Discuss
Maytag Bravo 300 leaking water
 in
Washer Repair
Have a Maytag Bravo 300 Series topload washer that started to leak water. I thought it was a pump. Took
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Bravo 300 leaking water
  #1 (permalink)
Old 10-01-2013, 09:35 PM
Junior Member
spyderEd is on a distinguished road
Default Maytag Bravo 300 leaking water
Model Number: MVB700VQ0   Brand: Maytag   Age: 5 - 10 years
Have a Maytag Bravo 300 Series topload washer that started to leak water. I thought it was a pump. Took the back off and watched while it ran through a cycle. It looks like it starts to leak when it goes to the spin cycle. I can see water (have it on a drip pan) start to appear on the pan when the spin cycle starts and I can feel water spray as it spins. Checked the pumps and they seem to be okay. Put washer through 2 whole cycles and water did not appear until it started to spin. It looks like it is coming from the bottom of the tub where there is some kind of plate type fixture on the bottom. The water appears in a circular fashion as if the spinning motion is spraying the water in a circular pattern. There is not a lot of water, maybe 2 cups worth after a full soak\rinse\spin cycle.
Related Models
Amana MVH-1020 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-700 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-720 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-900 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-920 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-9T MWAVE - FAMILY SIZE (60 HZ)
Amana MVH-9T MWAVE- MOUNTED OVER RANGE/WO
Amana MVH100E1 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH110E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH110E1 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire MVH1150C0 Frg(v0) / Microwave Oven
Frigidaire MVH1150C1 Frg(v0) / Microwave Oven
Frigidaire MVH1150C2 Frg(v1) / Microwave Oven
Frigidaire MVH1190A Frg(v1) / Microwave
Frigidaire MVH1190E1 Frg(v1) / Microwave
Frigidaire MVH1190E2 Frg(v1) / Microwave
Frigidaire MVH1190N Frg(v1) / Microwave Oven
Frigidaire MVH1190P Frg(v1) / Microwave
Frigidaire MVH1195A Frg(v1) / Microwave
Frigidaire MVH1199A Frg(v2) / Microwave
Frigidaire MVH1199N Frg(v2) / Microwave Oven
Frigidaire MVH1199P Frg(v2) / Microwave
Amana MVH120E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH130E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH130W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH140E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH140W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH150E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH150W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH150W MWAVE - FAMILY SIZE (60 HZ)
 MVH1615WW Microwave Oven
 MVH1670ST Microwave Oven
Amana MVH200E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH200E1 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH200W1 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH210E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH210E1 MWAVE - FAMILY SIZE (60 HZ)
Amana MVH210W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH210W1 MWAVE - FAMILY SIZE (60 HZ)
Amana MVH220E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH220W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH230E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH230L MWAVE- MOUNTED OVER RANGE/WO
Amana MVH230W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH240E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH240L MWAVE- MOUNTED OVER RANGE/WO
Amana MVH240W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH250C HOOD
Amana MVH250C MWAVE - FAMILY SIZE (60 HZ)
Amana MVH250E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH250L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH250W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH320E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH320L MWAVE- MOUNTED OVER RANGE/WO
Amana MVH320W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH330E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH330L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH330W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH340E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH340L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH340W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350C HOOD
Amana MVH350C MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350SS MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350W MWAVE - FAMILY SIZE (60 HZ)
Amana MVP211 MWAVE - FAMILY SIZE (60 HZ)
Maytag MVP5000TQ0 LAUNDRY TOWER
Maytag MVP8600TB0 LAUNDRY TOWER
Maytag MVP8600TU0 LAUNDRY TOWER
Maytag MVP8600TW0 LAUNDRY TOWER
Maytag MVP9000TB0 LAUNDRY TOWER
Maytag MVP9000TU0 LAUNDRY TOWER
Maytag MVP9000TW0 LAUNDRY TOWER
Maytag MVWB300WQ0 AUTOMATIC WASHER
Maytag MVWB300WQ1 AUTOMATIC WASHER
Maytag MVWB400VQ0 AUTOMATIC WASHER
Maytag MVWB450WQ0 AUTOMATIC WASHER
Maytag MVWB450WQ1 AUTOMATIC WASHER
Maytag MVWB700VQ0 AUTOMATIC WASHER
Maytag MVWB750WB0 AUTOMATIC WASHER
Maytag MVWB750WB1 AUTOMATIC WASHER
Maytag MVWB750WL0 AUTOMATIC WASHER
Maytag MVWB750WL1 AUTOMATIC WASHER
Maytag MVWB750WQ0 AUTOMATIC WASHER
Maytag MVWB750WQ1 AUTOMATIC WASHER
Maytag MVWB750WR0 AUTOMATIC WASHER
Maytag MVWB750WR1 AUTOMATIC WASHER
Maytag MVWB800VB0 AUTOMATIC WASHER
Maytag MVWB800VQ0 AUTOMATIC WASHER
Maytag MVWB800VU0 AUTOMATIC WASHER
Maytag MVWB850WB0 AUTOMATIC WASHER
Maytag MVWB850WB1 AUTOMATIC WASHER
Maytag MVWB850WL0 AUTOMATIC WASHER
Maytag MVWB850WL1 AUTOMATIC WASHER
Maytag MVWB850WQ0 AUTOMATIC WASHER
Maytag MVWB850WQ1 AUTOMATIC WASHER
Maytag MVWB850WR0 AUTOMATIC WASHER
Maytag MVWB850WR1 AUTOMATIC WASHER
Maytag MVWC300VW0 AUTOMATIC WASHER
Maytag MVWC300VW1 AUTOMATIC WASHER
Maytag MVWC400VW0 AUTOMATIC WASHER
Maytag MVWC400VW1 AUTOMATIC WASHER
Maytag MVWC450WW0 AUTOMATIC WASHER
Maytag MVWC500VW0 AUTOMATIC WASHER
Maytag MVWC500VW1 AUTOMATIC WASHER
Maytag MVWC5ESXW0 AUTOMATIC WASHER
  #2 (permalink)
Old 10-02-2013, 07:31 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
You have a blown seal or bad bearing or cracked tub..........but with circular fashion of leak as you stated during spin more then likely it's a bad seal or bearing which basically means you need to rebuild the whole machine. Contact whirlpool with your problem and see if they'll do anything about it you shouldn't have that problem that quick on a unit already.
http://www.whirlpool.com/contact-us/
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Bravo top load bobber50 Washer Repair 2 04-06-2012 02:37 PM
Maytag Bravo Lid Shattered bbylow Washer Repair 1 05-19-2011 03:42 PM
Opinion please: New Maytag Bravo Valley Washer Repair 3 10-28-2010 02:01 PM
maytag bravo gas dryer problem bugjuice Dryer Repair 1 07-14-2010 02:02 PM
Help With Maytag Bravo Please jok3rw Washer Repair 3 10-06-2009 09:30 PM
