Register | FAQ's | New Posts | Today's Posts | Extras |
» h2o all over inside of machine |
![]() Model Number: DLW330RAW Brand: Amana Age: 5 - 10 years
![]() Installed new h2o pump,when washer goes from wash or rinse and starts to drain n spin as it spins faster water flys out of the drain holes on top of the tub all over the inside of the machine. drain pipe is no more than a foot into house drain,hoses to and from pump are clean and clear,brand new pump.. any sugestions??? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Wow, a new one. About the only thing I can think of is that something is clogging the drain lines or the new pump is defective or partially blocked. Check that out and see if you can find a problem.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
retrieving towel from inside machine | cleaninglady | Washer Repair | 0 | 07-17-2010 08:39 AM |
The lid and machine is HOT but inside the drum is NOT | jtowell | Dryer Repair | 4 | 12-10-2009 07:38 PM |
tub wobbles and oil found inside machine on bottom plate | b.gale | Washer Repair | 1 | 08-29-2009 04:14 AM |
Maytag LA510 Leaks just inside machine | rsi77 | Washer Repair | 1 | 08-06-2009 03:11 PM |
machine does not start to agitate unless clothes inside are repositioned | charleyk | Washer Repair | 11 | 06-29-2009 03:00 AM |
