I have received the f28 error code. I'm a little perplexed because the washer will lock the door and act like it is going to start the cycle but it will not fill with water or agitate. However the washer did work for the "clean washer" cycle but ended the wash before it was actually done. Just wondering what could be the cause of this.
Incomplete or inaccurate model number
