
sprank
#5 Posted : Thursday, October 3, 2013 4:13:27 PM(UTC)
sprank
The electronics failed due to age and wear, I didn't short anything out.
Kenmore front load washer 417.42142100 won’t do final spin. (Washer Repair)
by Kmeadows 5/28/2020 7:41:23 AM(UTC)
Kenmore Front Load Washer Suddenly Displaying 8E (Barely Used / Has not Been Used for a While) (Washer Repair)
by ataenter 10/30/2018 7:19:47 PM(UTC)
Kenmore Front Load Washer has power, lights, wont's start (Washer Repair)
by JJones35! 2/10/2017 1:53:12 PM(UTC)
kenmore front load washer (Washer Repair)
by bowert 12/10/2015 11:05:14 PM(UTC)
kenmore front load washer won't spin (Washer Repair)
by kempffc 4/14/2015 1:34:35 PM(UTC)
Kenmore front load washer won't spin (Washer Repair)
by jwes 10/31/2014 4:31:29 PM(UTC)
Kenmore Front load Washer 417.47102700 timer or Motor Control Board issue? (Washer Repair)
by BGM 2/8/2013 12:13:07 PM(UTC)
Kenmore front load washer dies before end of cycle. (Washer Repair)
by The Hobo 1/16/2013 5:10:50 AM(UTC)
Kenmore Front Load Washer (Washer Repair)
by ERICJS112 5/8/2012 4:45:03 PM(UTC)
Kenmore front load washer wont agitate or spin (Washer Repair)
by ebcravens 1/10/2012 2:27:09 PM(UTC)
Kenmore front load washer intermittantly fails to spin (Washer Repair)
by fivefoot20 11/28/2011 9:41:30 AM(UTC)
New Sears Kenmore Front Load Washer Power Button Broken (Washer Repair)
by CEDRIC_W 8/19/2011 11:53:45 AM(UTC)
Kenmore front load washer (Washer Repair)
by ajm1979 8/16/2011 1:08:02 PM(UTC)
Kenmore front load washer won't spin... (Washer Repair)
by carlymac 7/1/2011 2:00:03 PM(UTC)
Kenmore front load washer squeaks and makes horribly loud noise on final spin cycle (Washer Repair)
by pktrain 6/8/2011 10:55:26 AM(UTC)
