Discuss
Whirlpool washer makes grinding noise on wash and rinse cycles. Spin cycles are fine
 in
Washer Repair
My Whirlpool top load washer makes a loud grinding noise on wash and rinse cycles. The spin cycles seem to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer makes grinding noise on wash and rinse cycles. Spin cycles are fine
  #1 (permalink)
Old 09-30-2013, 10:19 AM
Junior Member
Debbie Foster is on a distinguished road
Unhappy Whirlpool washer makes grinding noise on wash and rinse cycles. Spin cycles are fine
Model Number: LSN2000LW0   Brand: Whirlpool   Age: 5 - 10 years
My Whirlpool top load washer makes a loud grinding noise on wash and rinse cycles. The spin cycles seem to work as normal with no noise. When
the washer makes the loud grinding noise, the agitator seems to slip. Any suggestions?
Related Models
Whirlpool LSN2000LW0 WASHER - DIRECT DRIVE
Whirlpool LSN2000LW1 AUTOMATIC WASHER
Whirlpool LSN2000PG0 AUTOMATIC WASHER
Whirlpool LSN2000PG1 AUTOMATIC WASHER
Whirlpool LSN2000PG2 AUTOMATIC WASHER
Whirlpool LSN2000PG3 AUTOMATIC WASHER
Whirlpool LSN2000PG4 AUTOMATIC WASHER
Whirlpool LSN2000PW0 AUTOMATIC WASHER
Whirlpool LSN2000PW1 AUTOMATIC WASHER
Whirlpool LSN2000PW2 AUTOMATIC WASHER
Whirlpool LSN2000PW3 AUTOMATIC WASHER
Whirlpool LSN2000PW4 AUTOMATIC WASHER
 LSN240HE Air Conditioner
 LSN242CE Air Conditioner
 LSN242HE Air Conditioner
Whirlpool LSN3000PG0 AUTOMATIC WASHER
Whirlpool LSN3000PG1 AUTOMATIC WASHER
Whirlpool LSN3000PG2 AUTOMATIC WASHER
Whirlpool LSN3000PG3 AUTOMATIC WASHER
Whirlpool LSN3000PG4 AUTOMATIC WASHER
Whirlpool LSN3000PW0 AUTOMATIC WASHER
Whirlpool LSN3000PW1 AUTOMATIC WASHER
Whirlpool LSN3000PW2 AUTOMATIC WASHER
Whirlpool LSN3000PW3 AUTOMATIC WASHER
Whirlpool LSN3000PW4 AUTOMATIC WASHER
 LSN301HE Air Conditioner
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
 LSNC183VMA Air Conditioner
 LSNJ0910CL Air Conditioner
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
Whirlpool LSP8245AW0
Whirlpool LSP8245BN0
Whirlpool LSP8245BW0
Whirlpool LSP9245BN0
Whirlpool LSP9245BN1
Whirlpool LSP9245BW0
Whirlpool LSP9245BW1
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0 AUTOMATIC WASHER
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0 AUTOMATIC WASHER
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0 WASHER
Whirlpool LSQ7030LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ7030LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ7030MQ0 AUTOMATIC WASHER
Whirlpool LSQ7533JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ7533JQ1 WASHER
Whirlpool LSQ7533JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ7533JT1 WASHER
Whirlpool LSQ8000HQ0 WASHER
Whirlpool LSQ8000JQ0 WASHER
Whirlpool LSQ8000JQ1 WASHER
Whirlpool LSQ8000LQ0 WASHER
Whirlpool LSQ8000LQ1 AUTOMATIC WASHER
Whirlpool LSQ8000LQ2 AUTOMATIC WASHER
Whirlpool LSQ8000LQ3 AUTOMATIC WASHER
Whirlpool LSQ8200HQ0 AUTOMATIC WASHER
Whirlpool LSQ8200HZ0 AUTOMATIC WASHER
Whirlpool LSQ8220HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HZ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ1 WASHER
Whirlpool LSQ8500JQ2 WASHER
Whirlpool LSQ8500JT0 AUTOMATIC WASHER
Whirlpool LSQ8500JT1 WASHER
Whirlpool LSQ8500JT2 WASHER
Whirlpool LSQ8500LQ0 AUTOMATIC WASHER
Whirlpool LSQ8510LQ0 AUTOMATIC WASHER
Whirlpool LSQ8511KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ8511KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ8512KQ0 WASHER
Whirlpool LSQ8512KT0 WASHER
Whirlpool LSQ8520JQ0 AUTOMATIC WASHER
Whirlpool LSQ8520JQ1 WASHER
Whirlpool LSQ8543JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JQ1 WASHER
Whirlpool LSQ8543JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JT1 WASHER
Whirlpool LSQ8543JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JZ1 WASHER
Whirlpool LSQ9010KQ0 WASHER
Whirlpool LSQ9010KT0 WASHER
Whirlpool LSQ9010LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LG1 AUTOMATIC WASHER
Whirlpool LSQ9010LG2 AUTOMATIC WASHER
Whirlpool LSQ9010LG3 AUTOMATIC WASHER
Whirlpool LSQ9010LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LQ1 AUTOMATIC WASHER
Whirlpool LSQ9010LQ2 AUTOMATIC WASHER
Whirlpool LSQ9010LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LW1 AUTOMATIC WASHER
  #2 (permalink)
Old 09-30-2013, 10:37 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Probably worn "dogs" in the agitator cam. See video on parts page.
Whirlpool 285809 Short Cam Agitator Repair Kit - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 09-30-2013, 11:12 AM
Junior Member
Default
Eric,
I watched the video my agitator came apart just like in the video. However
the cam does not come out when I turn the agitator upside down like in the video. I think you may be right about the problem I have. The top of this piece looks to be clear plastic over a white ring with 4 raised white plastic tabs. Out of the 4 tabs only one is in tact. the other three appear to be grinded down and one is completely grinded off. Just cannot get the "kit" out of the agitator. Any suggestions?
  #4 (permalink)
Old 09-30-2013, 02:12 PM
Expert
APP Volunteer
Default
Sounds like you need a new thrust spacer as well.
Whirlpool 3951608 Thrust Spacer Washer - AppliancePartsPros.com
Don't know about the stuck cam. You might need to make a tool to reach up in there to pull it out.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Direct drive washer agitates and drains fine, not spining after wash and rinse cycles whl66 Washer Repair 3 02-01-2012 04:44 AM
Kenmore 80 Series Washer makes a banging noise during rinse & spin cycles sixnovaceks Washer Repair 1 09-30-2010 06:04 PM
Loud Grinding noise during spin cycles stephsexton Washer Repair 16 10-01-2008 10:11 AM
Grinding noise during wash cycles tekajan Dishwasher Repair 0 11-30-2007 06:10 PM
