Hi, The problem I'm having is a washer that will not level out at any setting you set on the fill indicator. Causing it to overflll all the time. since this happen the washer will not agitate but will spin. Any ideas? Thank you!
If the water does not shut off when the machine is shut off, the problem is in the water valves and they need to be replaced. Since your machine will not agitate this is not likely the problem
If it does shut off when the machine is shut down, then check the tube going from the water level switch to the tub. It can get obstructed so clean it out good and try the machine. If that does not fix it the water level pressure switch is the likely the problem, and will need to be replaced.
