Discuss
Slowly Leaking (< 1 cup/hr)
 in
Washer Repair
Last week I repaired the drain pump on my washing machine to correct a &quot;it does drain problem.&quot; The repair
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Slowly Leaking (< 1 cup/hr)
  #1 (permalink)
Old 10-02-2013, 07:21 PM
Junior Member
notstarman is on a distinguished road
Default Slowly Leaking (< 1 cup/hr)
Model Number: Haier HLP021 WM   Brand: -other-   Age: 1 - 5 years
Last week I repaired the drain pump on my washing machine to correct a "it does drain problem." The repair went fine and the machine works perfectly again except it now has a slow leak at the rate of a few cups of water over night.(I had turned the water off and disconnected the water.)
The source is difficult to find because of the leak it so slow. I suspect that the cause of the leak might be a poor seal around the input pipe of the drain pump. Before I dissembled washer this junction was coated in what appeared to be latex which was removed when I removed the pump. This compound must have improved the seal between the hose of the pump.
Does any one know where I can find more of the sealing compound?
Related Models
Hoover HAV1200ARW WASHER-TOP LOADING
Hoover HAV1200AWA WASHER-TOP LOADING
Hoover HAV1200AWQ WASHER-TOP LOADING
Hoover HAV1200AWW WASHER-TOP LOADING
Maytag HAV2357AWW WASHER-TOP LOADING
Maytag HAV2360AWW WASHER-TOP LOADING
Maytag HAV2460AWW WASHER-TOP LOADING
Maytag HAV2557AWW WASHER-TOP LOADING
Maytag HAV2558AWW WASHER-TOP LOADING
Maytag HAV3460AWW WASHER-TOP LOADING
Hoover HAV4200AKW WASHER-TOP LOADING
Hoover HAV4200ATW WASHER-TOP LOADING
Hoover HAV4200AWW WASHER-TOP LOADING
Maytag HAV4657AWW WASHER-TOP LOADING
Maytag HAV4657EWW WASHER-TOP LOADING
Magic Chef HB100-30 HOOD
Magic Chef HB100-36 HOOD
Magic Chef HB100-42 HOOD
Magic Chef HB100D-30 HOOD
Magic Chef HB100D-36 HOOD
Magic Chef HB100D-42 HOOD
Thermador HB30QB RANGEHOOD
Thermador HB30QS RANGEHOOD
Thermador HB30QW RANGEHOOD
Thermador HB36QB RANGEHOOD
Thermador HB36QS RANGEHOOD
Thermador HB36QW RANGEHOOD
Bosch HBL432 AUC (FD 8202-)
Bosch HBL435 AUC (FD 8202-)
Bosch HBL436 AUC (FD 8202-)
Bosch HBL442 AUC (FD 8202-)
Bosch HBL445 AUC (FD 8202-)
Bosch HBL446 AUC (FD 8202-)
Bosch HBL452 AUC (FD 8202-)
Bosch HBL455 AUC (FD 8202-)
Bosch HBL456 AUC (FD 8202-)
Bosch HBL532 ELECTRIC WALL OVEN
Bosch HBL535 ELECTRIC WALL OVEN
Bosch HBL536 ELECTRIC WALL OVEN
Bosch HBL542
Bosch HBL545
Bosch HBL546
Bosch HBL552
Bosch HBL555
Bosch HBL556
Bosch HBL562
Bosch HBL565
Bosch HBL566
Bosch HBL632
Bosch HBL635
Bosch HBL636
Bosch HBL642
Bosch HBL645
Bosch HBL646
Bosch HBL652
Bosch HBL655 ELECTRIC BUILT-IN OVEN
Bosch HBL656
Bosch HBL662
Bosch HBL665
Bosch HBL666
Bosch HBL742 AUC (FD 8207-)
Bosch HBL745 AUC (FD 8207-)
Bosch HBL746 AUC (FD 8207-)
Bosch HBL752 AUC (FD 8207-)
Bosch HBL755 AUC (FD 8207-)
Bosch HBL756 AUC (FD 8207-)
Bosch HBL765 AUC (FD 8207-)
 HBLG1200H Air Conditioner
 HBLG1203R Air Conditioner
 HBLG1400E Air Conditioner
 HBLG1453E Air Conditioner
 HBLG1800H Air Conditioner
 HBLG2350E Air Conditioner
 HBLG2400R Air Conditioner
 HBLG5200E Air Conditioner
 HBLG6000R Air Conditioner
 HBLG8000R Air Conditioner
Bosch HBN442 AUC
Bosch HBN445 AUC
Bosch HBN446 AUC
Bosch HBN452 AUC
Bosch HBN455 AUC
Bosch HBN456 AUC
Bosch HBN642
Bosch HBN645
Bosch HBN646
Bosch HBN652
Bosch HBN655
Bosch HBN656
Bosch HBN662
Bosch HBN665
Bosch HBN666
Bosch HBN742 AUC (FD 8207-)
Bosch HBN745 AUC (FD 8207-)
Bosch HBN746 AUC (FD 8207-)
Bosch HBN752 AUC (FD 8207-)
Bosch HBN755 AUC (FD 8207-)
Bosch HBN756 AUC (FD 8207-)
Bosch HBN765 AUC (FD 8207-)
Magic Chef HC309B-2 HOOD
Magic Chef HC30AB-2 HOOD
Frigidaire HC30C Frg(v1) / Range Vent Hood
Frigidaire HC30CL Frg(v2) / Range Vent Hood
Frigidaire HC8830S Frigidaire / Range Hood
Frigidaire HC8830W Frigidaire / Range Hood
Frigidaire HC8836S Frigidaire / Range Hood
Frigidaire HC8836W Frigidaire / Range Hood
Hardwick HCF120 FREEZER- VERTICAL
Hardwick HCF170 FREEZER- VERTICAL
Hardwick HCF200 FREEZER- VERTICAL
General Electric HCK23LCMAFCC Refrigerator
Amana HCL305 RANGE- S/C S/I DDRAFT GAS
Amana HCL605 RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 10-02-2013, 07:27 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Provide a better model number that's not complete usually there's alot more digits on those models like 13 digits
  #3 (permalink)
Old 10-03-2013, 12:47 PM
Junior Member
Default
I gave the whole machine a good looking over last night and only relevant text on the machine is "Haier HLP021 WM".
I was also able to confirm that the leak is defiantly coming from the junction of the pump inlet pipe and the hose.
  #4 (permalink)
Old 10-03-2013, 05:42 PM
Senior Member
Default
Well then you solved your problem.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tub slowly filling when not in use Modomo Washer Repair 1 07-06-2013 06:16 AM
slowly moving agitator colonianj86 Washer Repair 1 09-05-2010 04:48 PM
Spins slowly JSK Washer Repair 2 06-01-2009 07:13 AM
Spinning Slowly rallen Washer Repair 0 05-03-2009 10:43 AM
Dishwasher bottom leaking slowly from sump gabhroo Dishwasher Repair 0 12-21-2007 10:17 PM
