Discuss
No spin still hums replaced gears and tube
 in
Washer Repair
I have replaced the transmission on the advice of a Sears repairman, still doesn't spin only hum from motor. The
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No spin still hums replaced gears and tube
  #1 (permalink)
Old 10-02-2013, 12:28 PM
Junior Member
DaveD69 is on a distinguished road
Default No spin still hums replaced gears and tube
Model Number: 110.29882980   Brand: Kenmore   Age: 5 - 10 years
I have replaced the transmission on the advice of a Sears repairman, still doesn't spin only hum from motor. The basket seamed real tight, I bought and replaced the basket drive, still only hums. I found this forum and make adjustments to the brake lining, performed the manual test and it seamed to turn a lot easier than before but when I put it all back together it still only hums. It doesn't seam like it is trying to turn at all. I have even reached down inside the tub to try and help get it going but it is tight, almost like frozen. I must have something wrong but cannot figure out what else to look at. Any ideas?
DaveD69
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-02-2013, 12:52 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Check the model number, doesn't come up. Does it fill and agitate ok?
Eric
  #3 (permalink)
Old 10-02-2013, 01:57 PM
Junior Member
Default
Quote:
Eric
110.29882890 model
I've been working on this on and off for over two weeks, first time over 6 weeks ago it had this problem and I took off the inner tub to check the block which was ok and put it all back together and it worked for about two weeks. I have not tried the fill and agitate cycles as I don't want to have to deal with all the water. Am I making a mistake not trying that? Thanks for your reply
  #4 (permalink)
Old 10-02-2013, 02:07 PM
Junior Member
Default
So far I have replaced the pump,coupler,tub block,complete gear case with new clutch and basket drive with new brakes. I'm wondering if the capacitor could be bad, I pulled it and don't believe it had a charge in it, tested it with A cap meter and got a reading of .175? Could that be it.
  #5 (permalink)
Old 10-02-2013, 02:25 PM
Expert
APP Volunteer
Default
Yes, it certainly could be. Set the motor on the floor, still plugged in and try it. If it just hums, spin the shaft by hand and it should start. If it does, problem could be motor switch or capacitor but based on your capacitor test, it's bad. Cap should be 324-389 microfarads
http://www.appliancepartspros.com/wh...ap3861916.html
Eric
  #6 (permalink)
Old 10-02-2013, 02:28 PM
Junior Member
Default
Eric
I will try that thanks, that should narrow it down, is the start switch that red plastic piece that the wire harness hooks over.?
  #7 (permalink)
Old 10-02-2013, 02:36 PM
Expert
APP Volunteer
Default
Yes, you can open it up to examine and clean the contacts if necessary. Can you provide a photo of your wiring diagram? Can't seem to find it. Should be inside of control panel.
Eric
  #8 (permalink)
Old 10-02-2013, 02:48 PM
Junior Member
Default
Eric
Motor started and ran on its own, I let it run for about 2 minutes.
  #9 (permalink)
Old 10-02-2013, 03:03 PM
Expert
APP Volunteer
Default
Still could be capacitor. It takes a lot more torque to start the motor when it's driving the gearcase. The capacitor gives it the extra torque for starting. You should be able to rotate the gearcase input shaft by hand or using a drill. CW for spin, CCW for agitate. Take half the motor coupler off the motor shaft, put a bolt through it and nut and chuck the bolt into the drill.
Eric
  #10 (permalink)
Old 10-02-2013, 03:21 PM
Junior Member
Default
I am able to rotate it by hand but it does take some effort but there is no scraping brake noise as before. Is using a drill a better method to test this? By the way after testing the motor to the side with success and reinstalling it.....HUMMMmMmsssss
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker fill tube frozen; replaced valve already JCapriotti Refrigerator & Freezer Repair 0 01-08-2011 06:33 PM
Looking for Place to buy Amana Transmission gears! BobLang Washer Repair 0 11-27-2010 05:54 PM
Replaced Clutch Assembly Now Machine Just Hums rfinnin Refrigerator & Freezer Repair 2 11-10-2010 08:03 AM
Drains but does not spin just hums glegace Washer Repair 1 10-08-2009 12:47 PM
drive gears pete104 Trash Compactor Repair 0 05-12-2009 07:06 PM
